October 13, 2025, 06:41:45 AM *
Pages: [1] 2 3 ... 19
Author Topic: VB's trike project  (Read 65004 times)
« on: October 24, 2007, 07:23:40 PM »
Hi all, im still in the collecting part of my 1st build, I have collected some parts from Desperate Dan “which most now of any rds” here’s some pics of there current location in passage 1&2  Grin
http://www.ratrods.co.uk/trikeproject/passage1.jpg
VB's trike project
http://www.ratrods.co.uk/trikeproject/passage2.jpg
VB's trike project
shortened escort axle/90cm long two gearboxes hidden on the left, wheels and 750cc motor various other parts not sorted them yet.
Aint much yet but I will post as it continues....
« Last Edit: February 06, 2008, 09:34:39 PM by VALLEYSBOY » Logged
« Reply #1 on: October 24, 2007, 10:40:37 PM »
Good chap! Another trike underway  Grin
You missed a bit when you painted the wall in that first piccie by the way.  Wink
« Reply #2 on: October 24, 2007, 11:07:08 PM »
hehe nah thats the start of the door way we made from the house to that passage which was outside walk way to front of house Smiley but yeah i havent painted it:) sheesh the things u have to do to keep up with u lot Smiley
« Reply #3 on: October 24, 2007, 11:14:30 PM »
I must get round to redecorating in here too. You lot don't 'alf leave a mess you know. And look at that big cobweb up there.
« Reply #4 on: October 24, 2007, 11:26:26 PM »
Smiley
« Reply #5 on: October 25, 2007, 05:55:50 AM »
Yey finally your own thread. Lots of picies as you go along   Grin
« Reply #6 on: October 25, 2007, 10:05:54 AM »
hmm yeah, trouble is Andy got the better of me so ive decided to paint my corridors 1st!!! Yeah right:) i dare not take a pic of the other wall!! lolol
« Reply #7 on: October 25, 2007, 08:44:30 PM »
ok been reading alot just finding out what ive got to start with Smiley dunno if engine numbers been covered over here? sorry if it has as im about to post on it lol.
i copied this from a member"str8lolly" about defining your reliant engine further.. he posts..
heres what we have gentlemen. First part was originally from Elvis old forum that I saved many moons ago. Seems to agree with Reliant service bulletins. Add, subtract what you will and we should end up with a really good insight into the engines.
The first section of an 850 engine number denote year and month.
A=Jan, B=Feb, C=Mar, D=Apr, E=May, F=Jun, G=July H=August J=september
6=1976, 7=1977, 8=1978, 9=1979, 0=1980, 1=1981, 2=1982, 3=1983, 4=1984, 5=1985, 6=1986, 7=1987
I can just about confirm this!
We know the second section is the engine size i.e. 85 = 850cc.
The third section appears to be a consecutive numbering of engines.
SO....
2D/85/65955 is an 850cc engine made in April'82
3D/85/69696 is an 850cc engine made in April'83
If we subtract the two engine numbers we get 3741 which should be, roughly, the number of Reliant engines produced in that 12 month period.
Something odd seems to happen to this number in the late seventies...but that's another problem!!!!!
PHEW! Does that seem to make sense?
Makes sense as my daughters 1983 Rialto has the engine number 3D/85/69696! But it does mean that the car was built in April and sold/registered 21/May/1983! Built and sold in a month, good going by anyones standards. Actually makes sense with my Robin engine number 9L/85/57630 Which would mean being built in September 1979 and sold/registered in February 1980. Suggests the Rialto was built to order for a customer while the Robin was built for a showroom.
We all seem to miss that the registration date will not be the build date of the engine.
My thanks to the members of R3W for the following contributions.
I've dug around and found a photocopied list of principle engine changes for Regal and Rebel. Six digit numbers begining with the number 7 are Rebel engines.
600cc
87367 Distributor was lowered.
88758 Gudgeon pins enlarged to 9/16" diameter.
91700 (c. Mar '66) Oil supply to rockers modified.
93860 Crank pulley bolt changed to 3/8" UNF.
101090 Three studs added to the side of the head/block.
107142, 700001 (c. Nov '67) TW7B Full flow oil filter and 30IZ Zenith carburettor.
700cc
115915, 700491 (Jun/Aug '68) 700cc introduced. Distributor rotation now anti-clockwise. Electrics now negative earth.
117572 Water outlet branch changed
129628, 700904 Timing chain tensioner fitted.
136204, 700981 Water pump improved.
141460, 701041 Crankshaft sealing changed.
142300, 701052 Sealed crankcase ventilation.
The only other information I found was in the Reliant Kitten Register's fantastic "Mewsletter" No 36. The engines stamped with just an "8" inbetween , date from around 1973 to August 1975, so I'm guessing that these are in the main 750cc engines, although the article doesn't state. Oddly an engine number 5G/8/10014 appears in the Kitten column as July 1975). Prototype?
5J/85/25866, 5K/85/100226 up to these engines numbers, angled split big end caps were fitted.
Right, the C70 blocks are 700cc ones - no ribbing on the block side. Early 70s vintage would be about right.
(S) = special - unsure if its a reconditioned unit or something else. On early Regal engines.
(R) = reconditioned unit used by Reliant and gmreliantpartsworld.
(@) = reconditioned unit used by gmreliantpartsworld.
If yuhs dunno then this may help Smiley
« Reply #8 on: October 25, 2007, 08:56:29 PM »
I nmy search for clarification to wot i have etc ive posted there..this is the thread didnt seem right to post it all again here as its slightly off topic to the build purposes.
http://www.r3w.co.uk/forum/showthread.php?t=9492
« Reply #9 on: October 26, 2007, 06:10:20 PM »
scrapped
« Last Edit: February 06, 2008, 09:35:20 PM by VALLEYSBOY » Logged
« Reply #10 on: October 26, 2007, 06:11:46 PM »
ops Sad
« Last Edit: October 26, 2007, 06:17:13 PM by VALLEYSBOY » Logged
« Reply #11 on: October 26, 2007, 08:09:53 PM »
Why oops?
Plenty to keep you busy there VB, but I've seen -& owned, worse.  Grin
« Reply #12 on: October 26, 2007, 10:53:25 PM »
ops was for a double post in the beginning Smiley ive seen worse too Smiley trying to find my big C clamp atm cant get valves out without it Sad
toad
« Reply #13 on: October 27, 2007, 02:34:09 PM »
a little tip for removing valves without a compresser. place the head on a good flat piece of wood and find a suitable piece of tube or socket that fits the valve collar then a good sharp tap should pop the collets out we used to use this method all the time when i was rebuilding motors as a full time job if you get stuck i have a spare compresser i can loan you.
« Reply #14 on: October 27, 2007, 05:30:52 PM »
nioce one Toad:) the idea that is i doubt u are close to me though for loaning things Smiley
