March 31, 2026, 08:39:40 PM *
Author Topic: independant suspention  (Read 4724 times)
ian
« on: June 20, 2007, 09:42:32 PM »
i am building a independent suspension rear end on Suzuki intruder and have been told to use sierra hubs but don't know what diff to use HELP
harley gazz
« Reply #1 on: June 22, 2007, 11:01:44 PM »
hi ian, i would of thought if your using siera hubs, then you will need the same for the shafts and diff so as it all maches up, or bmw running gear,are you building a cradle to sit the diff in ,and not running off an axle mated to rear swing arm,with shocks, Wink
arc eye tha noo
ian
« Reply #2 on: June 23, 2007, 08:40:39 AM »
  runing  with a cradle, many thanks ian
harley gazz
« Reply #3 on: June 24, 2007, 11:11:26 PM »
hi ian one o these
arc eye tha noo
Terrortubby
« Reply #4 on: June 26, 2007, 06:01:38 PM »
I'm having a fully independant back end built and will post some piccys as soon as I have been over to get some piccys.
Regards
Gary
Chaos, Panic. Disorder.my work here is done!
http://grumpygaz.blogspot.co.uk/
« Reply #5 on: July 28, 2007, 10:10:57 PM »
Ive used sierra diffs before with sierra shafts, note...left and right shafts are different lengths, about 1&1/2" between them. I used 2 shorter ones to keep diff central and the overall width of trike a little narrower. The bottom rails of frame came right through to back of trike and were used to mount the lower of 2 "H" arms which all had 4 "oil-lite" bushes in them, 2 connected to bottom of one off backplates on wheel and 2 onto the frame. That was duplicated on the upper "H" arms and fitted to top of wheel backplates and parrallel top rails of frame. Further to this each side had an extra diagonal "brace" forward mounted on the lower frame rails to the "H" arms with same bushes to eliminate any "torque" movement. I opted for "H" arms instead of the usual "A" type to give more stability. No anti-roll bar was fitted or needed and when going into a corner it allowed trike to lean a little like a bike. All this worked very well and the new owner is still pleased with it even after nearly 5 years.
hope this is useful to you
« Reply #6 on: July 28, 2007, 10:16:01 PM »
another photo
ian
« Reply #7 on: July 29, 2007, 03:21:59 PM »
many thanks for the info i am buying a pro built unit, what was the ratio of the sierra diff
                   Ian
« Reply #8 on: July 29, 2007, 05:08:42 PM »
I like the look of that, it's cleaner looking than some irs back ends.
« Reply #9 on: August 21, 2007, 07:40:20 PM »
                   Ian
sorry ian, ive hunted around my files but cant find what ratio it was, the trike was sold on a few years ago.
« Reply #10 on: August 22, 2007, 10:31:36 PM »
I was going to use BMW 3 series as you can get different ratios.
Like this:-
ian
« Reply #11 on: August 26, 2007, 06:50:19 AM »
have now bought unit same as that off Casarva LTD many thanks ian
« Reply #12 on: September 06, 2007, 09:41:11 PM »
Show us some photo's then, don't leave us in the dark.
« Reply #13 on: September 07, 2007, 01:40:09 PM »
think this may be it?
http://cgi.ebay.co.uk/BIKE-2-TRIKE-CONVERSION-CRADLE-ASS'Y-LEFT-HAND-DRIVE_W0QQitemZ230166622730QQcmdZViewItem
ian
« Reply #14 on: September 13, 2007, 08:01:18 PM »
thats the one, very good unit.  will send in picks when totally finished
