April 17, 2026, 06:20:31 PM *
Author Topic: Trike builder wanted  (Read 10442 times)
« on: March 12, 2016, 02:03:20 AM »
Does anyone know of a trike builder or engineer not too far from me (Dorset)?  Bruce at BB Customs says my diff's on its way out so my trike needs a new (Reliant) axle but he's too busy to do it.
Someone has recommended a firm called ZaNNetec at Shepton Mallet but I don't know whether they would do a trike - anyone know them?
« Reply #1 on: March 12, 2016, 08:08:33 AM »
My brother runs a welding/fabrication business in Marlborough, Wiltshire. He specialises in building drag race cars, but has recently hardtailed a customer's bike, raked the headstock on mine & is building a new trike frame for Hillbilly. He's not the cheapest but he's damn good at what he does.
Check the Field Craft Fabrication page on Face Book.
« Reply #2 on: March 12, 2016, 10:04:26 AM »
What do you want BG a new diff or complete axle? as your one has been cut down
« Reply #3 on: March 12, 2016, 10:40:31 AM »
Now there's a thought!
« Reply #4 on: March 12, 2016, 01:36:13 PM »
Well there's the question Terry - the answer is, I don't know!  Bruce said it needs a new axle, and I remember Fifer saying that setting up a Reliant diff is a black art (words to that effect), also I believe there a part (possibly a seal?) that's not available.    There's also the problem of obtaining an axle.  And I have no idea which would be easier/quicker/cheaper - dismantling and rebuilding the diff, or shortening an axle.I think I probably want to take it to a professional who can advise me, or tell me which they would prefer to do.
And, I know Bruce is the expert, and he says it's the diff, but I have a niggling doubt.  I've only ever once experienced diff problems, with my first car, an Anglia - well a Pop but it was a smart one called an Anglia, and it was a grinding noise whereas this sounds like a rubbing noise - but maybe it just hasn't got as far as the grinding stage!
But could it be failure of the weld on the shortened half-shaft?
« Reply #5 on: March 12, 2016, 02:00:06 PM »
The place I've been recommended at Shep says on the website that they do 'Chassis, V8 Engine, Transmission, Custom Wiring' so I've emailed them but the website seems to be a bit out of date - unless of course they're too busy doing actuall stuff to update it.
« Reply #6 on: March 12, 2016, 02:23:27 PM »
Bg, you don't need a trike builder, you need a reliant axle expert. fifer is right, these axles are simple, but almost impossible to set up correctly without the right tools, and even then these are no good if your axle has been shortened. You see the problem is you measure the settings with rods from the wheel ends, you cant get inside them to check/measure without splitting them, and once you've split it.... I reckon most modified axles, if they've had new diff bearings will be nowhere near correctly set up, but on a trike, they seem to take it.(Except the one on mine of course which was totally worn out).
When i did mine it was a case of build, strip, remove shims, build, mark, strip, etcetc, and then best guess its Ok.
Having said all this, its only an axle, and your not after shortening it again or anything, so you need a reliant diff expert
« Reply #7 on: March 12, 2016, 02:41:32 PM »
Thanks - where do I fine one of those?  Sounds even more unlikely than a trike builder!
The Shepton Mallet People rebuild and set up diffs - doubt they've ever done a Reliant though.
fifer
« Reply #8 on: March 12, 2016, 05:55:25 PM »
Download the instructions from the following link and show / send them to an axle rebuilder to see if they can do it .
The Reliant axle is very forgiving and has been stripped and put together by many folk who did not bother or know about any set up .
These axles have run for many miles but probably best to get it done professionally .
http://s7.photobucket.com/user/sparesman2000/library/parts%20manuals/Axle%20Refurb?sort=3&page=1
« Reply #9 on: March 12, 2016, 07:24:54 PM »
Hi BG you say a rubbing noise!  This went into BBs for the wheel bearing not to long back I'm wondering if the bearing and collar weren't put back on right. to far on it will hold the drum off the back plate not on far enough the hub and drum may rub the shoes or back plate.
some where on here was the measurements for the setting of the collar and bearing from the spine on the shaft I think it was for Triker Pete. I doubt that the weld on the your shaft is the problem
« Reply #10 on: March 12, 2016, 08:03:28 PM »
It was when it went in for the wheel bearing that Bruce said the axle was shot.  Bloke in Shepton says if I can get the axle out and take it to him he may be able to do it so I shall look into that - my son in law may be able to help when he gets over the flu thing he currently has.  It poses a few problems but would solve a lot more, if it was done that way, as I could take the axle over in my car.
I've told him (Zane at Shep) that I'm not 100% sure it's the diff, and I've downloaded the info the Fifer sent a link to.  Zane has recently built a trike with a Reliant axle, and rebuilt the diff.
« Reply #11 on: March 12, 2016, 08:05:15 PM »
I'm really grateful for all the input from folks on here!
« Reply #12 on: March 12, 2016, 09:29:56 PM »
Wish i was closer, would be simple to open it up for a look, at least that is simple and straight forward. It wouldnt take someone who knows these more than 1/2 hour to identify the problem (once its out of the trike of course).
« Reply #13 on: March 13, 2016, 08:28:24 AM »
Had an email from my brother last night Bobbi. He says Zane in Shepton Mallet's definitely the guy to go to -he takes his own drag racing axles there.
« Reply #14 on: March 13, 2016, 10:57:31 AM »
Cheers Andy - I did message him on FB but he hasn't seen it.  Sounds like my best option then is to get the axle out - I'll have a look at that in the next few days, at present we're trying to clear the house as we have decorators coming in!
Thank Steve for me please!
