December 17, 2025, 11:54:37 AM *
Author Topic: MX5?  (Read 3299 times)
« on: December 30, 2017, 02:57:29 PM »
One of my customers had this parked on his drive this morning. I know he's into kit cars but he wasn't around to ask.
Is it a naked MX5? Definitely a Mazda engine. Interesting single spine chassis design with the propshaft running inside the 3 sided channel that formed the spine.
« Reply #1 on: December 30, 2017, 02:58:00 PM »
« Reply #2 on: December 30, 2017, 05:44:48 PM »
That looks interesting
phunkie hiboy
« Reply #3 on: December 30, 2017, 05:48:09 PM »
Yes, MX5.
« Reply #4 on: December 30, 2017, 10:26:41 PM »
So not monocoque then?
I'll try & find out what he plans to build from it.
phunkie hiboy
« Reply #5 on: December 30, 2017, 11:25:34 PM »
Yes, monocoque. Just 'cos it has a spine, does not mean it's like an elan. If you look at your pictures you will see that there are two subframes, one front and back( bit like a mini or 1100 really). They introduced the Mk1 in '89, don't think there was anybody making chassised sports cars apart from Morgan then.
« Last Edit: December 30, 2017, 11:33:01 PM by phunkie hiboy » Logged
« Reply #6 on: December 31, 2017, 09:14:32 AM »
I'm curious to see what he does with it now Smiley
« Reply #7 on: December 31, 2017, 11:08:37 AM »
The girder like section is called the power plant frame and is bolted to the gearbox and the differential.
« Last Edit: December 31, 2017, 11:23:20 AM by Olds » Logged
« Reply #8 on: December 31, 2017, 12:15:44 PM »
Aah, of course -because it's IRS. I was trying to figure out how the axle moved, but of course, the diff' doesn't.
So does the bodyshell lift off in one piece then?
« Reply #9 on: December 31, 2017, 12:33:28 PM »
If anyone needs one I have an MX5 early 1600 with auto and  prop /cat/ wiring etc pls logbook and all vin tags to use for BIVA.
« Reply #10 on: December 31, 2017, 02:53:56 PM »
 Smiley
« Reply #11 on: December 31, 2017, 03:51:30 PM »
Yep but the springs/shocks mount to the body in a similar way to MacPherson struts.
Does make the power plant and drive train very suitable for mounting on a simple ladder chassis.
 Body rust is the big problem with MX5's but there are a lot of kits out there. From Ferrari lookalikes to Ariel Atom like type cars.
« Reply #12 on: December 31, 2017, 04:37:51 PM »
The guy I bought my replacement Rover V8 from had rebuilt it to put into an Atom style kit, then changed his mind & went for an MX5 motor instead.
« Reply #13 on: December 31, 2017, 05:04:08 PM »
rebodied mx5
https://www.mx5parts.co.uk/info/wp-content/uploads/2016/03/SWB5_635.jpg
MX5?
« Reply #14 on: December 31, 2017, 07:02:36 PM »
Thats nice
