December 23, 2025, 04:29:58 PM *
Author Topic: Engine whine.  (Read 5925 times)
« on: August 01, 2013, 01:12:47 PM »
OK so it's not a "HotRod" but it is a V8.
A while back, the Jag started to whistle, rising in pitch with engine revs, (sounded like a supercharger) figured it would need a new belt or tensioner. This turned into a whine. Now it's turned into more of a howl. People turn and look Shocked.
Took a sounding tube to rotating components and found the noise was coming from the water pump. Slackened the serpentine belt and sure enough the bearings are shot. It turns freely enough and no leaks but there is a lot of side to side movement. So there goes another wad of cash  Cry
« Reply #1 on: August 01, 2013, 02:01:31 PM »
i had the same on my minx, no leak just bearing buggered.
« Reply #2 on: August 01, 2013, 09:03:33 PM »
Personally I'd just pretend you've got a 'charger on it.
« Reply #3 on: August 01, 2013, 09:30:04 PM »
mine cheered the fan belt!!!
« Reply #4 on: August 01, 2013, 09:48:46 PM »
Grin. But at only 240hp there's nothing to back it up.
« Reply #5 on: August 01, 2013, 09:52:54 PM »
That's twice what I've got in my truck. Time to build a roadster out of it then Dave!
« Reply #6 on: August 01, 2013, 10:44:42 PM »
recently done the timing chains on a ,supercharged, one of them ,
« Reply #7 on: August 02, 2013, 07:20:35 AM »
Exploding tensioners?
Replaced mine last year Angry
Rather have the old Rover/Buick V8 + carbs any day.
