Technical Section => Trike Tech => Topic started by: Olds on November 26, 2012, 07:15:58 AM
Title: Deliverance
Post by: Olds on November 26, 2012, 07:15:58 AM
Thought it time to add a few photos
Title: Re: Deliverance
Post by: Olds on November 26, 2012, 07:19:08 AM
 home made battery/electrics box, big enough to take a harley sized battery(just),ign. switch, hazard switch and relay, bolted to rear tank mounts through pick-up panel, starter cables and ignition wire run in stainless flex.
Post by: Olds on November 26, 2012, 07:22:58 AM
Crowded left hand but nowt on the right hand. Headlamp is also a bit cluttered at the moment. Inside is a bit of a rats nest as most of the wiring connections are there, the temp gauge is a lot bigger than the std ammeter and the the voltage regulator is in there as well.
Post by: Olds on November 26, 2012, 07:34:25 AM
Before any comments this is my daughter. Added to show the proportions of the trike.
Post by: Manky Monkey on November 26, 2012, 09:53:59 AM
Lovely looking trike Dave. I really like the pick-up bed.
Post by: BikerGran on November 26, 2012, 12:56:08 PM
Me too - and it made me chuckle cos now I understand the name - clever!
Post by: vmax1200 on November 26, 2012, 05:52:33 PM
nice looking trike love the back end  8) 8) 8)
Post by: bigdarren on November 26, 2012, 06:45:41 PM
is your pickup bed made from an atv trailer ? ???
Post by: Olds on November 26, 2012, 07:10:29 PM
NO !
Post by: bigdarren on November 26, 2012, 07:29:04 PM
calm down , was only asking as it looks like my trailer bed (http://i695.photobucket.com/albums/vv320/bigdarren73/388930_10150577516925620_769510619_11649066_2090776173_n.jpg)
Post by: dave 67 on November 26, 2012, 07:35:35 PM
Real Cool little trike that ,, are you going to put a bottom in the back bit some nice cedar wood would look nice and go silver after time
Post by: Olds on November 26, 2012, 07:51:50 PM
Yep, not sure on the type of wood though, thinking along the lines of ash or oak.
Sorry BD, wasnt having a strop
Post by: bigdarren on November 26, 2012, 07:56:29 PM
 ;D
Post by: hornet6 on November 26, 2012, 08:06:15 PM
Very neat and tidy.....and different
Post by: gazzagood on November 26, 2012, 08:18:23 PM
still think your sheetmetal skills
are outstanding
very nice indeed  ;D
gaz
Post by: Olds on November 26, 2012, 08:43:01 PM
You didn't see all the bits that I had to throw away but thank you.
Post by: scannerzer on November 26, 2012, 10:05:32 PM
looks good once you get it floored it'll be a very usefull runabout
Post by: scannerzer on November 26, 2012, 10:38:25 PM
any chance of a close up of you gear change arrangment it looks interesting
Post by: Olds on November 27, 2012, 05:59:41 AM
Deja vu. Pics and description in thread "nearly finished " posted in general discussion a while back. This build has been a bit slow (it's my first trike) but once it's finished the next shouldn't take as long :-\ Just found the receipt for the pipe bender dated 30 july 2011 !
Post by: TwistedPatience on November 27, 2012, 07:34:09 AM
My trike was going to have a pick up bed but that was 20 years ago, lovin' that tho', wish I had done it now.
Post by: steven brock on November 27, 2012, 07:55:44 AM
Looking fantastic , love it :)
Post by: Manky Monkey on November 27, 2012, 07:30:39 PM
I've just sold my longstanding trike project, but if I'd kept it I would've copied Dave's gearchange set-up, though mounted on the left of the tank, rather than the right. Having tried it, I can confirm it works really well.
Post by: dave 67 on November 27, 2012, 07:40:13 PM
Dave what is the short gear lever for and can you post some more pics up off the gear set up
Post by: Manky Monkey on November 27, 2012, 07:42:05 PM
Short lever's to engage reverse.
Post by: Olds on November 27, 2012, 08:53:36 PM
Thanks MM.
 Been busy on the lathe today. Needed to make a new clutch rod adjuster and also made a dipstick/filler adaptor to save taking off the tank to add oil. Will still take a while to change the oil but saves messing around with tank & gearchange.
No longer have most of the pics I took of gearchange and don't know how to move them from one post to another.
Will try to take more tomorrow.
Post by: Manky Monkey on November 27, 2012, 09:06:58 PM
Nice work Dave. That'll should take about a week to fill the engine vis the dipstick tube shouldn't it?!
I wish I knew how to operate a lathe -how do you make the knurly knob thingy? I don't understand how you get that uniform wavy edge when the piece is spinning in a lathe.
Post by: dave 67 on November 27, 2012, 09:20:06 PM
Cheers andy so how do you engage reverse then is it a push down or lift up I've never driven a reliant it's my first so looking at options on what I can do
Post by: Olds on November 27, 2012, 09:30:46 PM
Actually it's not that bad. Certain veedubs use something similarbut with a slightly larger tube. The main thing is having somewhere to pour the oil into, the cup is 20mm id, plenty big enough :D
You don't. The grip notches were added afterwards :)
Post by: Olds on November 27, 2012, 09:36:19 PM
On a normal Reliant box you lift up. On this one as MM said it has a seperate reverse lever so neither.
Post by: Manky Monkey on November 27, 2012, 10:30:09 PM
Normal Reliant reverse position is lift the lever, then across to either the left or the right, & back. On some boxes it's to the left & others to the right, though I don't know why they changed. You can tell which you've got though -if you look down on the gearbox from above, there's a bump in the side of the casing below the stick. If it's on the left of the box, your gearstick goes to the right to engage reverse. If it's on the right, it goes to the left. Might determine the shape of your gearstick as it'll need to clear the frame etc whe you select reverse.
