March 15, 2026, 04:50:22 PM *
Author Topic: Reliant axle brackets  (Read 1796 times)
Rocket
« on: July 29, 2013, 05:35:30 AM »
Would anyone be able to make me a set of axle brackets and engine mounts like the ones MM used on Flaps orange trike  Undecided Undecided
Thanks in advance Wink
« Reply #1 on: July 31, 2013, 07:57:12 AM »
Hi Rocket.
Making the axle brackets is not difficult but it is time consuming plus you have to have the materials at hand. As to the engine mounts same applies plus you need to have the engine sat in the frame to determine the shape/length etc. it all depends on the width of the frame and the height of the engine relative frame.
Good luck with your build.
Rocket
« Reply #2 on: July 31, 2013, 09:16:08 AM »
Thanks buddy I had thought that about the engine mounts so ill make them once I've bent the main tubes up, I've found someone to make me some axle brackets now so I'm all sorted, just waiting for my headstock to be finished and it's all systems go...
