February 19, 2026, 09:18:35 PM *
Author Topic: trike back lights  (Read 4231 times)
gpz
« on: May 29, 2008, 01:45:00 PM »
can any one tell me how high off the floor back lights have to be and how far in from the side any help appreciated
texon
« Reply #1 on: May 29, 2008, 02:54:51 PM »
Madron has all those regs  Wink
« Reply #2 on: May 29, 2008, 06:21:43 PM »
Rear lights.
Minimum height 250mm.
Maximum height 1500mm.
Vehicles wider than 1300mm must be fitted with 2 position lamps.
Vehicles wider than 1300mm must have 600mm between illuminated surfaces.
Vehicles less than 1300mm wide may have 400mm between illuminated surfaces.
The measurement is taken from the appropriate edge of the lens, not the centre.
Vehicles less than 1300mm wide may have a single rear position light but I'm not sure if that has to be centrally mounted, (all pairs of lights must be symetrically mounted).
Rear indicators.
2, or 4 maximum.
Minimum height 350mm.
Maximum 400mm from outermost edge of vehicle.
Minimum 500mm between illuminated surfaces.
gpz
« Reply #3 on: May 29, 2008, 09:05:10 PM »
thanks manky as usual you have the answer
« Reply #4 on: May 29, 2008, 09:09:31 PM »
Know the answers, just not the questions. Tongue
Got the MSVA manual here so if you need anything quoted just ask.
gpz
« Reply #5 on: May 29, 2008, 09:13:00 PM »
thanks thats just what i need cos i dont want to mess up again ,having second go at getting the frame rails up to the headstock the right lenght
« Reply #6 on: May 29, 2008, 09:33:28 PM »
Keep plugging away at it mate.
Tori
« Reply #7 on: July 03, 2008, 01:20:29 PM »
Is this for sva or mot? i had no idea my lights should be a certain distance from the ground. Oops! I'm sure they're fine though.
« Reply #8 on: July 03, 2008, 01:32:15 PM »
They not only have to be a certain height but they have to be set at a max width to the trike too. Marker lights/reflectors are also required to show the full width of the trike, front and back.
« Reply #9 on: July 03, 2008, 03:14:06 PM »
For MSVA Tori.
The MOT's only checking things work & are safe. It assumes it's already legal measurement wise by being registered for road use.
There's a yellow ring binder available from the DVLA for about 30 quid that contains all the relevant info for MSVA. That's what I've quoted from. You need a marker light to show the width of the vehicle, white showing towards the front & red to the rear. They have to be within 400mm of the edge of the vehicle. You also need red reflectors at the back, (not triangular ones).
« Last Edit: July 03, 2008, 09:19:08 PM by Manky Monkey » Logged
Tori
« Reply #10 on: July 03, 2008, 08:32:35 PM »
Ahhh I'm cool then I think.. Just going for mot end of aug/beginning of september. It's been a long time coming finishing this project, and I can't wait to see it on the road. My heart, soul, tears, blood, burnt hair and chapped fingers and broken nails have gone into it. Smiley
