December 15, 2025, 07:00:16 PM
General Tech
A life of vice.
Topic: A life of vice. (Read 4908 times)
A life of vice.
November 28, 2017, 10:01:21 PM »
Recently managed to break the front jaw clean off of my big bench vice.
Bought an even bigger, heavy duty one. When I say heavy i mean 60 Lbs heavy.
Only problem is I'm going to have lower the bench or make a step to stand on to use it.
I will attempt to weld up the old one but, as it's cast iron, I'm under no illusion that it will be anywhere near as strong as before.
Last Edit: November 28, 2017, 10:05:55 PM by Olds
Re: A life of vice.
November 29, 2017, 07:15:44 AM »
Ooh, shiny new! I love new tools
Re: A life of vice.
November 29, 2017, 09:34:02 AM »
do you have cast rods? or dissimilar rods? big V grind and blast them in, it'll be fine, until next time
dont forget pre heat and post heat on cast. You'll be fine, what can possibly go wrong (my Mantra)
Re: A life of vice.
November 29, 2017, 10:05:09 AM »
NiFe rods. These worked for a welding a 3/4" Hardox steel surface to my cast iron anvil. I might strap the sides to add a little more strength. One handy thing about having a forge is being able to get large lumps of metal very hot.
Re: A life of vice.
November 29, 2017, 11:32:50 AM »
Not the prettiest of welding but should hold it together, for a while at least. Deep V prepped (3/4 depth) root welded then filled.
paulywombats
Re: A life of vice.
November 29, 2017, 12:53:00 PM »
Not even a good boat anchor
Living on a wing and a weld
Re: A life of vice.
Reply #6 on:
November 29, 2017, 11:35:00 PM »
Definitely not pretty but hey ,who gives a
if it works..cool
Re: A life of vice.
Reply #7 on:
November 30, 2017, 05:22:19 AM »
Well as a vice it works fine, but I wont try to press any bearing with it.
Had difficulties (read never found) the right setting for the rods. It was always either too low an amperage to sustain a good arc or turn it up till it would arc nicely and the rod would quickly overheat over it's entire length.
Re: A life of vice.
Reply #8 on:
November 30, 2017, 02:42:36 PM »
Quote from: Olds on November 28, 2017, 10:01:21 PM
Where did you buy the new one from and if you don't mind how much was it ?? As when I went back to collect my stuff some body had nicked my vice
Re: A life of vice.
Reply #9 on:
November 30, 2017, 05:07:59 PM »
I bought it from Sitebox. £80.59 inc. delivery.
