May 04, 2026, 08:13:37 PM
Bike Tech
HELP...(yes , I know AGAIN)
Topic: HELP...(yes , I know AGAIN) (Read 5050 times)
Firery Fred
July 03, 2014, 07:46:14 PM »
Petrol tank "sealed" , painted and fitted and NOW it decides to leak. Can't afford to get it repainted and it's weeping from where the tap boss ued to be ( tig welded). Can't put another seal on top , is there anything that could be used outside that wouldn't involve heat?. It's a sportster type tank and underneath so almost out of sight. I know it's not the right thing to do but I just can't lose another summer/year without a bike
Re: HELP...(yes , I know AGAIN)
July 03, 2014, 08:28:31 PM »
Old fashioned bar of soap ! Coal tar or something basic like that ,it will react with the fuel and expand to seal the leak.
July 03, 2014, 08:36:56 PM »
Here is something I have done and it worked for me.
Remove and empty tank. Remove all paint around the leak and clean with thinners. Seal the filler cap ( rubber glove works well) and any vents.
Apply cyanoacrylate (super glue) to the leak area. Lower the air pressure in the tank and leave like this for a few minutes. This should pull the glue into any porous areas. Wipe off all excess and seal with a coat of epoxy glue.
July 03, 2014, 09:40:34 PM »
How do you lower the air pressure Dave?
July 03, 2014, 10:33:49 PM »
Suck it and see..............
fifer
July 03, 2014, 10:42:16 PM »
Quote from: Manky Monkey on July 03, 2014, 09:40:34 PM
Take it from the top and transfer it to the bottom ; it will then be lowered
Reply #6 on:
July 04, 2014, 12:50:48 AM »
This is where I
should
say use a vacuum pump (or converted bicycle pump) attached to the fuel tap. What I should not say is "suck it and see"
Last Edit: July 04, 2014, 06:17:58 AM by Olds
Firery Fred
Reply #7 on:
July 20, 2014, 07:33:52 AM »
Had petrol in tank for a couple of days(on the bench)now and seems to be fixed
So THANK YOU to one and all
