April 03, 2026, 10:01:29 PM *
Pages: 1 ... 18 19 [20] 21 22 ... 48
Author Topic: Deliverance  (Read 335901 times)
« Reply #285 on: April 08, 2013, 08:48:32 PM »
Thanks guys Smiley
Will try to get over to the DVLA tomorrow but family matters may (probably will) get in he way.
Hopefully be able to give MM, the registration number, for the Basingstoke show soon Grin
« Reply #286 on: April 08, 2013, 09:12:50 PM »
Congratulations young man Wink Smiley
« Reply #287 on: April 08, 2013, 09:25:20 PM »
Well done Dave.
« Reply #288 on: April 09, 2013, 06:00:12 AM »
Congratulations ; there was never any doubt that it would pass Grin Grin
« Reply #289 on: April 09, 2013, 09:47:09 PM »
Thanks. No chance to go to DVLA today Cry but did some more on the new seat.
The leather has been glued to the top surface of the foam. This is not normally done but this seat is sculpted.
The second seat base is made out of 1mm steel. The reason for two bases will become apparent.
Just noticed that It's been eight months since I started posting about the trike under the heading Nearly finished ?
 Finishing has taken longer than I thought Smiley
« Last Edit: April 10, 2013, 07:56:04 AM by Old Newbie » Logged
« Reply #290 on: April 10, 2013, 12:17:59 PM »
Spent all morning at the DVLA. All paperwork ok but they have decided that despite having the V842 stamped by a garage confirming the vin is stamped correctly, the MSVA certificate from VOSA which you can't get without the vin stamped and a MOT certificate from a different garage, which once again you can't get without the vin stamped, they want trike taken to the office so someone can see if it's got the vin number on it. Huh
ARRRRGH Angry Angry Angry Angry Angry
« Reply #291 on: April 10, 2013, 12:36:04 PM »
they will have you walking a tight rope, and jumping through hoops whilst whistling ,dixie, next  Roll Eyes Roll Eyes
Dslam
« Reply #292 on: April 10, 2013, 04:28:55 PM »
In my experience this is normal. You should find the inspector is fine and is only ratifying what is on the paperwork to help prevent fraud. Just go with it and all will be well.
« Reply #293 on: April 10, 2013, 07:46:11 PM »
Welcome to my World Dave! As Mr Slam says, just roll with it -it could be a lot worse. One more tiny hurdle & you'll be roadworthy & completely legal!
« Reply #294 on: April 10, 2013, 09:15:18 PM »
Well I'm in trouble then.
Can't whistle!
I know. Just can't work out why they made me pay (and go through the hassle) to get a V842 certified to prove that it's been stamped.
I keep on rolling but am ending up a bit bruised. And a lot lighter in the pocket!
Scottie is once again coming to the rescue, transporting the trike for me. ( www.movinghotrods.co.uk) For which I am very grateful,  I know he's had to rearrange things to do this.
« Reply #295 on: April 10, 2013, 09:20:30 PM »
He is indeed a diamond geezer.
With luck, both Scottie & Old Newbie should be displaying vehicles on our pitch at the Basingstoke Festival of Transport next month.
« Reply #296 on: April 13, 2013, 07:16:52 AM »
Yep. If I manage to get it registered in time I'll be there Grin
Done no more on the new seat recently but will get back to it today. Had a bad night so made up the nameplate to go on the tailgate.
The recessed etched area has been filled with a mix of paint and lacquer to try to get a effect similar to the old style enamelled badges. when its fully dried out (it's in the oven at a low heat) I will bevel the edges before final lacquer.
« Last Edit: April 13, 2013, 07:25:16 AM by Old Newbie » Logged
« Reply #297 on: April 13, 2013, 05:42:47 PM »
Is there no end to your talents?!
« Reply #298 on: April 13, 2013, 08:16:06 PM »
hhmmm you clever old bugger  Smiley Wink Cheesy
« Reply #299 on: April 14, 2013, 07:20:26 AM »
Got a bit more done on the seat. Three holes drilled through to match existing mount and two M8 bolts welded through the rear holes to attach the springs to. I used calliper mount bolts as these have a large head, low profile and happen to be laying around. The front mount hole has a M8 nut welded on. Also a stiffener was welded down the centre line of the of the steel seat pan.
Apologies for the poor quality welds but all I have left are 3mm rods. None of this will be visible anyway Wink
Next will be the hard bit. Sewing. Not looking forward to this and it might take some time as the leather is 2mm thick and sewing through 4mm of hide is hard on these old hands.
« Last Edit: April 14, 2013, 07:37:26 AM by Old Newbie » Logged
