January 01, 2026, 01:46:29 AM
A phrase Mr Haynes never uses!
Topic: A phrase Mr Haynes never uses! (Read 1204 times)
November 25, 2007, 12:19:17 PM »
Just reading a site about restoring a mini and came across this wonderful phrase which I know you lot will appreciate!
Regardless which fan is used
a mallet adjustment
has to be done to the front crank case breather in order to provide the necessary clearance.
klogan45
Re: A phrase Mr Haynes never uses!
November 25, 2007, 02:17:59 PM »
Sounds like I might have written that
Certainly made some fine adjustments with a mallet in the past
K
