April 04, 2026, 05:09:02 AM
General Tech
Metal spinning
Topic: Metal spinning (Read 4652 times)
Metal spinning
June 19, 2015, 11:31:19 AM »
Had a quick go at metal spinning using the Myford.
Results were ok until the centre of the work piece broke out. May have too much pressure on this area.
Has anyone else tried this ( with success ), if so any tips or help would be most welcome.
Re: Metal spinning
June 19, 2015, 01:17:44 PM »
I've got to be honest,I've never herd of it before.
But it looks like a pleasurable thing to do.
https://www.youtube.com/watch?v=FHvtieU4-7Y
andbolt0
Re: Metal spinning
June 19, 2015, 02:15:47 PM »
if you are using aluminium it should be anneald first as the forming work hardens it and it becomes brittle depending on how much shape you putin it may need to be anneald more than once
markju
Re: Metal spinning
June 19, 2015, 02:29:48 PM »
Quote from: hunter on June 19, 2015, 01:17:44 PM
I'd never heard of it either. Very clever that.
You can certainly learn some things on this ere forum.
Re: Metal spinning
June 19, 2015, 02:47:07 PM »
Known as Turkish work down 'ere in the west country.
Sid_Vicious
Re: Metal spinning
June 19, 2015, 02:55:54 PM »
Take a look on this guys work, I don't remember which one link there is metalspinning in but they are both good.
http://www.alloyavenue.com/vb/showthread.php?9080-Other-stuff-related-to-a-motorcycle-restoration
http://www.alloyavenue.com/vb/showthread.php?8389-Metal-press-work&highlight=metal+press+work
Edit: Sorry I remembered wrong Jami used a press to make the cone shape before he took the finishing in the lathe in the last link.
Last Edit: June 19, 2015, 03:01:38 PM by Sid_Vicious