Post by: Olds on November 28, 2012, 08:05:51 AM
Gear change close ups
Post by: dave 67 on November 28, 2012, 08:07:55 AM
Arrrrrr thanks haven't got that far yet but handy to know ta
Post by: dave 67 on November 28, 2012, 08:11:47 AM
So you push down on the short leaver to force the gear stick up to put in reverse cleaver is ita rod in the stainless shower hose to and from the leaver to the box sorry for all the questions but it does look good
Post by: Olds on November 28, 2012, 08:35:01 AM
No and yes.
No the short lever is totaly seperate from the main lever, has its own selector. You just move it towards the rear to select reverse.
Yes there is an 8mm dia rod inside the shower hose. this was added because the rod needs to be well greased as it slides in the centre rosejoint.
You could use large cable boots either side but this works well and matches starter cable cover.
Post by: triker_Chewie on November 28, 2012, 01:49:55 PM
Mite need a tech article written on this.
Then pin it at the top with the brake mod
Post by: Manky Monkey on November 28, 2012, 09:06:31 PM
Took me a while to get my head around it -& I've seen it.
Tell 'em about the ball joint thingy that allows you to move the stick from side to side as well as back & forth Dave.
Post by: Olds on November 28, 2012, 09:57:41 PM
The pivot shaft (the shiny bit with a nut on it) allows fore and aft movement, the gearlever is attached to the end of the pivot shaft by a cross pin, allowing side to side movement of the lever. A compression spring (in the photos bit of rubber hose but this has now been changed) between the mount and the fixing nut keeps the lever tight against the mount, and the linkages in the 3rd-4th plane, pushing the lever toward the tank pulls the pivot shaft out against the spring allowing the bottom of the lever to move outwards and causes the connecting rod to pivot in the centre rose joint moving whats left of the original gear lever to the left, 1st and 2nd. This means std H gate gear change pattern except 1st and 3rd are at the bottom and 2nd and 4th are at the top.
Post by: Olds on November 28, 2012, 10:03:38 PM
insitu
Post by: Olds on November 29, 2012, 03:49:27 PM
Latest little job done, out of hundreds left to do, alternator fan guard. Hope it's enough to keep Mr MSVA happy  :-\
Post by: BikerGran on November 29, 2012, 10:14:46 PM
It's very pretty!
Post by: Olds on November 29, 2012, 11:00:31 PM
Thank you kind lady.
Despite being, as my wife would say "a mere male" I can sometimes do delicate or pretty :)
Post by: Manky Monkey on November 29, 2012, 11:03:20 PM
Nicely done Dave.
Bearing in mind the MSVA registration test is done with the rider sat on the trike, & they test for external projections with a large foam roller rolled down the side of the vehicle, I wonder if the fan belt needs a shroud?
On my own trike the bottom radiator hose curved around to form a sort of natural guard around the front of the alternator. Would that be enough to satisfy the testers?
Post by: dave 67 on November 29, 2012, 11:59:57 PM
Nicely done Dave. I'd like to see that in place.
[/quot
Are serious about that andy or are you kidding
Post by: Manky Monkey on November 30, 2012, 12:20:41 AM
About the foam roller? No, that's what they do. It's jokingly called the kebab -a big cylinder of foam on a wheeled stand, like a carwash roller. Yes, they test the trike with you sat on it -so stick your knees & elbows out & wear the biggest boots you've got. They roll it down both sides, but not across the back for some reason. Anything it touches must have a radiused edge.
Post by: thebigdogsix on November 30, 2012, 06:08:59 AM
im with Andy on this with the exception that the rollers were steel (when mine was tested) at no point did the examiner ask or even mention a guard for the alternator but i will say nice work on that guard O N really neat and tidy
Post by: dave 67 on November 30, 2012, 07:01:00 AM
Bloody ell
Post by: Olds on November 30, 2012, 07:11:20 AM
Was partly joking about Mr MSVA. I believe they can fail a vehicle for having dangerous items like exposed rotating  parts likely to cause injury. But this was added for ny own piece of mind. Next photo shows how close it is to my foot,plus don't want some idiot kid losing a finger :)
Post by: Olds on December 08, 2012, 11:21:17 AM
Handbrake. Release lever added cos I can have problems with my right thumb.
Before,
Post by: Olds on December 08, 2012, 11:24:17 AM
After.
Now just need to make up a nice grip.
Post by: Mendalot on December 08, 2012, 05:03:41 PM
you can buy a tin of liquid dipping plastic from Frost Restoration, Ive used it to coat the handles of pliers etc, the more you dip the item and build up coates, the better the finish. May not be what you had in mind though.
Post by: Olds on December 08, 2012, 10:25:44 PM
Know the sort of stuff you mean but thinking more along the lines of turning up a stainless one, to look like the stainless spiral hose cover used over the starter/ ignition leads and gearchange rod. That or the white handgrips you used to get on kiddy scooters & tricycles way back. Found them in the states but postage was horrendous.
Post by: Olds on December 09, 2012, 08:21:49 PM
Finished handbrake. Modified, from a Landrover Defender. So much easier for me to use now ;D
Post by: goose on December 11, 2012, 03:48:01 PM
very nice indeed sir ;D ;D
Post by: Olds on December 14, 2012, 09:01:53 AM
Thanks Goose.
Had a good day yesterday finishing the electrics. Fitted the battery, put in the fuses and nothing caught fire ;D
Amazingly all the lights and horn work as they should, even the hazards! Turned the key to start position and hurray the motor turned over for the first time. Not tried to actually start it though as the fuel tank still needs sealing and I still need to fit a couple of hose clamps but for me that was enough The electrics took far too long, somehow it's the little jobs that take ages with little to show for it at the end of each day.
