May 04, 2026, 11:53:16 AM *
Author Topic: Dumb question number 1  (Read 8631 times)
« on: March 06, 2015, 12:37:30 PM »
Is there any tricks to changing handle bar rubbers I should know about ,like what lube if any to use ?
« Reply #1 on: March 06, 2015, 12:39:03 PM »
KY jelly springs to mind when ,lube, is mentioned  Roll Eyes Roll Eyes Wink
« Reply #2 on: March 06, 2015, 12:40:27 PM »
By rubbers do we mean grips,
If so i use petrol.But not twostroke.
« Last Edit: March 06, 2015, 12:42:53 PM by hunter » Logged
Sid_Vicious
« Reply #3 on: March 06, 2015, 12:43:20 PM »
Compressed air between the rubber and the bars.
« Reply #4 on: March 06, 2015, 01:05:56 PM »
Women's hair spray -lubricates when wet, then sets like a glue. Makes your bike smell nice too Smiley
Stix
« Reply #5 on: March 06, 2015, 02:29:24 PM »
A long thin screwdriver push it in from the open end once in raise it up a bit and squirt some wd40 or duck oil in there and give them a good twist, make sure to clean them out if you are going to re-use them.
Stix
« Reply #6 on: March 06, 2015, 05:52:53 PM »
Cheers all. Do they go back on dry ?
Sid_Vicious
« Reply #7 on: March 06, 2015, 06:03:36 PM »
With air they usually do.
Stix
« Reply #8 on: March 06, 2015, 06:04:05 PM »
Little bit of glue but don't overdo it.Upholstery glue will do it and give you time to get them on properly.
Stix
« Reply #9 on: March 06, 2015, 06:47:59 PM »
And how did you find that out  Smiley
« Reply #10 on: March 06, 2015, 07:32:22 PM »
 Smiley Old trick passed on to me by an ageing biker when I was a teenager after I found a can of hairspray in his toolbox.  Tongue
Dslam
« Reply #11 on: March 06, 2015, 07:52:12 PM »
Hairspray works. I have no hair to speak of but luckily Mrs Dslam still has some but rough up a small area for it to grip to as shiny chrome is not the best surface.
I just read that back. I didn't mean rough up mrs Dslam. Oh poo you know what I mean. Wink
« Reply #12 on: March 06, 2015, 08:39:10 PM »
I've met Mrs Dslam & I wouldn't dare!
lunatic
« Reply #13 on: March 07, 2015, 10:26:03 AM »
I've always used hairspray since my old bmx days. Slide a thin screwdriver down the grip, lil squirt of hairspray,twist the grip an off it comes!
trev
« Reply #14 on: March 08, 2015, 12:21:00 PM »
I use soapy water to put grips on,works a treat and doesn,t harm the rubber.
