March 18, 2026, 03:42:54 PM *
Author Topic: wireing help needed  (Read 3684 times)
sprocky
« on: January 25, 2014, 04:05:20 PM »
Hi guys not bin about for a bit bin building my v6 trike Engine is a 2.9i v6 on a autobox from a scorpio Engine was built in 1989 the pre cat one bounus. Have not got a rear end yet as ive ran out of money so guna start to sort out ellectrics. It came with wireingloom /and the ecu but no fuse box .is it a case of trceing all wires  that run between ignition/ecu/ect . I can by a 5 way or 10 way fusebox frome my local auto ellectrion so is it just a case of feeding a live to it  and http://i933.photobucket.com/albums/ad179/plockhead1/Mobile%20Uploads/2014-01/20140122_164428_zpsowsrnjgw.jpg
wireing help needed
fead out of it eg lights /horn ect ect any help would be gratefull sprocky
b free on three
« Reply #1 on: January 25, 2014, 08:07:55 PM »
The  ECU and gearbox wiring breaks down into a seperate loom that needs only 3 ( pretty sure it's only 3) that make it all run and work. Does your gearbox have a manual speedo output or an electronic one ? What's the model number on the box as there are 3 variants requiring slightly different relays. Did you get the bunch of relays from up behind the Granada dash as well ?
« Reply #2 on: January 26, 2014, 09:09:47 AM »
http://www.fordscorpio.co.uk/12vlooms.htm
sprocky
« Reply #3 on: January 28, 2014, 07:32:39 PM »
 Grin many thanks for you time kapri bin told the gearbox is A4LD yes it is ellectric.also bin on internet to try getsom info as far as I can tell my ecu as I call it turns out its clased as a pcm with only 60 pin conections put a nother pic up of relays I do have the blue one is kickdown control there is a yellow relay and a red relay don't no wat they are there is allso a purple conecter with a fuse in it don't no what this is either once again many thanks for your time and help http://i933.photobucket.com/albums/ad179/plockhead1/Mobile%20Uploads/2014-01/20140127_174017_zpsipb4p4e_edit_1390849933609_zpsmr1sqbq_edit_1390936171333_zpsjndmkinr.jpg
wireing help needed
b free on three
sprocky
« Reply #4 on: January 28, 2014, 07:35:57 PM »
 Grin gearbox http://i933.photobucket.com/albums/ad179/plockhead1/Mobile%20Uploads/2014-01/20131206_164722_zpsf6d7154_edit_1390933584655_zpsxfa69tap.jpg
wireing help needed
b free on three
sprocky
« Reply #5 on: January 28, 2014, 07:43:04 PM »
   Grin many thanks old newb got some info pcm mainly nice one
b free on three
« Reply #6 on: January 28, 2014, 08:50:30 PM »
Can't remember the colours but you have a main relay and then a fuel pump relay fed from that . The blue relay is the kickdown timer relay , at .5 secs it's turns from 'pull' to 'hold to take the current load down.
Hopefully you've also got a relay on a lonish vacuum pipe connector with 2 wires to it ? That switches your overdrive on and off  when vacuum requires it.
sprocky
« Reply #7 on: January 28, 2014, 10:39:25 PM »
Thanks kapri will have look tomorro for another relay but think I've only got these three canot get my head rond hayns manul .would when ready will ibe able to run engine with just these .as I no I can by a simple fusebox for lights ect
b free on three
sprocky
« Reply #8 on: January 29, 2014, 04:47:42 PM »
 Grin hi kapri mate is this the vacume pipe you mentchand ? http://i933.photobucket.com/albums/ad179/plockhead1/Mobile%20Uploads/2014-01/20140129_154301_zps1m8fsrk1.jpg
wireing help needed
b free on three
sprocky
« Reply #9 on: January 29, 2014, 04:55:15 PM »
 Grin have also taken pic of my ecu if that helps your good self http://i933.photobucket.com/albums/ad179/plockhead1/Mobile%20Uploads/2014-01/20140129_155529_zpsdot7deu5.jpg
wireing help needed
help me as I an'tgot a clue   Huh My friend
« Last Edit: January 29, 2014, 05:16:48 PM by sprocky » Logged
b free on three