Next- number plate mount,
Post by: morrag on December 14, 2012, 12:28:24 PM
I do like this trike................................ ;D ;D ;D ;D ;D ;D ;D ;D
Post by: Olds on December 15, 2012, 08:35:42 AM
Thank you morrag  :D
Filled the engine with oil this morning and Mr MM was nearly right about it taking a week to fill using the dipstick tube. Actually took a bit over 1/2 hour.
Still, it means I don't have to take off the tank or gear change so not to bad ;D
Post by: morrag on December 15, 2012, 11:20:27 AM
Barely time for a piece of toast and a cuppa!!!
Post by: andyrennison on December 16, 2012, 07:39:51 PM
Ive been waiting to hear about that fill up. I really like the idea of a side fill for the oil. Can you think of any way of improving the fill rate ?
Post by: steven brock on December 16, 2012, 07:53:36 PM
I wonder if my fuel pump blank off plate could be adapted as an oil filler ummmm
Post by: Olds on December 16, 2012, 09:05:07 PM
Warming the oil might speed it up. The oil had been stored in the shed and was really, really cold or you could -
Easily. Great idea ;D but not for me as i'm using my pump.
Not a lot done today. Had to change the rear fuel tank outlet cos msva wont allow fuel connections above the exhaust. Also made the numberplate mount.
Post by: Olds on December 16, 2012, 09:11:17 PM
And fitted. Like all the sheetmetal, i'm trying to make it look 1920-30s factory made. Means a lot of tin bashing.
Post by: Manky Monkey on December 16, 2012, 09:18:56 PM
Nicely done Dave. Little touches like that make all the difference don't they -& I think make building one-offs more satisfying.
Post by: Olds on December 16, 2012, 09:33:49 PM
Very true but it take a lot of time.
My hands aren't working as well as they should at the moment so the bracket took over 2 hours to make. Still it's one more thing off the list of things to do.
Somehow that list is still getting longer :P
Post by: Olds on December 18, 2012, 08:07:58 AM
Looking at the fuel pump, realised that if youre not using it you could probably rip out the guts make a new top and use this as a side filler.
Just a thought.
Post by: andyrennison on December 18, 2012, 06:21:12 PM
Just a thought.
Ooooohhhhh. Ive got a knackered pump here, I'll take a look at that idea. Means i'll have to buy a facit pump but what the heck, ive spent so much now on this I may as well mortgage the house some more to finish it.
Post by: panthershaun on December 19, 2012, 11:22:57 AM
 8) 8) 8) superb build sir, I'm not a great trike lover but have great affection for the HD Servi-car and Indian Despatch-tow type of trike, This is up there with Sumo's Panther trike as the best I have seen (not that my opinion matters a jot  ;)) makes me think of the mock up I did using my spare model Y axle with the skinny wires and how cool it would look fitted to this type of trike.. something to add to the projects wish list...  ::)
Post by: Olds on December 19, 2012, 03:49:15 PM
Thank you. Kind words are always appreciated as are constructive criticisms.
Actually logged on to say IT RUNS   ;D ;D ;D ;D ;D ;D
Not sealed the fuel tank yet so hooked up to a drip and it fired up straight off. Was worried about how much noise it would make as the silencer is a shortened Enfield one but it sounds great but not too loud ;)
Post by: dave 67 on December 19, 2012, 08:09:02 PM
It's always good when they start first time isn't it ,,it does look  good I like it very much I've posted some pics up of the old harley trikes like it
It's what I was thinking off  for a while when I said a rat army type trike
Did you link the brakes so they run off one pedal
Post by: Manky Monkey on December 19, 2012, 08:28:56 PM
Congratulations Dave! So we'll see you at the workshop on it soon then!
Post by: Olds on December 19, 2012, 08:46:16 PM
Yep, I jury rigged the engine when i first got it and ran it for about 10 sec, no coolant, no exhaust, just to make sure it could run but that was it until today.
Have looked at the pics, no more ideas pleeeeease.
And no. The twin disc front brakes are operated from the left handlebar by a Harley clutch master cylinder. The throttle, lights, indicators and horn are all on the same side.
Post by: Olds on December 19, 2012, 08:56:34 PM
Will be the first place I go to after the MSVA.
If I can get the tank sealed this week I won't take it out for a quick spin round the block on Christmas day ;)
Post by: Manky Monkey on December 19, 2012, 08:57:55 PM
No, I wouldn't either.  ;)
Post by: scannerzer on December 19, 2012, 10:54:52 PM
it's nice to hear them run it give you a feeling of complete satisfaction :)
Post by: nabsim on December 19, 2012, 10:59:19 PM
Can see it now, Santa suit on and nip round town, the kids will think its Santa on his sleigh :)
Post by: Olds on December 20, 2012, 06:19:08 AM
:D   I already have the bushy beard but it's not quite snowy white yet.
Getting it running is always one of the high points of any build. There are still a lot of small jobs to do but hearing the motor run adds impetus.
Have to admit that Deliverance puts a smile on my face every time I go into the garage and if for any reason I couldn't ever ride it I think I would still be happy.
Post by: Manky Monkey on December 20, 2012, 10:47:48 AM
At one point we were talking of printing a MMMotors calendar, using forum members & their vehicles. If we get snow this year Dave, we really should get some Santa shots of you for future use.
Post by: steven brock on December 20, 2012, 11:15:44 AM
Great idea!
Post by: Manky Monkey on December 20, 2012, 12:20:31 PM
Got some great projects on the go here at the moment.
Maybe we'll revive the idea. Get some photos of you & your ride during the year, so we've got a selection to choose from, showing the different seasons, & maybe we can sort something for next year.
Post by: triker_Chewie on December 20, 2012, 03:07:42 PM
wish i HAD a project. give you a real confusing shot for a january day 40+deg!
