November 13, 2025, 10:36:35 PM *
Author Topic: electrolytic de-rusting  (Read 4015 times)
« on: February 03, 2013, 11:28:17 AM »
nothing done to the trike this weekend and still waiting on parts for the bike
so had a go at electrolytic rust removal.
things you need
washing soda crystals
plastic bucket
battery charger or 12v power supply
hook up wire
a sacrificial piece of metal
basiclly add 1 table spoon of washing soda crystal's to a gallon of water in a plastic bucket
and stir
suspend the sacrifical piece in the water connected to the + side of the battery charger
but do not let the connection touch the water
suspend the part you want to remove the rust from in the water and connect ot the - of the
 battery charger this can touch the water
switch on the charger and you should see bubbles forming in the water,if not you have a bad connection
leave it in a well ventalated area for a few hours and see how it goes, we tried it on a piece of
rusty angle iron and it worked well,if you move the pieces closer together be sure to check the
amps on the battery charger,closer = more amps
sorry forgot to photograph the piece before we put it in the bucket but it was pretty rusty
http://i1056.photobucket.com/albums/t373/Eddie096/3E0DF76C-FB61-4CB4-A21C-5E7AF7D79BF6-15891-00001F35DEDEBDAB_zpsd6fcfc5b.jpg
this was the current drawn with the pieces at opposite sides of the bucket so a 4 amp charger is fine
http://i1056.photobucket.com/albums/t373/Eddie096/D21B8D54-CE45-4897-903F-A5CE2572FB3F-15891-00001F35F430F2DB_zps318e1feb.jpg
after, all surface rust removed some pits still evident
http://i1056.photobucket.com/albums/t373/Eddie096/5F1E9907-E4FB-45D1-914A-021AD68CD679-15891-00001F360B5E4CC4_zps4e45051b.jpg
hope i'm not re covering some thing thats already been on here but i haven't seen anything
« Reply #1 on: February 03, 2013, 11:34:06 AM »
I claim no originality for this, there's plenty of info on the net,youtube etc
so happy derusting
Al
« Reply #2 on: February 03, 2013, 02:21:04 PM »
iv been using this method for a year now and works a treat      bloody amazing  im using an old cast railing instead of metal piece very impressed with results
well recomend
The North
« Reply #3 on: February 03, 2013, 05:55:15 PM »
Spent the last six months messing with rust removal my totally unscientific totally unprofessional conclusion for what its worth. Molasses  Cool Cool Cool Cool 9 parts water to 1 part molasses.   1 word to describe this method Awesome!.
http://www.youtube.com/watch?v=KZCFcxf5IBw
http://www.youtube.com/watch?v=8-gBAjEga1s
Mendalot
« Reply #4 on: February 03, 2013, 11:19:23 PM »
Ah ha, science stuff Cheesy   does the amount of washing soda crystals make a difference,  ie;  will a stronger mix give a better result?
Al
« Reply #5 on: February 03, 2013, 11:28:01 PM »
i thought the same   but no it doesnt put as much as you want in and it will do the exactly the same
this method is great for petrol tanks to get rid of the rust out of a tank that has been lying for a bit then rinse out a couple of times then with petrol and job is a good one
« Reply #6 on: February 03, 2013, 11:29:09 PM »
it,ll take an ,f##king,, big tub for a ,dutton,, chassis  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
one arm bandit
« Reply #7 on: February 03, 2013, 11:55:53 PM »
cut it in to bits the weld her back together Cheesy Cheesy
« Reply #8 on: February 04, 2013, 12:02:21 AM »
bu##er the welding -------chuck it in the skip  Cheesy Cheesy
« Reply #9 on: February 04, 2013, 08:34:56 PM »
thats exactly why we are experimenting Al hopefully get some pics on when we try it for real
