March 03, 2026, 06:42:34 PM
General Tech
output prop flange
Topic: output prop flange (Read 5856 times)
twisted
output prop flange
July 04, 2018, 03:36:05 PM »
afternoon all.
anyone now of anywhere that either might have as stock or could make a splined out-put flange?.
So a female internal splined cup with a flange at one end that could bolt to a prop UJ?
cheers
Re: output prop flange
July 04, 2018, 03:58:47 PM »
Err. Unlikely. To fit what ?
twisted
July 04, 2018, 04:21:23 PM »
honda pan european st1100 drive shaft out the gear box
July 04, 2018, 07:07:55 PM »
Pictures dude?
July 04, 2018, 09:10:20 PM »
I tell you where you'll find one of them - on the back of a pan-european, connected to the rest of the shaft. Cut and shut my friend, been done times over?
July 04, 2018, 09:10:24 PM »
Why not mod. a Pan output shaft? as to have one made as a "one off" will be extremely pricey!.... to put it mildly!!...Morrag
twisted
Reply #6 on:
July 04, 2018, 11:23:18 PM »
After lots of searching I'm starting to think it might have to go the cut and shut route. Will try to find someone to cut the spline cup off the ujs and weld a plate to it. The original ho da uj is now no good at the angle the prop is now set at and is knocking on it's self. If I can get the flanged cup made it means a better uj with a greater working angle can be used and will have a happier prop.
Reply #7 on:
July 05, 2018, 10:30:18 AM »
On the drive shaft from the axle it should be under spring tension when it slides onto the uj
Reply #8 on:
July 05, 2018, 10:40:42 AM »
That's why many trikes have an offset diff. The shorter the trike, the bigger the problem.
Even using UJ's with a wider operating angle, be cautious of extreme angles at high RPM and make sure the prop is fully balanced. If you are using a live axle, check the angles at both extremes of axle movement.
Last Edit: July 05, 2018, 12:25:50 PM by Olds
Reply #9 on:
July 05, 2018, 08:30:45 PM »
Quote from: terry t on July 05, 2018, 10:30:18 AM
Be careful not to ignore this - holding some tension on the splines is important to pevent the slack causing run out and vibration - had this on my kawasaki splined drive prop.
