April 30, 2026, 10:42:37 AM *
Author Topic: Cross point screws. Work of the devil.  (Read 16249 times)
« on: November 06, 2018, 12:52:46 PM »
Marcus (Lunatic) recently located a hardtop for my MX5 in near new condition.  Grin
Fitted perfectly but I had a problem with one of the rear deck catches. The covers are held in place by small cross point countersunk screws. One came out no sweat, the other was a real pain.
 This little M4 screw took over 4 hours, a lot of cussing, copious amounts of WD40, the making of a tool steel chisel, to cut a deep slot into it and the grinding of a screwdriver,  to remove. Angry
Needless to say it had to be replaced and while they are available from Mazda, at a very silly price no doubt, for just £1.29 I bought 10 stainless steel Allen head ones. Fitted with lots of grease, there shouldn't be any future problems. Smiley
« Last Edit: November 06, 2018, 12:59:41 PM by Olds » Logged
« Reply #1 on: November 06, 2018, 01:54:36 PM »
Always the small stuff that buggers up the plans isn't it! Smiley
« Reply #2 on: November 07, 2018, 07:30:45 AM »
Yup. It's amazing how 'simple quick jobs' often end up taking hours instead of minutes, because of poor design or fasteners that wont unfasten.
 I have a particular loathing for cross points since working on Jap bikes in the 70's and 80's. There would always be at least one engine case screw where the head would be chewed up, need drilling out and you prayed that there would be enough shank left to grip after heating with a gas torch.
One Honda (CJ360t) sticks in my mind because someone had Loctited every fastener and despite using an impact screwdriver, all ended up being drilled.
« Reply #3 on: November 07, 2018, 11:35:09 AM »
One of my enduring memories of my GT550 will be cross-point screws on carb tops!
Bus Boy
« Reply #4 on: February 04, 2019, 08:12:23 PM »
Check out JIS screws on tinternet...............Japans own crosshead screw!!!
« Reply #5 on: February 06, 2019, 07:51:43 PM »
I know about JIS screws, as I worked for Honda motorcycle dealer in the early 70s. Look just like a Phillips but aren't quite the same. We used to warn customers to only use the screwdriver from the supplied tool kit.
Bus Boy
« Reply #6 on: February 06, 2019, 10:27:01 PM »
only found out about them last year!!!!!!always late to the party me Embarrassed
« Reply #7 on: February 07, 2019, 01:26:10 AM »
Most folk don't know the difference. JIS cross points are usually marked with a tiny dimple or dot on the head.
Bus Boy
« Reply #8 on: February 07, 2019, 09:22:43 PM »
see....I'm learning somthing new every day! Embarrassed
« Reply #9 on: March 05, 2019, 09:40:25 AM »
There’s a nice JIS (Japanese Industrial Standard) screwdriver available by a company called Vessel Megadora which looks like an ordinary screwdriver, but is in fact an impact driver.
A pal who runs a business selling used Japanese motorcycles has one and sings it praises.
Looks like they’re available for around the £20 mark.
« Reply #10 on: March 05, 2019, 11:13:17 AM »
ive got one. its ace
only used it as an impact a few times but its does work
worth noting it only impacts "lefty loosey"
« Reply #11 on: March 05, 2019, 07:21:55 PM »
Never seen one of those before -or maybe I have & just thought it was an ordinary screwdriver.
