March 12, 2026, 02:03:12 AM *
Author Topic: Chichester College Classic Car Show Sussex  (Read 8022 times)
Chevy Rick
« on: September 23, 2013, 08:58:34 PM »
22.9.2013
http://i.imgur.com/FdIeyY8.jpg
Daimler 2.5, the first two door ragtop I have ever seen.
http://i.imgur.com/XCN04t2.jpg
http://i.imgur.com/sf3h5R7.jpg
http://i.imgur.com/p5WxQnD.jpg
http://i.imgur.com/nwuD5g7.jpg
http://i.imgur.com/CSVSKdV.jpg
http://i.imgur.com/8yjJ4M4.jpg
http://i.imgur.com/r3jETWi.jpg
http://i.imgur.com/rowiYwc.jpg
http://i.imgur.com/yPoemJp.jpg
http://i.imgur.com/qwgc9w7.jpg
http://i.imgur.com/5lGLZie.jpg
http://i.imgur.com/aq0r5Bw.jpg
http://i.imgur.com/XjNjv9g.jpg
http://i.imgur.com/WK4pCAs.jpg
« Last Edit: September 23, 2013, 09:02:43 PM by Chevy Rick » Logged
Chevy Rick
« Reply #1 on: September 23, 2013, 08:59:17 PM »
http://i.imgur.com/JJG9Yqr.jpg
http://i.imgur.com/qSGRrt2.jpg
http://i.imgur.com/L3DkJER.jpg
http://i.imgur.com/q96071h.jpg
http://i.imgur.com/O1Cw2Om.jpg
http://i.imgur.com/6jdIU0k.jpg
http://i.imgur.com/jbmVEPB.jpg
http://i.imgur.com/BHDucbc.jpg
http://i.imgur.com/IpLxJ2y.jpg
http://i.imgur.com/LYzfV19.jpg
http://i.imgur.com/fK7l13C.jpg
http://i.imgur.com/SS50aDp.jpg
http://i.imgur.com/aYLAE4L.jpg
http://i.imgur.com/1ivPLXL.jpg
http://i.imgur.com/kvqbUY0.jpg
« Reply #2 on: September 24, 2013, 07:54:10 AM »
Nice turnout Rick. Looks like a good show.
« Reply #3 on: September 24, 2013, 08:57:58 AM »
The convertble Jag looks really sweeeeet.........  Cool
An awful lot of work to make that come together, looks like Jag (should have) made it.
JayJay
« Reply #4 on: September 25, 2013, 10:38:42 AM »
I liked the brand new 3 wheel Morgan with the Harley engine. I didn't realise they still made 3 wheelers. It arrived late in the day but it got lots of attention.
JJ  Cool
« Reply #5 on: September 25, 2013, 11:02:45 AM »
JJ  Cool
Krazy Horse are the dealers for them now, along with the new indians
« Reply #6 on: September 25, 2013, 09:38:34 PM »
They must be selling well -I've seen 6 different ones in the last 2 weeks.
« Reply #7 on: September 25, 2013, 09:52:57 PM »
Out on the trike the other day and met one blatting around the village.
Twas faster than me Cry   Wink
« Reply #8 on: September 26, 2013, 04:47:41 PM »
Bear in mind they use BIVA ( Low volume production) , or MSVA but I don't think they have a Low volume section ?, to make them legal .Another good place to steal ideas for your project.
« Last Edit: September 26, 2013, 08:47:32 PM by kapri » Logged
« Reply #9 on: September 26, 2013, 09:19:14 PM »
Yeah, I was wondering about the full length exhaust, down the side of the body. Wouldn't that need heat shielding along the whole length? And wouldn't the tail pipe be too high?
« Reply #10 on: September 26, 2013, 09:39:55 PM »
Nope re heatshield, look at most Lotus 7 replicas and, my favourite point of reference to Police officers, motorbikes ! .May be a problem with C&U re exhaust height but would have to check that out.
« Reply #11 on: September 26, 2013, 09:57:09 PM »
We'd like to run the pipe down the side of the body on the T roadster thingy. So it's O.K to burn yourself on any part of it except the bit below the cockpit? Heightwise, I was thinking about the emissions & decibel tests we had to comply with for the Pop. The meters were at set heights from the ground, which would suggest minimum/maximum tailpipe height wouldn't it?
« Reply #12 on: September 27, 2013, 07:15:28 AM »
JJ  Cool
The press was talking up that Morgan were going to be using Harley engines a few years ago, but to be a bit sadly technical  Roll Eyes, they're actually S&S - but don't they look fun  Cheesy
http://info.sscycle.com/performance-times/bid/51874/Introducing-The-new-X-Wedge-powered-Morgan-3-Wheeler
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=8766.0
« Reply #13 on: September 27, 2013, 11:18:37 AM »
From section 01 BIVA manual group M1 vehicles
Position the vehicle within the authorised test area. With the sound
meter horizontal, set the microphone height so that it is at the height of
the exhaust outlet or 200mm from the ground, whichever is higher.
a.
At an angle of 45 degrees to the exhaust outlet in the direction
which gives the greatest distance between it and the vehicle
contour
b. At a distance of 500mm from the exhaust outlet.
With the vehicle at normal operating temperature, run the engine at ¾
of its ‘maximum power’ speed, and note the sound level reading
obtained.
Note 1:
Manufacturers drain holes are permitted in silencers
Note 2:
The exhaust may have several outlets up to 300mm apart
connected to the same silencer. In this instance the microphone must
face the outlet closest to the vehicle contour or highest from the
ground. In all other cases, separate measurements must be taken for
each exhaust outlet; the highest value obtained is the test value.
Note 3:
Where the engine maximum power speed is not available, the
test may be carried out at 2/3 of engine maximum design speed.
« Reply #14 on: September 27, 2013, 08:17:55 PM »
O.K, so no mention of actual pipe height then. And an exposed hot exhaust is O.K?