Post by: Manky Monkey on December 20, 2012, 04:14:10 PM
 ;D
Post by: steven brock on December 20, 2012, 05:40:30 PM
Sure ill take a pic or too soon :) is it 12 pics one for each month or another format :)
Post by: Manky Monkey on December 20, 2012, 10:12:48 PM
Yeah, the previous plan was a shot of your trike/bike/hotrod, either being ridden or parked somewhere interesting, that's appropriate for whatever month it was for, with a small black & white portrait shot of the owner, inset in one corner.
Chewie, we could always use a shot of your brother's XS somewhere typically Australian, or even you in a MMMotors T shirt somewhere we'd recognise as Oz.
Obviously it'd be a long term project, (would need to be ready for sale around Nov/Dec next year), so you've got some time to think about it -or to build something!
Post by: triker_Chewie on December 20, 2012, 10:39:02 PM
well Lil' bros bike does live out in the rural areas. could  snap it out in a barren field
Post by: Manky Monkey on December 20, 2012, 10:56:40 PM
There ya go.
-sorry Dave. Didn't mean to hijack your thread!
Post by: Olds on December 20, 2012, 11:21:14 PM
Thats fine :)
Post by: Olds on January 01, 2013, 04:13:25 PM
Due to one thing and another, progress has been slow over the past couple of weeks  >:( but have at last managed to get a bit more done  :).
Sealed the rear tank today. Even though I made the tank, thought it best to degrease it first. Glad I did , the muck that came out was surprising. Then it needed drying out which involved washing out with what smells like nail varnish remover and then an hour of blowing it out with the air line and finishing off with a hair drier (Mrs Old don't know and I'm not telling). Finally poured in the sealant and spent a very tedious hour trying to get an even coating. This may all be easy on a bike tank but this thing has three baffles in it and to be honest I have no idea if the coating is even at the far end. All this you are supposed to do in a well ventilated area at a temp of 30 C, so used 3 fan heaters (my electric bill is going to be horrendous). This stuff takes 48 hours to cure but cant put petrol in for 6 days ???
Post by: Manky Monkey on January 01, 2013, 10:14:16 PM
Good luck Dave. I've had very varied results with tank sealers. Some are much better than others. We ended up doing the fuel tank on my truck twice, with 2 different brands. Think the first was Por 15 & the second PetSeal. No matter how much you prep the tank, they have a tendency to peal away from the inside face in sheets, then block up the fuel outlets. What make did you go for?
Post by: Olds on January 02, 2013, 12:00:20 PM
Sureseal made by a company called Tank Care Products. Recomended by Just Bikes in Basingstoke. It's the stuff they use after having problems with other types like Petseal. When cured it stays flexible and looks like latex. Supposedly totally ethanol proof, the main reason older sealants break down. The only real problem with it seems to be the 6 days to fully cure. A bit pricey but the tank was a pig to make so lets hope it works.
Post by: Manky Monkey on January 02, 2013, 07:51:07 PM
Worth noting for my own tanks if it works.
Post by: Olds on January 03, 2013, 07:57:41 PM
Finished the new bottom plate for the seat
Post by: Olds on January 03, 2013, 08:01:28 PM
Hopefully I wont be seeing these brackets again once the tank has cured and been fitted
Post by: Olds on January 03, 2013, 08:09:38 PM
It's a tight fit if you put the radiator, inside of the front frame tubes instead of stuck out front as it was originally designed to be.
Post by: scannerzer on January 03, 2013, 09:00:58 PM
all very nice work ON your trike will look really well with you out and about
Post by: trikerpete on January 03, 2013, 10:51:03 PM
I'd still like the June slot  :)
Post by: Olds on January 04, 2013, 03:14:57 PM
You expecting good weather in June or do you know someone called June  ;)
Tank refitted pic shows the sealant and also shows the first of three baffles. Hope this stuff doesn't peel off or break up. Pretty sure tank was sealed before but didn't want to risk having petrol dripping into the pick-up bed and messing up the paint or wood.
Post by: trikerpete on January 04, 2013, 04:16:08 PM
Ive been thinking about sealing my tank as a "belt & braces" thing but I'm unsure what to use. I keep hearing that fibreglass resin/gelcoat is the same as these other more expensive sealers, but cheaper. Anyone know different?
Didn't mean to hijack your thread. Cheers :)
Post by: ROD on January 04, 2013, 04:56:34 PM
I dont think Ive looked at this thread before ON,nice work,like the gearchange mechanism! I considered a pickup bed for mine at one point. That looks just the right scale/size.
Post by: Olds on January 04, 2013, 05:35:23 PM
Thanks Rod  :)
Sorry Pete, GRP tanks seem to suffer more than any other from the ethanol problem. Lots of boat owners are having to replace tanks.
Post by: Olds on January 09, 2013, 02:17:45 PM
Lots of shiney bits have arrived  :D thanks to my favorite postie, Heather (sorry Andy but she's delivered a lot of my trike and, she is better looking  ;D).
Still waiting for the chrome and glass fuel filter and the fuel tap though  :'(
Post by: Mendalot on January 09, 2013, 03:26:43 PM
Oi Oi, its Christmas again ;) ...... Nice
Post by: Manky Monkey on January 09, 2013, 09:32:44 PM
I'm hurt Dave.  :'(
Are your mirrors the required diameter for the MSVA test? They also have to be convex don't they?
Post by: morrag on January 09, 2013, 09:36:19 PM
Which particular anorak have you got on at pres. Mr M? ;D ;D ;D ;D ;D ;D ;D ;D
Post by: Olds on January 09, 2013, 09:43:24 PM
I'm hurt Dave.  :'(
Yep, so they should be OK and they are E marked. Was worried about the quality when I ordered them, cost £13.95 the pair but they seem fine.
