April 29, 2024, 06:23:32 AM *
Author Topic: Changing the angle on rear suspension  (Read 5503 times)
jevi
« on: July 12, 2018, 08:29:01 PM »
Would this work?
Would I need to SVA the bike if I cut the rear of the frame off and moved the mounting points?
More importantly is there any specific grade of steel I would need for the new shock mounts?
« Reply #1 on: July 12, 2018, 09:15:03 PM »
Is this your First Build Jevi ?
« Reply #2 on: July 13, 2018, 05:22:45 AM »
Any modification to the frame that require cutting it puts it into MSVA territory. To a large extent this has been ignored in the past but things are changing with regards to modified bikes.
As to your grade of steel question... no, but stay away from air hardening steels or exotics. Normal low carbon mild steel will be fine.
As long as the mount is suitably designed, of sufficient strength and can be securely mounted to the frame, then it's OK.
« Last Edit: July 13, 2018, 05:45:06 AM by Olds » Logged
« Reply #3 on: July 13, 2018, 05:28:45 AM »
I've hardtailed my bike frame & haven't put it in for testing, but I know I'll have to at some point.
« Last Edit: July 13, 2018, 12:27:43 PM by Manky Monkey » Logged
« Reply #4 on: July 13, 2018, 05:49:39 AM »
Yup.
 MSVA isn't difficult, especially for a bike if you build to the manual. Just a pain in the ass getting it done.
« Reply #5 on: July 13, 2018, 07:37:48 AM »
Not something I'd admit to on a public forum? Roll Eyes
« Reply #6 on: July 13, 2018, 12:31:02 PM »
I know, but if it gets flagged up I don't lose the bike, it just has it's registration rescinded, so I can't ride it. Then it goes back in the garage & gets modified until it passes. Not my only vehicle, not the end of the World.
jevi
« Reply #7 on: July 16, 2018, 02:14:59 PM »
Just to let you know the bike pictured is from a Russian website.
This will be my first build because I've given up on the trike idea- 8 years since I first signeMore d up to the  world of the monkey and I'm sick of being stuck with no bike especially now my oldest son has recently got himself a 125 and keeps taking the p##s about me not finishing anything.
Anyways  there's nothing stopping me from making a  couple of alterations  - changing the tank and altering the shock mounts.
The main engine cradle will stay, the swinging arm will stay in it's original position and the front forks will go back on to the  keep the same rake.
This time next year?
« Reply #8 on: July 16, 2018, 05:12:48 PM »
Good luck with this. We expect progress reports and pics (especially the pics). Cheesy
jevi
« Reply #9 on: July 29, 2018, 08:20:19 PM »
Just a quick update.  I've started the rebuild!
First job clear the garage, rearrange everything and build a new workbench - check
Next breakout the new toy - cut-off saw and build a jig to hold everything straight (I'll post some pics when I get it finished - promise)
« Reply #10 on: July 30, 2018, 07:28:58 AM »
A frame jig ! Shocked
What, no bit's of string and a length of angle iron ?
Are you sure you're on the right site ?  Wink Grin
« Last Edit: July 30, 2018, 08:38:57 AM by Olds » Logged
« Reply #11 on: July 30, 2018, 07:47:02 AM »
« Reply #12 on: July 30, 2018, 08:02:56 AM »
Angle iron,string ? Roll Eyes
« Reply #13 on: July 30, 2018, 09:14:38 AM »
Roll Eyes D'uh. Elastic stretches too much and round bar keeps rolling away.  Wink
Stix
« Reply #14 on: July 30, 2018, 10:30:48 AM »
Grin Grin Grin
