October 18, 2025, 05:40:19 AM *
Author Topic: tyre size  (Read 4784 times)
blair
it looks bigger in water ! !
« on: August 26, 2008, 12:22:41 PM »
does anyone know about tyre sizes ?
i have a spoked rear wheel with a 120 / 90 /17 tyre and was wondering if i could fit a 130 /90 /17  or wider if poss ?
its only 10 mm extra and it if i can it mean i could use the same tyre that i used on my z550 chop , theres no limit on width as i havent built the frame yet but i dont know what the maximum tyre width would be
any ideas ?
cheers
« Reply #1 on: August 26, 2008, 12:47:01 PM »
any idea what size the wheel is? apart from the diameter of course
maybe this will help
http://www.steelthundercc.com/tiresizes.html
« Last Edit: August 26, 2008, 01:20:32 PM by tbone » Logged
blair
« Reply #2 on: August 26, 2008, 03:52:35 PM »
thanks tbone , no i would be able to measure it once i have the tyre off but untill then just the tyre dimms , thanks for the link but its not working , i will try again later
toad
« Reply #3 on: August 26, 2008, 04:00:08 PM »
your wheel should have the rim size stamped into it Grin
blair
« Reply #4 on: August 26, 2008, 04:18:53 PM »
good piont toad , i will go and check
« Reply #5 on: August 26, 2008, 04:34:55 PM »
a 120/90/17 will fit on rims 2.50 - 3.00 with an overall width of 119
a 130/90/17 will fit on rims 2.50 - 3.50 """""""""""""""""""""""""""" of 129
Taken from the Avon tyres website Roadrider tyre data sheet
and at last i found that link........http://www.avon-tyres.co.uk/motorcycle/content/en/pdf/roadrider.pdf
« Last Edit: August 26, 2008, 04:41:10 PM by tbone » Logged
blair
« Reply #6 on: August 27, 2008, 10:25:34 AM »
thanks tbone , had a look at the rim and theres no stampings on it so i ll measure it once the tyre is off
retro900
I Love The Blues They Tell My Story
« Reply #7 on: March 15, 2009, 01:28:12 AM »
120 / 90 /17
17 is the wheel diameter.
120 is the tyre width
90 is the aspect ratio (90% of the 120 width) thats the depth of the tyre from centre of tread to rim (not sure if measured as a staright line or the contour of the tyre).
"Ony Bikers Understand Why Dogs Like To Stick Their Heads Out Of Car Windows"
http://www.bikepics.com/members/retro900/
manfred
So many projects - so little time.....
« Reply #8 on: March 24, 2009, 12:47:54 AM »
It's straight line.
Over the hill and picking up speed on the long down-hill unto DEATH.