Post by: Manky Monkey on January 09, 2013, 10:08:56 PM
 ;D ;D Wasn't being picky Mr Morrag, just assuming Dave's building for the test, & trying to point out to readers who might not know that fittings like mirrors need to comply.
Post by: morrag on January 09, 2013, 11:41:58 PM
 ;D ;D ;D ;D ;D only.......................
Post by: Olds on January 10, 2013, 06:56:42 AM
;D Got it in one Andy. That's also the reason for buying the exhaust trim. It has to have a rolled end to it, nothing to do with it being pretty at all, honest :D.
I want to get the trike through MSVA first time, so am being very carefull to meet all the requirements.
The footboards will need something on the front edges and the front axle nut will need a cover, I also still need to fit a steering lock or a lock on the reverse lever, because of the test  >:(
Post by: one arm bandit on January 10, 2013, 09:00:00 AM
hi old loving this build youve got some skills, recognised on you one pic showing the rad /engine that you cap on the brake m/cylinder looks metel, i think i remember rod saying when was building his the cap had to be clear or plastic or somthing?????  :)
Post by: Olds on January 10, 2013, 10:44:06 AM
Thanks OAB.
As far as I can ascertain the only problem with the metal cap is that it has a radius of less than 2mm on its bottom lip. You can overcome this by fitting a cover with radiused edges or a shore hardness less than 60A. I intend to turn up a cap cover from ally or brass.
Because the front mudguard is steel I welded in 4mm diameter rod under the front edge.
Post by: BikerGran on January 10, 2013, 07:57:55 PM
Good grief!!????!!!!  :o
Post by: Manky Monkey on January 10, 2013, 08:35:24 PM
It's so that when you're being run over, you don't graze yourself on it Bobbi.  ;)
You can get black rubber caps that fit over the metal Girling cylinder caps. No idea where from, but some of mine have had them in the past.
Didn't someone say a chain & padlock wrapped around the frame somewhere would suffice as a steering lock? My last green trike had a disc lock that clipped onto a tab on the frame when it wasn't in use. I don't think the regs say it has to be permanently in the operating position, just attached to the trike. Harleys use a tab on the bottom of the headstock with a hole in it that corresponds to one on the bottom yoke, so that you can put a padlock through the holes when the steering's on full lock.
Post by: one arm bandit on January 10, 2013, 08:52:38 PM
Thanks OAB.
sorry old, whilst bashing some metel around today i had this at the front of my mind, you have to be able to access the cap, ie not cover over the top, rod had foot boards and someone posted that they looked to cover the cap,    im just being causious and following you build as im about to cut my reliant trike up next weekend and build a new frame and register it properly.  as you, i dont want to fail on somthing so stupid/simple because the testers having a bad day etc. so all box's MUST be ticked ;)
Post by: Olds on January 10, 2013, 09:00:48 PM
Yep, at least when you run over someone and break their legs they shouldn't get scratched.
 I have a rubber/plastic cover for the MSVA but I turned up a brass master cylinder cover  on the Myford.
The idea of a cover is not to close in the mastercylinder just to cover the cap with something that becomes part of the cap.
Post by: Olds on January 11, 2013, 04:43:41 PM
Fitted the rear boarding today and dragged the trike out into a rare bit of sunshine :D
I was going to use real wood but getting decent stuff cut to the right thickness was a bit pricey, so at the moment this will have to do, it's laminate designed for use in bathrooms. Looks OK and should be weatherproof enough
Post by: Manky Monkey on January 11, 2013, 05:02:38 PM
I wish my truck pick-up bed was as tidy as yours Dave. Very nice.
Post by: Olds on January 11, 2013, 05:28:34 PM
Thanks And . I'm sure it will be when finished
For the MSVA locks now have to be on the steering and/or the transmission. Locks that act on the brakes in any way are not allowed. Seems that locking the transmission in reverse is acceptable.
Post by: Olds on January 14, 2013, 08:05:40 PM
Got around to signwriting the front tank today :-\  not too happy about it though, I was after a period look, seemed fine until i put it back on the trike, now it seems a bit big and my hands aren't as steady as they were but it will have to do. Will do DELIVERANCE on the back tank, but may use something like letraset.
BTW still waiting for that fuel filter. Someone must be building a trike out of the all the bits that don't get delivered  >:( The supplier said he'd send out another.
Post by: Mendalot on January 14, 2013, 08:33:00 PM
Very skillfull Sir, looks great.   Like to think that I can turn my hand to most things, but unfortunately don't have a steady enough hand for that sort of thing :-\
Post by: WAYNE999 on January 14, 2013, 08:34:08 PM
I spoke to a friend today who said a few years ago he welded a tab with a hole to the inside of the gear lever drilled the lever to suit put the trike into first gear the popped a padlock through the holes and this passed
Post by: Manky Monkey on January 14, 2013, 09:12:38 PM
Some mopeds have a clip that snaps over the brake lever when it's pulled on. I guess that's no longer acceptable then.
You hand painted that Dave? I'm impressed! Personally I think it's just the right size.
Post by: steven brock on January 14, 2013, 11:19:08 PM
Love the gear-stick how'd you select reverse? Sorry if already covered
Post by: Manky Monkey on January 14, 2013, 11:53:56 PM
A second lever down by the top of the box.
Post by: Olds on January 15, 2013, 08:18:55 AM
Yep.
Post by: steven brock on January 15, 2013, 04:22:39 PM
You sir are a genius :)
Post by: steven brock on January 15, 2013, 05:42:38 PM
How's that reverse lever work then ? Can't picture it..
Post by: Olds on January 15, 2013, 06:25:29 PM
Thanks SB
The shaft goes down into the box, through a bush, pressed into the boss on the cover, where on early reliants there was a dip stick. On the bottom of said shaft, is a selector arm, which engages with the slot in the reverse selector shaft. The selector arm also stops the original gearlever from engaging in the reverse slot.
