December 16, 2025, 07:57:12 AM *
Pages: 1 ... 5 6 [7]
Author Topic: Ariel  (Read 36644 times)
blair
it looks bigger in water ! !
« Reply #90 on: October 21, 2013, 03:11:45 PM »
been doing a bit of spray painting , bikes going to be a bit of a rattle can special . think this the best way to do it as i can get it all back together and itll look ok , then later on i can do the whole thing again but without the engine and box needing done
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2593_zps64ca3560.jpg
Ariel
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2592_zps4361a05c.jpg
Ariel
also had a go at elctrolisis to strip the tank . however after 48 hrs it had removed most of the rust but not the chrome , ive tried bleech , brake fluid and oven cleaner but its on there pretty good . going away to speak to my friend that has an industrial blaster , way bigger than my garage one
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2587_zps3c7d250e.jpg
Ariel
« Reply #91 on: October 21, 2013, 06:46:10 PM »
Nice to see it starting to come together again. Smiley
blair
« Reply #92 on: October 22, 2013, 11:05:56 AM »
cheers , the main problem is not knowing what parts i need until i need them if you know what i mean , other than the tank the wheels will be a problem and shall only get done once i have funds  Angry .
still got to sort out the kick start shaft  Huh once ive done that i can get the gearbox back together
« Reply #93 on: October 22, 2013, 04:56:30 PM »
Building wheels can be done at home. It's time consuming but you can save a fair bit. Main thing is never to take rim off the hub until you have taken some basic measurements and made a careful note of the lacing. Pics are a good idea.
A trueing jig is essential but easy to make.
blair
« Reply #94 on: October 26, 2013, 07:28:30 PM »
i think i may cheat a little to be honest Old Newbie , if all the spokes are the ( i havent checked yet) i may get them blasted and powder coated . its not a full resto job anyways so not really a worry . also found out today that the paint is not solvent proof hahahahah
after getting new bearings and headrace adjuster sleeve i got the headset refitted , also go the plungers rear end back on too
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2599_zps0c5cef53.jpg
Ariel
i think this is how itll sit for a while as i need to put the gearbox back together im going to copy the idea of a man on another forum for the kickstart shaft , ive ordered one for a cg125 . its almost the same shape but has a 16 mm splined hole and the Ariels was 18 mm (5/8") so ill dremmel new splines into the shaft
« Reply #95 on: October 26, 2013, 09:29:56 PM »
Well, your an optimist, if nowt else................ Huh Huh Huh Huh
blair
« Reply #96 on: October 26, 2013, 10:35:32 PM »
not really Morrag im actually a realist , and i fully understand that i may just me building a bike shaped paper weight  Grin  Tongue, i take it your referring to the shaft idea ? if so i really cont think of any other way around it . i cant find a replacement and other than tinfoil im out of ideas .
blair
« Reply #97 on: October 31, 2013, 09:28:12 PM »
well new gs 125 kick starter arrived today , spent a wee while in the garage with a very small grinding disc and had a go at recutting the splines , seamed to have worked but i can only get the starter on in the upside down position  Tongue not really handy  Grin
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2613_zps55b0d4ab.jpg
Ariel
just need some gasket paper and i can try an put this lot back together , and not just shove it all in the casings and hope  Grin
http://i39.photobucket.com/albums/e160/bummer2220/IMG_2614_zps5aa925ad.jpg
Ariel
« Reply #98 on: October 31, 2013, 11:30:48 PM »
You're a brave man blair!
Shall I tell you the story of my Moggy Minor?  My then hubby bought a gearbox for it from an A35 but the casing wasn't the same so he had to swop the innards over.  He did a great job except that I had the only Moggy in the UK - probably in the World!  that would engage first gear and reverse at the same time.....   and second gear and reverse, and so on.  At least you won't have that problem!
goose
« Reply #99 on: November 01, 2013, 12:43:53 PM »
doing a great job there sir Smiley
