April 23, 2026, 01:42:55 AM *
Author Topic: Radiator fan switch  (Read 2886 times)
fORGOTTEN
« on: November 16, 2013, 02:05:11 PM »
Got a 4.3 v6 chevy. Wanna wire a radiator fan in but not sore what temp fan switch to get.
Will that pass S.V.A?
« Reply #1 on: November 16, 2013, 03:55:21 PM »
Where are youplanning on fitting the switch, top or bottom tank/hose ?
fORGOTTEN
« Reply #2 on: November 16, 2013, 04:15:47 PM »
Probably top hose.
« Reply #3 on: November 16, 2013, 04:57:18 PM »
In many ways the adjustable ones are the easiest to fit and allows you to set the temp to suit and cost about £25 from CBS.
I think the running temp of the 4.3 v6 is about 200 to 210 F so I guess a fixed switch of, on 100 off 95 C (212-203F) should be about right.
Check what the recommended running temp is.
fORGOTTEN
« Reply #4 on: November 16, 2013, 05:08:06 PM »
O right cool. Yeah trying to find out what the recommended running temp is.
fORGOTTEN
« Reply #5 on: November 16, 2013, 08:55:11 PM »
Soooooo apparently 180 to 200 degrees is the running temp. Well so some forum said.
« Reply #6 on: November 16, 2013, 09:43:06 PM »
I can never remember it overheating when it was on the road
fORGOTTEN
« Reply #7 on: November 16, 2013, 10:51:00 PM »
Na arch just gonna put a auto fan switch in to do away with the manual one in the cab