Seems there are two types of gearbox some have the reverse shaft on the left, others on the right.
Was originally going to actuate it from another tank mounted lever but decided it wasn't worth the added complication cos I like simple.
Hope that helps. It really is quite simple, just not that easy to explain.
One day I'll get around to taking some internal pics.
Post by: steven brock on January 15, 2013, 06:37:22 PM
So both hands at once to engage? Then hold long gear lever and reverse steer etc
Post by: Olds on January 15, 2013, 07:11:55 PM
No.  Main gear lever in neutral, select reverse, back up.
The gearbox has three selector shafts. one has two positions, two have three positions
neutral reverse
first neutral second
third neutral forth
The reverse lever is totally independent of the main gearlever, except because of the interlocks, it can only be operated while the main lever is in neutral.
No holding on to any levers.
Post by: goose on January 16, 2013, 03:20:00 PM
you sir are a genious  8)
Post by: morrag on January 16, 2013, 04:53:49 PM
Nice, neat, and above all not overly complex piece of engineering, in fact, very tidy!, which is a notch up on "halfway-tidy", here in God's country!! ;D ;D ;D ;D ;D
Post by: Olds on January 17, 2013, 01:05:46 PM
Thanks.
Good news and bad news. Filled up the home made fuel tank for the first time and no leaks  ;D This meant that, for the first time, I could run the engine for more than 20 secs. Wont tick over though :( slight weep from the fuel pump outlet :(  the oil pressure switch is leaking where the terminal comes out  :((and the rocker box gasket is not doing a great job either, oil dripped down onto the fan belt >:(
 But on the bright side took the Dragstar for its MOT this morning and it passed no probs ;D  damned cold ride though,ice on local roads and started to snow on the way back. Glad I'm not a BRASS MANKEY
Post by: Manky Monkey on January 17, 2013, 07:15:22 PM
that's good news isn't it Dave?
A few small leaks are nothing to a man of your calibre!
Post by: Olds on January 18, 2013, 07:37:26 AM
Yep as you say good news. Think i've solved two problems. The rocker box gasket must have shifted slightly during fitting and the carb is pulling air from there. Hence the poor slow running and the oil leak. Should be OK now but can't test cos it's a bit early (fixed it at 4.30 this morning, couldn't sleep). Will order a new pressure switch later.
Post by: fifer on January 18, 2013, 02:44:20 PM
Here is one method of ensuring a good rocker cover seal seal  :)
https://sites.google.com/site/fifersrelianthintsandtips/rocker-cover/rocker-cover-gasket
You must be running the hose direct from the carb to the rocker cover ?
Post by: Manky Monkey on January 18, 2013, 03:36:16 PM
Dave, today would be the day to get out & grab those Father Christmas photos with the trike for next year's MMMotors calendar!
Post by: Olds on January 18, 2013, 04:13:42 PM
Fifer. yes, I know a lot of folk just blank off the carb and vent the engine to atmosphere but generally I've found a slight vacum on an engine helps keep the oil inside.
Andy. Yes it would be. I just tried to move the wifes car to do so, but with 6" of snow on the drive had a hell of a job. Sorry NO WAY am I going to ride the trike for the first in this.
Post by: Manky Monkey on January 18, 2013, 04:14:51 PM
 ;D
Post by: nabsim on January 18, 2013, 04:30:26 PM
Awwww, gowon Old :)
Post by: Olds on January 18, 2013, 04:38:41 PM
NO, NO, NO, well we'll see what it's like tomorrow :)
Post by: Olds on January 18, 2013, 07:52:27 PM
Heather braved it through the snow to deliver the steering lock today, so have made up a mounting plate and modified a couple of stainless hex drive screws to suit.
Now all I have to do is weld it to the lower yoke so the lock bolt hits the steering lock.
Simple and only cost £8.49
Post by: Manky Monkey on January 18, 2013, 08:26:18 PM
That's clever Dave. What's that from?
Heather the Post Lady tells me she went to school with you.
Post by: Olds on January 19, 2013, 07:55:58 AM
The lock is as used on Hondas like the old C50-70-90. It's a new pattern part, bought from Bike Business in Portsmouth, via Evilbay on Thursday arrived next day and the £8.49 included postage. I think that's pretty good value and service.
Yep we were at school together and so was Linda so we have known Heather for a long time, which is lucky, otherwise question might be asked about me taking the post lady into the garage  ;D As you know she has an interest in trikes.
Post by: Manky Monkey on January 19, 2013, 10:48:37 AM
Used to own one herself.
Post by: Olds on January 19, 2013, 01:10:15 PM
Steering lock fitted. Should keep Mr MSVA happy and it's another job off the list  :)
Post by: Manky Monkey on January 19, 2013, 07:24:11 PM
Could we have a clearer pic of that Dave? Maybe from above? Can't see how it works.
Post by: Olds on January 19, 2013, 08:38:07 PM
Not sure the pic will help much.
The lock is mounted to a plate welded to the bottom yoke. when locked, the lock bolt rises and stops the yoke from moving by hitting the steering stop lug that is welded to the rear of the headstock/frame.
Post by: steven brock on January 19, 2013, 08:47:54 PM
So does it lock or is it a pop up stop?
Post by: ROD on January 19, 2013, 09:47:52 PM
I hope it locks and doesnt pop up ;D
Post by: Olds on January 19, 2013, 10:07:15 PM
Sorry SB, I'm being a bit dense, not sure what you mean by a pop up stop. If you mean, can you push the lock bolt down then no, you need the key. Can confirm that it definitely locks the steering though ;D
To unlock, turn the key and the lock bolt (or pin) is pulled back down, flush with the mounting plate.
