December 18, 2025, 05:41:29 PM *
Author Topic: xvs rear tyre  (Read 7444 times)
« on: December 04, 2013, 10:37:05 AM »
After a recent mishap I realised that my rear tyre was well past it's best. With quotes for a new one ranging from £125 to £140 I managed to find one on fleabay for £79 including postage. Ordered it late Saturday evening and it arrived early on Tuesday morning Shocked
Having problems with my wrist at the moment so I may just pull the wheel out and have someone else fit the tyre. I remember having a bit of a struggle with the Harley rear.
(Do you think they noticed the product placement Andy  Wink)
« Last Edit: December 04, 2013, 02:26:43 PM by Old Newbie » Logged
« Reply #1 on: December 04, 2013, 08:41:18 PM »
Very subtle Dave  Wink
You didn't make Heather the Post Lady lug that up your drive did you?!
Baychimp
« Reply #2 on: December 04, 2013, 08:45:48 PM »
its alright if he did.   The exercise will do her good. Grin Grin
« Reply #3 on: December 04, 2013, 09:15:11 PM »
I'm gonna tell her you said that Bob!
Baychimp
« Reply #4 on: December 06, 2013, 11:24:38 PM »
Go on then you tell her I'm not scared! (I think,Mebbe).  Snitch!
stumpy
« Reply #5 on: December 07, 2013, 11:20:56 AM »
i take it you put that on the trikes front wheel i been looking into a bike rear tyre on front but my tyre man says the rotation ought to be running backwards ? is that what you do quoted 90 pounds for a 140x70x17 fitted thought was reasonable for a mitchellin
stumpy
« Reply #6 on: December 07, 2013, 11:23:46 AM »
but from memory you have a bike too ? so maybe nothing to do with trike ... but never the less any views on bike rear tyre on front of trike with rotation reversed
« Reply #7 on: December 07, 2013, 11:42:38 AM »
I've had a good motorcycle tyre on the front of my trike, and an economical 'don't care as long as it's black and round'.  Never noticed any difference!
« Reply #8 on: December 07, 2013, 11:51:37 AM »
It's for a bike. I have no experience of fitting a bike rear tyre on the front of a trike, so have not given the rotation issue any thought. For my trike I fitted a 19" car tyre.I believe rear tyres with a directional bias, not only have bias as far as loading goes, (hence the idea of reversing the direction if used on the front), but also in the way they direct water away from the contact patch. It is possible that running the tyre in the wrong direction, could actually cause water to be forced under the contact patch.
Bridgestone do 17" fronts up to 150/80 so might be worth having a look around to see what others do.
« Last Edit: December 07, 2013, 12:01:58 PM by Old Newbie » Logged
« Reply #9 on: December 07, 2013, 12:49:03 PM »
It's actualy an MOT fail,Having a tyre fitted with directional arrows facing the wrong way.
« Reply #10 on: December 07, 2013, 02:47:18 PM »
Avon Roadrider AM26 is available in 140/80x17 which fits front or rear at about £100.
« Reply #11 on: December 19, 2013, 03:59:34 PM »
Had a few problems getting the old tyre off the rim today. Just could not break the bead  Angry Tried for over a hour. Ended up having to knock up a lever type bead breaker out of old square section tube. Then it was no problem at all.  Cheesy Might make a proper one for future use.
« Reply #12 on: December 19, 2013, 04:28:24 PM »
I made one up of a similar style that "levers" against the lower steel tube cross-rail of my work bench. Portable, and works a treat Dave!!  Morrag
« Reply #13 on: December 22, 2013, 11:59:37 AM »
Fitting the tyre was not too much of a problem, but refitting the wheel turned into one of those, 5 minute jobs that take ages.
Due to not having a bike lift, the back of the bike was a fair way off the ground, with car axle stands each side,under the frame. This meant that the wheel, assembled with brake and drive unit had to be lifted up into the axle slots while keeping the drive shaft aligned, the brake rod out of the way and the wheel alignment spacer in it's place. All hampered by the saddlebags (that take forever to remove so I hadn't).
After a lot of cussing, it was loosely bolted in place, but while taking a breather before torqueing it all up, I noticed a nice clean shiny tube in the corner of the garage. Things in the corners or my garage, are rarely clean and never shiny and it took a while for my brain to go from 'I wonder where that came from,' to 'D'oh! I know exactly where that came from #####'
Yep you guessed it. The internal spacer  Angry Start again. Roll Eyes
« Last Edit: December 22, 2013, 01:07:52 PM by Old Newbie » Logged
digger06
« Reply #14 on: December 22, 2013, 02:49:25 PM »
yup, and as old newby says, it fecks water dispersal up,
fit as per rotation arrows...
 as for bead splitting when tyre changing,if a splitter isnt handy, i use a trench shovel,
never fails,
lay the wheel on the ground , put it as near to the rim as poss, and jump on it,
straight off.....
« Last Edit: December 22, 2013, 02:54:31 PM by digger06 » Logged
