March 15, 2026, 10:52:25 PM *
Pages: 1 [2]
Author Topic: Propshaft length.  (Read 20710 times)
« Reply #15 on: October 06, 2015, 08:37:02 AM »
You were a propshaft salesman?! How does that work then Kev? Did you go door to door or is there some sort of mail order catalogue?
Just be grateful for Sercks liking to train their sales guys well ! One of my other specialist products was braking Wink
« Reply #16 on: October 06, 2015, 08:50:40 AM »
What about the other end.
The other end would be easier but then it would definitely have to be re balanced. Still sticking with the 'if I can't do it at home, then it don't get done' rule of building.
Think I'm just going to go for it at the diff end and see what happens. Smiley With a bit of luck there may be enough spigot left to hold on the chuck.
« Reply #17 on: October 06, 2015, 09:15:23 AM »
« Reply #18 on: October 06, 2015, 11:29:34 AM »
No such luck. Not enough spigot to grip so some slightly iffy use of the 4 jaw chuck and a running centre.
Last cut and it's a light press fit, into the tube. Grin
Damn I hate machining welds. Even tungsten carbide tips go blunt and they are not cheap.
« Last Edit: October 06, 2015, 11:33:20 AM by Olds » Logged
Mendalot
« Reply #19 on: October 06, 2015, 11:39:57 AM »
Where there's a will ......... even if its iffy ....... there's a way Grin Grin
« Reply #20 on: October 06, 2015, 12:27:08 PM »
Is this what you mean Kev ?  Wink
OK so the light press fit turned out to be a slightly heavy press fit. Think i will assemble it all with the old spider just to check all is fine before welding.
« Reply #21 on: October 06, 2015, 03:00:51 PM »
Tried it on the car and it fits with clearance, so welded it up. Not my best welding to date, but it's good and strong.
Thanks for all comments and suggestions folks.
« Reply #22 on: October 06, 2015, 07:04:17 PM »
Slightly off track, I'm putting together a project and the gearbox end is a doughnut, rotoflex? coupling. So that cannot slide in and out, so how do I manage?? There was a fixed diff but this car has a live axle, working with a jack and stands it doesn't seem to alter in length much. Have I boobed??
« Reply #23 on: October 06, 2015, 08:11:32 PM »
As far as I know, rotoflex are used where there is little or no linear deflection. Such as certain drive shafts or between gearbox and a fixed diff where the only deflection is caused by by the likes of changes in temperature or vibration.
Might be worth checking that the prop is not limiting the axle movement both in loaded (bump stops) and unloaded (wheels off the ground) conditions.
« Reply #24 on: October 06, 2015, 08:35:37 PM »
Looks good to me.
« Reply #25 on: October 06, 2015, 08:46:09 PM »
Proper job Dave, she'll be right! and if a tremor be detected, then the old "Jubillee" trick will cure it I'm sure! Wink..Morrag
« Reply #26 on: October 06, 2015, 09:10:35 PM »
When  using the rotoflex coupling and movement is normally a slide joint in the middle of a 2 piece prop . Rotoflex should have NO misalignment as it will eat it in very short order.
« Reply #27 on: October 07, 2015, 02:06:32 PM »
many thanks for the pointers. This morning, I went and investigated the prop shaft and at the centre bearing there is indeed a slide fitting, trouble was it was siezed. Big fire axe and a trusty hammer soon freed it up, now have it soaking in special brew to keep it free. Any idea how much it should be engaged? Cannot see a rub mark.
« Reply #28 on: October 07, 2015, 06:08:00 PM »
I did one for a mates kit car, exactly the way your doing it, then fitted it to the car, with a dti. Turned  the prop, tapping to eliminate throw, tacked it,  then took it off to weld. It was spot on, even though i say so myself. For balancing a jubilee clip to find where to tack a weight on will do.
Diy city Smiley
Pages: 1 [2]
