December 12, 2025, 12:59:32 AM *
Pages: 1 ... 28 29 [30] 31 32 ... 52
Author Topic: "Old Dorg"  (Read 386418 times)
« Reply #435 on: April 06, 2017, 06:05:45 AM »
I'd leave it like that -I like that!
strange you say that andy, the more i look at it i'm thinking the same!!!!! plus it runs, drives, stops etc, just not been mot'ed since 2012!!!
« Reply #436 on: April 06, 2017, 05:42:22 PM »
well the strip down has started,
removed steering column, brake and clutch pedals which look ideal to swap straight over.
speedo, switches etc.
wiper motor and linkages.
anything i can remove that could be useful is being removed.
luckily there's no airbag, but plenty of electricals!!!
some how it runs and drives ok with the immobiliser ecu removed!!!! no idea how.
managed to find a diagram to show where the ten bolts are that hold body on.
hope to get it removed by next week end.
« Reply #437 on: April 06, 2017, 08:35:55 PM »
So what engine does that have then Chris?
« Reply #438 on: April 07, 2017, 04:22:55 AM »
2litre, 8v nothing crazy.
« Reply #439 on: April 11, 2017, 06:53:08 PM »
still stripping, my god theres some crap in modern vehicles.
dashborad area, erm its gone!!!!!!
http://imagehosting.rodsnsods.co.uk/558ed2185747b6.jpg
"Old Dorg"
the body is very solid, thought for a while it was to good to strip down.
http://media6000.dropshots.com/photos/1101204/20170411/r90_x_190532.jpg
"Old Dorg"
trying to use as much of donor as possible, pedals, along with braking system will all be used.
http://media6000.dropshots.com/photos/1101204/20170411/r90_x_190658.jpg
"Old Dorg"
going to try to use steering column complete, even removed mounting bar,plates etc.
http://media6000.dropshots.com/photos/1101204/20170411/r90_x_190726.jpg
"Old Dorg"
been told this bit is very important!!!!
http://media6000.dropshots.com/photos/1101204/20170411/x_190745.jpg
"Old Dorg"
these will be have to be cut of as siezed solid. only 10 to find!!!!!
http://imagehosting.rodsnsods.co.uk/558ed218812bd5.jpg
"Old Dorg"
got to finish removing wiring loom, drain, remove radiator then a few odds and sods, should then be lift off!!!!
« Last Edit: April 11, 2017, 06:54:59 PM by poprodder » Logged
« Reply #440 on: April 14, 2017, 06:18:53 PM »
so 7 chassis bolts removed, 4 cut off, 3 removed at rear, fighting with a stubborn one that i think will shear off.
just got front bumper to remove then last 2 bolts. radiator etc,
then last few bits of wiring along with rear seat belts.
should then be body off.
« Reply #441 on: April 14, 2017, 06:55:00 PM »
Oh my Gawd! He's done it again!  Cheesy
« Reply #442 on: April 20, 2017, 04:49:11 PM »
body still on, as suffering with trapped nerve in shoulder also don't help that i load vans at work.
i've got a 6inche drop just from wheel and tyre change(mostly tyres!!!) 9 1/2 inches stock, will come down to 3 1/2" ish soon. could be  a little higher due to less body weight. torson bars at front so can easily raise(or lower!!!) it an inche if required.
« Reply #443 on: April 20, 2017, 08:43:54 PM »
Get well soon matey -so we can follow your progress.  Wink
« Reply #444 on: April 24, 2017, 04:57:48 PM »
still no work done, got sent home from work early today. been to docs this afternoon.
muscle and nerve damage, been told to take a few days of work.
put on diazepam, said it will take at least ten days to start to feel better.
« Reply #445 on: April 24, 2017, 07:34:07 PM »
Bugger.
« Reply #446 on: April 24, 2017, 08:20:14 PM »
just abit, been told i MUST rest.
« Reply #447 on: April 26, 2017, 10:34:47 PM »
http://www.ebay.co.uk/itm/Pre-order-All-metal-All-new-1930-Ford-Pickup-Truck-Roadster-Pickup-Hot-Rod-Body-/361946372621?roken=cUgayN
3 1/2 grand, but a bunch of handy reference photos for you there Chris.
« Reply #448 on: April 27, 2017, 07:35:38 AM »
thats handy andy!!!!!(  Roll Eyes )   Cheesy
will give it alook. cheers.
« Reply #449 on: April 27, 2017, 01:45:39 PM »
back to docs tomorrow, in left shoulder as well now.  Sad
