April 19, 2026, 11:01:19 AM *
Author Topic: Gertie up date  (Read 6060 times)
« on: March 17, 2019, 09:59:44 PM »
As you may know I pick up Gertie from BG last week. I can totally under stand how Bobbi feels about parting with her Trike.
I am not sure what's going to happen with it yet but I have removed the axle and swing arm to try and see what the problem is.
So far it looks like There is a fair bit of backlash on the prop to the diff. The planet wheels  are worn and the pinion wheel bearing is wining. There is also some wear on the drive shaft splines. going to check with a mate to see if he has a spare diff if not look at rebuilding this one
« Reply #1 on: March 17, 2019, 11:59:21 PM »
Good to know it's gone to a good home Smiley
« Reply #2 on: March 18, 2019, 12:01:16 PM »
Just so you know, I've told Terry to do whatever with it - fix it, flog it, or use it for parts if the first option isn't viable.  Just didn't want it sitting in my garage any more making me keep wondering if I could ride again - now I can move on.
« Reply #3 on: March 19, 2019, 08:42:07 AM »
Totally agree Bobbi.
Once you set it free, it's no longer your baby & you can't dictate what the new owner does with it, but it does give you "closure" -horrible American phrase, but you know what I mean. You're free to move on.
« Reply #4 on: April 01, 2019, 03:36:11 PM »
Well Over the last week or so I removed the axle and stripped it down. I could not find any thing wrong with it apart from some back lash from the pinion and planet wheels.
So cleaned it all up and put it back together. looking at the drive shaft coupling that fits on the axle and slots into the shaft I did notice a lot of play and ware so I am looking at getting another one made. while its all apart I will give it a rub down and a coat of paint.
« Reply #5 on: April 01, 2019, 06:03:47 PM »
Terry you'll be glad to know I found the seat bracket today and will get it in the post tomorrow!
« Reply #6 on: April 01, 2019, 08:14:03 PM »
Thanks Bobbi let me know what the postage is and I will sent it over.
