December 12, 2025, 01:00:46 AM *
Author Topic: battery charger  (Read 4605 times)
« on: September 04, 2016, 07:13:55 AM »
I'm after a Battery charger that I can leave connected for long periods.
something that will condition and keep the battery in tip top condition.
ive done all the usual internet searches and come up with loads lol
can you guys recommend any ?
thanks mick
ps its for a car battery on my trike
pps lead acid battery
Mousy Boy :-) AKA Mick Smiley
Stix
« Reply #1 on: September 04, 2016, 07:55:19 AM »
Optimiser I think it is called, only a trickle charger but will cut off when battery is full and they come with leads to fix to the battery if it is in a hard to get to place so you can just plug in without removing panels to get to battery.
Stix
Might be an Optimate.
« Last Edit: September 04, 2016, 08:45:05 AM by Stix » Logged
« Reply #2 on: September 04, 2016, 08:15:19 AM »
Yup, not used one myself but know several people who've used those. Not heard any bad reports on them.
« Reply #3 on: September 04, 2016, 09:03:52 AM »
There's some opinions on this thread
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=14482.0
My personal view (having had Optimates) is the BC (Battery Controller)  http://www.batterycontroller.co.uk/index.php
« Reply #4 on: September 04, 2016, 10:12:44 AM »
Thanks Tony
ive found this one
http://www.wemoto.com/parts/picture/bf-706debcbp-eu/
 thanks for the help guys
« Reply #5 on: September 04, 2016, 09:46:35 PM »
Optimates, Optimisers, Optimax - you're just paying for the name.  Mine's just called a battery charger but I haven't had to buy a new battery for the trike since I had this charger, plugged in all the time, different coloured lights show what it's doing.  No idea what it's called, had it for years!
digger06
« Reply #6 on: September 10, 2016, 03:54:41 PM »
I have heard a few inc myself,
they can mask faults when left over winter,
my kawi battery was showing ok on the optimiser and started the bike, ,,
however when I tried again it was flat, good job I didn't set off anywhere,  Angry
tried it again, after an hour the optimiser said ok, yet after 1 start it was nearly flat again,
I have heard this a few times through friends and the internet,
theres cheaper unbranded chargers that do the same trick, great if you cant get to the battery easy, or cant be arsed in winter, but check the battery over properly before using...
i just use a normal charger now, and do it the old tried and trusted way , (remove battery, keep warm, discharge and recharge every few months)always seems to work,,,
i noticed the optimate doesn't like moped size batterys often either, just sits there with the lights flashing....my mates does the same
« Last Edit: September 10, 2016, 03:58:54 PM by digger06 » Logged
« Reply #7 on: September 10, 2016, 05:04:43 PM »
Had similar happenings with that brand, am now using the BC (Battery Controller) make, and so far, so good.......... plus it also brought a battery back to life that was irretrievable with the other brand.
