December 23, 2025, 08:17:35 AM *
Author Topic: TH 350 modulator  (Read 4469 times)
« on: May 27, 2013, 10:26:22 PM »
right,,
on the  r/h side of ,EMILY,s transmission is a modulator diaphragm , its not got a vac pipe going to it which i believe it should have ,, and when i tried her out on the road (what little she ran) i wasn,t 100% shure the trans was changing up into top ,,so i want to pipe up this modulator, and also clean out the trans pan and change the fluid whilst im fitting the new engine and doing a few other mods ,,
the question is ,,where to pick up the vac for the modulator ,, Undecided Undecided should i just pick it up of the inlet manifold ,, seperate from anything else ?
or doe,s it need to be from a specific point ??
phunkie hiboy
« Reply #1 on: May 28, 2013, 06:02:07 PM »
It works on inlet manifold vacuum.   Smiley
