March 05, 2026, 10:23:48 AM *
Poll
Question: SUGGEST A COLOUR FOR MY TRIKE
ARMY GREEN - 18 (58.1%)
BLACK - 13 (41.9%)
Total Voters: 28
Pages: 1 ... 5 6 [7] 8
Author Topic: Willy's Skorpion Trike Re-build (Restoration ) Poject  (Read 56250 times)
willy
« Reply #90 on: November 26, 2008, 11:33:57 AM »
Mine will need wirring from scratch as well
« Reply #91 on: November 26, 2008, 02:44:03 PM »
All I know about auto-electrics.
Auto electrics
Electricity isn't caused by cold fusion, that’s nuts, and forget all that nonsense about magnetic fields and the flow of electrons along a conductor, for it is just that; nonsense, a myth put about by auto electricians to support their lavish lifestyle at your expense. The reality is ... smoke!  When you think about it, it all becomes startlingly obvious – smoke makes all electrical things function, if smoke escapes, the component stops working. For example, the last time you had to grovel under the car to replace the starter motor, didn’t it start smoking before it ceased working? - of course!
The wiring loom on your car carries smoke from one device to another, pumped around the system by the alternator, and when a wire springs a leak it lets all the smoke out and everything stops. Starter motors require lots of smoke to work properly, so they have very thick wires going to them. The battery stores up lots of smoke dissolved in battery acid, which is why they were once called accumulators, until it became apparent that we unwashed home mechanics would twig to the secret. Naturally, if you try to dissolve too much smoke in your battery it will escape through those little holes in the top, which is why those batteries with sealed tops explode when they get too much smoke in them.
With regard to Joseph Lucas and his wrongfully sullied reputation, why is he so maligned? Why are Lucas components more likely to leak smoke than, say, Bosch? Because Lucas is British, and all British made things leak. British motorcycles leak oil, British sports cars leak rain, British brakes leak fluid, and British governments leak military secrets. So naturally,  British electrical components leak smoke!
HTH   Wink
willy
« Reply #92 on: November 26, 2008, 07:39:56 PM »
Been busy again today,i've sepperated the engine and box.Next jobs are clean and paint the suspension,clean the gearbox and re-fit it to the trike.
http://i34.tinypic.com/66m2vt.jpg
http://i34.tinypic.com/1y61wx.jpg
« Reply #93 on: November 27, 2008, 12:51:46 AM »
Sounds easy when you say it quick doesn't it!  Tongue
willy
« Reply #94 on: November 27, 2008, 11:38:11 PM »
Manky ... Yes it does
Up Date
Been busy again today ''doing well hey'' i,ve cleaned and painted the suspension and started cleaning the gearbox ready to re-fit it all,pictures to follow.
I also got rid of the green body to a scrapman who happened to drive past as i was aranging for it to be picked up by the local scrap yard,no cash for it but hey its out of my way now.
The trike should be back on all 3 wheels in the next couple of days.
« Reply #95 on: November 27, 2008, 11:50:38 PM »
Fast work Willy!
willy
« Reply #96 on: November 27, 2008, 11:52:40 PM »
Got the feel for it at the moment
willy
« Reply #97 on: November 28, 2008, 05:53:56 PM »
Finished cleaning and painting the suspension and i've finished cleaning the gearbox today.
I have still got to paint the hubs and drums though,they are going to be olive ''army green'' drabb.
http://i37.tinypic.com/2dbqwle.jpg
« Reply #98 on: November 29, 2008, 12:31:48 AM »
Tidy set up.
willy
« Reply #99 on: November 29, 2008, 04:23:49 PM »
Cheers matey
willy
« Reply #100 on: December 12, 2008, 06:04:58 AM »
I've decided to change the name to the skorpion because i think it sounds better
« Reply #101 on: December 12, 2008, 10:48:14 AM »
 Grin How's the re-build going?
willy
« Reply #102 on: December 12, 2008, 03:01:17 PM »
A bit slow again due to the weather and the loss of my brother in law
« Last Edit: January 29, 2009, 05:58:28 PM by willy » Logged
willy
« Reply #103 on: January 29, 2009, 05:59:22 PM »
Up-Date
Been busy today, i managed to get the Gearbox and Suspension back in position ''not easy on your own''' but can't bolt it in because it don't fit due to the replacement box being longer. Think i need to cut the bulkhead to make clearence to get it to fit
http://i42.tinypic.com/j6q642.jpg
http://i42.tinypic.com/20kb2f9.jpg
« Last Edit: September 16, 2010, 09:43:46 PM by willy » Logged
The pointy helmet
« Reply #104 on: January 30, 2009, 01:08:24 PM »
Pray for a spot of sun.
I'm in the same situation as you. No garage, shed.
I have a whopping great conservatory, full of parts...
At the back of a terraced house!
A colour-
British racing green, the late one, more like the After Eight box colour?
Nice and classy, yet understated. Would look nice with any chrome/ ally or gloss black parts.
Odd little highlight of something in red would lift it out.
Waiting for the next post to start-
"Cleared snow.."
