« Reply #135 on: May 03, 2008, 10:20:19 PM » |
My Webbers say "400COE32" on them, or possibly "40DCOE32" -hard to read. They measure 40mm across the mouths anyway. Wonder how they'd perform on my Rover V8?
brock
« Reply #136 on: May 03, 2008, 11:08:01 PM » |
40 DCOE and yeah they'd be Ok, build a plenum with 8 individual runners and mount the carbs sticking out each side. Or, see if you could find an old boxer manifold and have four SU's, two a side. Or stick a single 360 Holley on top. Do you have the standard twin SU manifold ?, make an adaptor to mount the Webbers into that.
« Reply #137 on: May 03, 2008, 11:16:57 PM » |
Yup, the SUs are hooked up & working. Just wondering if we'll have the room under the bonnet for them. A Holley straight through the top of the bonnet will be the answer if we haven't.
« Reply #138 on: May 04, 2008, 10:23:50 AM » |
they are manky  i want another 151/7b thanks for lookin
« Reply #139 on: May 21, 2008, 11:06:35 AM » |
Dai's on the job!!! a term i used to use when in work meaning dilemma !! ok i have to run the axle at an angle to accommodate the sump nut at the front "it sits very low" to ensure i have enough clearance for speed bumps etc. pics below to explain, im also close to bending pipe and this is making me feel it gonna feck up,"costy of the pipe is in me head" atm i have a 16 tonne bender but may have to rent a staffa for a week or too? God i wish i didnt live on the outskirts to now where   VB's trike project  VB's trike project  VB's trike project  VB's trike project
madron
« Reply #140 on: May 21, 2008, 12:27:01 PM » |
vb wont engine n box drop down a bit more i build with about 4" clearance which works fine i was thinking that uj is very tightly angled at gearbox and might cause you problems
« Reply #141 on: May 21, 2008, 02:05:48 PM » |
ive got 6.5" atm from the base of the sump nut to the ground so i can drop it more, gonna ave to make some sort of sump guard as u lot know sumps aint that hard and that nut is just asking to get ripped out
texon
« Reply #142 on: May 21, 2008, 02:11:13 PM » |
I agree with Ron drop the engine and gearbox down at that prop angle it will knock it self apart
« Reply #143 on: May 21, 2008, 02:30:17 PM » |
im also close to bending pipe and this is making me feel it gonna feck up,"costy of the pipe is in me head" atm i have a 16 tonne bender but may have to rent a staffa for a week or too? God i wish i didnt live on the outskirts to now where  Its Probably to late for you and I`m sorry for that, but i have some BS1387 pipe, 48mm OD. 42mm ID, 3mm wall. Yours if you can use it.
« Reply #144 on: May 21, 2008, 02:44:50 PM » |
hmm yeah ive already pd £220 for 6 lengths thanks anyway
« Last Edit: May 21, 2008, 02:46:28 PM by VALLEYSBOY »
« Reply #145 on: May 21, 2008, 02:48:59 PM » |
but im bound to wreck it so where does yuhs live TBone?
« Reply #146 on: May 21, 2008, 03:02:26 PM » |
The pipe is in gloucester, you`ll have to cross that bridge again!  There`s 6 lengths that are 20 odd feet (my tape measure stops at 16ft) and a short bit about 12ft long.
« Reply #147 on: May 21, 2008, 03:12:43 PM » |
Flap only has 3" of ground clearance, Manky's has 5" clearance and mine will be 6-7"
« Reply #148 on: May 21, 2008, 03:43:17 PM » |
arent your frames the lowest part though? the sump being inside the frame parimeters, my sump "see pic above front pic going of current mounting points"that blksorta rubber looking thing with 2 nut and bolts pointng down" will sit below the frame, im just weary of wether im doing it right  if yuhs get my meaning
« Reply #149 on: May 21, 2008, 03:44:34 PM » |
The pipe is in gloucester, you`ll have to cross that bridge again!  There`s 6 lengths that are 20 odd feet (my tape measure stops at 16ft) and a short bit about 12ft long. im not afraid of bridges  got the magic blue card as well, but i could also go m5 m42 ... you near stroud?