Post by: Manky Monkey on January 19, 2013, 10:26:35 PM
That's very clever Dave -& very simple, as all the best clever ideas are.
Post by: hunter on January 20, 2013, 01:07:21 AM
Can i ask if this locks on full lock,
Handlebars full left or right lock.
Post by: Olds on January 20, 2013, 08:28:59 AM
Full lock to the right. I know this is contrary to the norm for bikes but it is easier this way, the lock can be accessed curbside, saves walking around the trike and I always get on from the left anyway. It can also lock with the bars to the left but it leaves a lot of movement in the bars and access to the key hole isn't as good. As far as the MSVA is concerned it only has to stop the vehicle being driven straight ahead.
Post by: Olds on January 20, 2013, 11:55:05 AM
 Front spindle nut cover made and another use for rubber door stops :D
Post by: Mendalot on January 20, 2013, 02:48:33 PM
Are you going to hide the heads of the screws on the lock or are they anti tamper screws?   It may make a difference to the tester  :-\
Post by: Olds on January 20, 2013, 03:08:34 PM
They are anti tamper in as much as the hex has been rounded out after fitting plus the use of thread lock. Removing the lock will require removal of the yoke and drilling the heads off. That or cutting through the 6mm thick mounting plate. Either way, not something I'd want to do at the side of the road so better not lose the keys  ;D.
Post by: Manky Monkey on January 20, 2013, 07:24:02 PM
Love the rubber door stops!
What's that song -The king of wishful thinking.
I reckon you're the king of lateral thinking.
Post by: andyrennison on January 20, 2013, 07:48:19 PM
Like the lock idea, need something for mine, another idea to steal :)
Post by: panthershaun on January 21, 2013, 10:46:42 AM
a mate on his open roadster thingy build, had an exterenal hand brake lever that had a lug on it that you put a padlock through when brake was on, that was OK for the test..
Post by: Olds on January 25, 2013, 09:02:24 AM
Not that I have ridden the trike  ;) but think that I may need to fit a steering damper, until I change the forks for girders with less trail  >:( Also discovered that perhaps having the throttle on the left, may not have been such a good idea as I have a tendancy to get on the throttle, after a gearchange but before getting my hand back on the bars and the change in weight on the front wheel makes it a bit squirrely. Of course the snow don't help much.
Post by: WAYNE999 on January 25, 2013, 02:11:21 PM
According to the manual you can't use any of the braking system
Post by: andyrennison on January 26, 2013, 05:08:32 PM
That's a lovely picture
Post by: Manky Monkey on January 27, 2013, 07:41:48 PM
Yup, if we get organised enough to do a MMMotors calendar for next year that's going to be the December pic.
Post by: WAYNE999 on January 27, 2013, 10:32:51 PM
Could do with a santa sat on it ;D
Post by: Manky Monkey on January 27, 2013, 10:40:34 PM
Yeah, what we really wanted was Dave in a Santa suit, riding it in the snow, with the back piled high with pressies.
Post by: Olds on January 27, 2013, 10:57:00 PM
Took three attempts to get the trike out in the first place. Wasn't about to start playing Santa
While I had no internet had a play with photo editing
Post by: andyrennison on January 27, 2013, 11:20:26 PM
Its got beefier !
Post by: slippery on January 28, 2013, 09:09:15 AM
Now that's what i call rear wheels  ::)
Post by: Olds on January 30, 2013, 03:56:55 PM
I now have a VIN ;D Yep DVLA have issued a number
I know it's silly, it's just a series of alpha-numerics and its not the MSVA or V5 but this somehow makes the trike official.
Post by: Manky Monkey on January 30, 2013, 09:06:56 PM
Hurrah! One small step closer Dave.
Post by: fifer on January 31, 2013, 12:05:13 AM
Great News ; You are now in sight of the vinning post  ;D
Post by: Olds on January 31, 2013, 05:23:10 PM
 ;D
Number all stamped up on the headstock  :) Local garage wants £30 to put their rubber stamp on the confirmation bit  ???  I think that's a bit steep so will ask around. I don't mind paying for someones time but £30 for less than 15 minutes  >:(
Post by: ROD on January 31, 2013, 06:39:54 PM
I paid £10. Looking very nice ON.
Post by: andyrennison on January 31, 2013, 07:58:27 PM
Whoop whoop whoop
Post by: Manky Monkey on January 31, 2013, 08:49:46 PM
"Vinning post" -harr ha!
...I've only just got that.  :P
Post by: Olds on February 02, 2013, 02:58:38 PM
Oh #######
Left the trike idling for 15 minutes while setting up the carb etc. and it boiled over. Always knew that the tiny fan fitted to the waterpump might not hack it. Have fitted an electric one now which means I'll have to make a grill to hide it cos it's pugly. Also can't find anywhere to fit a thermostatic fan switch, so will probably fit a manual switch to the handlebars. Any ideas anyone?
Also the ###### tank sealer is starting to lift.
Post by: Olds on February 02, 2013, 04:57:23 PM
Wasn't happy about the plain vin plate I made, so made this one. Better but might try again. Depends on how bored I am tomorrow morning.
Post by: steven brock on February 02, 2013, 05:42:48 PM
How'd ya make that then
Post by: one arm bandit on February 02, 2013, 05:47:11 PM
beat me to it,   its a nice little touch me tinks ;)  aaaaahhhhhh uuummmm OAB ninja pig england aahhhh uuuuummmm
Post by: Olds on February 02, 2013, 08:48:16 PM
No, not gonna say!
Well OK then, Ferric Chloride.
Mask off the areas/ letters you want raised then dip the brass or copper into Ferric Chloride. This you can get from Maplins. It's used to etch circuit boards. Dont forget to mask off the back and edges of the plate as well though. Humbrol paint is good for masking. For lettering I use Letraset.
