April 17, 2026, 10:59:36 PM *
Pages: 1 ... 61 62 [63] 64 65 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 588181 times)
« Reply #930 on: March 29, 2016, 02:29:30 PM »
Thanks. Machining finished just need to braze on the threaded collar. It's made of one piece of steel but I did cheat. It started off life as an MGB splined front wheel hub.
I plan on copper plating it to protect against corrosion.
« Last Edit: March 29, 2016, 02:34:52 PM by Olds » Logged
« Reply #931 on: March 29, 2016, 07:56:33 PM »
With some trepidation, crossed fingers, and a lots of measuring, I cut the hole in the boat tail for the filler to come through, with enough clearance to allow the rear section to hinge up.
Need to make a neat panel reinforcement, to be riveted around the hole.
« Reply #932 on: March 29, 2016, 08:16:23 PM »
 Smiley
« Reply #933 on: March 30, 2016, 07:12:02 PM »
Ok, so the copper plating didn't go quite as I planned. Actually it went far better by accident.
I made my own plating solution by leeching a pile of brass swarf, in a 9.5% solution of Ammonium Hydroxide (household ammonia). This was added to water, then Acetic acid (vinegar) added. With a ring of copper wire around inside of the bucket and using a 6v battery charger all seemed fine. It started to go a nice copper colour then started going yellow. At first I thought the plate was failing but it turns out that the plate is fine just has a colour between brass and nickle.
The inside that has less coating is still copper in colour. Seems you cant extract just the copper from the brass.
« Last Edit: March 31, 2016, 07:37:18 AM by Olds » Logged
« Reply #934 on: March 30, 2016, 07:49:49 PM »
looks great, but everything you wrote just wizzed above me head!!!! lol
« Reply #935 on: March 30, 2016, 08:14:14 PM »
 Smiley
This part wont be seen so there was no point in polishing before plating. It's just an anti corrosion coating, but I will try to recreate the plating solution as it's a really nice colour. Sort of vintage nickle.
« Last Edit: March 31, 2016, 07:30:23 AM by Olds » Logged
« Reply #936 on: March 30, 2016, 09:35:45 PM »
The man's an alchemist!
No Sound
« Reply #937 on: March 30, 2016, 10:37:04 PM »
Nice work  Smiley
« Reply #938 on: March 31, 2016, 02:39:11 PM »
 Smiley Last part of filler arangement sorted. Hole reinforcement. Think I may use brass or copper rivets for contrast.
Hardest part was getting the 4mm thick aluminium to follow the curve of the bodywork.
« Last Edit: March 31, 2016, 02:42:56 PM by Olds » Logged
Mendalot
« Reply #939 on: March 31, 2016, 03:31:38 PM »
Unique, as usual Dave it looks bloody marvelous.
« Reply #940 on: April 05, 2016, 07:56:40 PM »
Thanks Paul.
Fed up of estimating the seating position, using bits of foam and old pillows, I decided that it's about time to start making some seats.
Idea is for a one piece backrest and individual squabs, similar to the Morgan 3 set up. Due to the restricted height of the seat belts, the seat squabs are going to be fairly thin and mounted direct to the floor.
Will probably do a temporary upholstery job until the car is nearer completion.
« Reply #941 on: April 05, 2016, 08:00:29 PM »
Have a look at the seat belts we do on the website and if any suit let me know and I'll sort a better price on them.
« Reply #942 on: April 05, 2016, 08:11:03 PM »
What's the web address Archie?
« Reply #943 on: April 05, 2016, 08:13:48 PM »
Have ordered a set but always willing to look again (if I knew where to look) Cheesy
« Reply #944 on: April 05, 2016, 11:00:11 PM »
Something like this then Dave................
