March 18, 2026, 01:58:16 PM *
Pages: 1 [2] 3 4 ... 16
Author Topic: Girder Forks.  (Read 77896 times)
« Reply #15 on: June 04, 2013, 09:51:34 AM »
my drawings are ,trial n, error, Wink
or  etch-a-scetch  Cheesy Cheesy Cheesy Cheesy
« Reply #16 on: June 04, 2013, 01:11:25 PM »
I like drawing.
The crayons taste nice.
« Reply #17 on: June 04, 2013, 01:33:05 PM »
Especially the red ones Cheesy
Steel plate for the yokes has arrived. Think I'm going to need a lot of hacksaw blades as they are 20mm thick. Just looking at it makes my arms ache.
I am just going out, to the garage. I may be some time.
(Apologies to Capt. L Oates)
« Last Edit: June 04, 2013, 01:43:06 PM by Old Newbie » Logged
« Reply #18 on: June 04, 2013, 01:40:54 PM »
try a jigsaw. low speed coarse teeeth
http://www.youtube.com/watch?v=8TU8HKqrtzI&list=UUGwEI_g2v8x06CFltaKsxWA&index=4
« Reply #19 on: June 04, 2013, 01:57:29 PM »
 Grin Watched another of his vids. He's a hoot.
That was 6mm plate he was cutting. Burnt out my jigsaw last time I tried something over 12mm thick. Will probably get some thin cutting discs for the angle grinder. It annoys the neighbours Grin
« Reply #20 on: June 04, 2013, 07:47:04 PM »
Bring it over to Loony's workshop Dave -the neighbours are used to us using angle grinders.
Bet Heather the post lady loved you for making her lug that steel about.
« Reply #21 on: June 04, 2013, 08:02:31 PM »
Luckily for her some other poor postie had to carry it  Cheesy  I'd forgotten quite how heavy 20mm steel is.
Have spent two hours roughing out the top yoke. This could take a while.
« Last Edit: June 04, 2013, 08:05:08 PM by Old Newbie » Logged
« Reply #22 on: June 05, 2013, 07:55:32 AM »
Top yoke. Just roughed out.
Once finished it should look like a forging.
« Last Edit: June 05, 2013, 08:01:02 AM by Old Newbie » Logged
« Reply #23 on: June 05, 2013, 02:42:27 PM »
The neighbours will be happy.
 Lots of smoke and not a lot of go from the angle grinder Angry Yep the motor caught fire
Never mind there is still the hacksaw and hand files, till I can get another. It's just a hell of a lot slower Smiley
« Last Edit: June 05, 2013, 03:09:02 PM by Old Newbie » Logged
« Reply #24 on: June 05, 2013, 03:26:59 PM »
i think thats ,,foooo-barrred  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
« Reply #25 on: June 06, 2013, 09:29:21 PM »
Angle grinder situation sorted + picked up a new 25mm drill bit, to bore the yokes for the headstock stem.
Bored the top one out on the lathe using a 4 jaw chuck and kept the speed down to about 60 rpm as it was so unbalanced.
Also drilled the riser mount holes.
« Reply #26 on: June 06, 2013, 09:32:49 PM »
did you put the yoke in the chuck ?
« Reply #27 on: June 06, 2013, 09:39:06 PM »
Yep. Only just fit. Luckily it swung in gap before the bed slides.
« Last Edit: June 06, 2013, 10:20:32 PM by Old Newbie » Logged
« Reply #28 on: June 08, 2013, 10:18:42 AM »
Steering stem carefully removed from a Z750 bottom yoke. Seemed a shame to cut it up, but the yoke wasn't in great condition, it will save a lot of machine time and I know that it will fit.
« Reply #29 on: June 09, 2013, 02:36:35 PM »
Bottom yoke slab roughed out and bored with a fine taper for the first 3mm to aid pressing in the steering stem.
Will press together later once I have finished shaping the yoke and got some more propane.
« Last Edit: June 09, 2013, 02:59:23 PM by Old Newbie » Logged