Post by: stumpy on February 03, 2013, 05:50:30 PM
very clever idea for all those in the cheap seats here is a link
http://www.letraset.co.uk/
will Ferric Chloride eat masking tape or fine line tape ?? do you think
Post by: Olds on February 03, 2013, 08:07:26 PM
Unfortunately Letraset have reduced their range of the traditional rub down lettering in recent years and also the number of sizes. I'm using up old stock.
Due to the length of time it takes to etch a decent depth, I think masking tape would absorb the acid. Pinstripe tape might do though but have not tried it.
Post by: hunter on February 03, 2013, 08:16:13 PM
I thought you were supposed to stamp the vin directly on the frame. ???
J should also say i love the idea. 8)
Post by: one arm bandit on February 03, 2013, 08:37:45 PM
think he has this is just a detail piece ;)
Post by: Manky Monkey on February 03, 2013, 09:51:31 PM
Yup, I believe Dave has the VIN stamped into the frame as well.
I saw him this afternoon & he showed me the brass plate. Very impressive -he's an annoyingly talented bloke! I'm hoping to persuade him to produce a MMMotors plaque to mount on the bulkhead of my truck. Being brass I can get it nickel plated.
Before you ask, he says no, he won't be making batches of them!
Post by: hunter on February 04, 2013, 12:24:32 AM
Was just thinking Aloud really ;)
Post by: spanners on February 04, 2013, 12:28:41 AM
thinkin aloud,,,, normally gets me a ,clip round , the ear ,, :D :D :D
Post by: merv on February 04, 2013, 08:30:14 PM
you and me both ;D
Post by: one arm bandit on February 04, 2013, 11:30:29 PM
you and me both ;D
ssshhhhhh mike didnt know you were there too
Post by: Olds on February 08, 2013, 09:17:26 PM
Fitted an electric fan a few days ago and was stuck for a way to operate it. Was going to go for either a manual switch on the handlebars or a thermostatic switch in the top hose. Both have problems, the top hose is too short and  I'd just forget about turning on the fan manually.
Rooting around in the garage, I came across the old, Kenlow adjustable fan switch and sender from my first Landy. The sensor bulb is too long to fit inside the top hose, so it's been wired to the rad core at the top, with the switch tucked up behind the headstock. Being adjustable it works a treat.
And cost nowt ;D
Post by: Manky Monkey on February 08, 2013, 10:58:41 PM
Clever solution Dave.
Post by: Olds on February 11, 2013, 11:57:09 AM
Thanks.
I know it's a bit late but have come across a pic of the frame, prior to final paint and assembly.
Post by: Manky Monkey on February 11, 2013, 04:17:51 PM
How did you manage to stick it to that pebble dashed wall?
Post by: morrag on February 11, 2013, 04:52:26 PM
It's not stuck to the wall, it's obviously stuck the the piece of 2"x1", and that's stuck to the wall!!, tsch.................some people :D :D :D :D :D :D :D
Post by: steven brock on February 11, 2013, 05:55:26 PM
How did he manage to spray it with no paint on the wall ???
Post by: Olds on February 11, 2013, 06:04:39 PM
 ;D Don't be daft, it's  not stuck to a piece of 2"x1". It's a length of, kiln dried, structural 4"x2".
What sort if idiot do you take me for! 2"x1" would be far to small to take the sort of cornering stresses a good pebble dash wall can generate.
Post by: darklancer on February 11, 2013, 06:29:03 PM
Very NICE TRIKE Sir! ;)
Post by: one arm bandit on February 11, 2013, 09:08:17 PM
you seem like quite an experinced bender old ::)
Post by: Olds on February 11, 2013, 10:03:10 PM
Not sure how to reply to that. ;D >:( :-*
Post by: Olds on February 12, 2013, 06:05:53 AM
Had problems sleeping, so attacked the brass brake cylinder cap, with etchant.
Think I may be taking this naming thing too far :-\
Post by: nabsim on February 12, 2013, 08:54:47 AM
Can you take it too far if its for yourself? Good work there Old
Post by: Manky Monkey on February 12, 2013, 10:31:47 AM
Got to find some bits on my truck for you to label Dave!
Post by: steven brock on February 12, 2013, 07:28:41 PM
How do you do this?
Post by: Manky Monkey on February 12, 2013, 09:10:08 PM
Acid etching. Dave called at Loony's workshop this morning. Loony reports that cap as "amazing".
Post by: steven brock on February 12, 2013, 09:19:52 PM
Do you print something then stick on and the exposed is etched away?
Post by: Manky Monkey on February 12, 2013, 09:35:13 PM
More or less. Dave's using "Letraset" lettering -a rub down transfer. Used to be common in technical drawing offices, but getting hard to find now.
Post by: scannerzer on February 12, 2013, 10:03:34 PM
ON that's ace,you made it yourself so why not personalise it
Post by: Olds on February 26, 2013, 08:57:50 PM
Just weighed the trike and was rather surprised. 285 kg (628lbs) with all fluids except fuel. This may seem a lot but it's lighter than all Harleys except the Sportsters and lighter than I was expecting. Thought I must have got it wrong, so did it again with different scales, nope, 97kg front and 94 kg each rear wheel.
The pickup rear seems to make it look heavier than it really is.
Post by: Mendalot on February 26, 2013, 10:23:34 PM
As I always say, it's all in the detail ....... and that Sir,   IS BL**DY MARVELOUS  8) 8) 8)
Post by: Olds on February 27, 2013, 06:43:52 AM
Thank you folks.
Replaced the rear gearbox seal this morning. Should have done it while doing the axle seals ::). With everything bolted down the prop wouldn't come out. Just fractionally too long to clear the flange centre nuts, so had to drop the gearbox a tad. With the prop apart I ground down the end of the male splined section (only 1mm) and now it fits in a treat.
Think the trike is now finished, well sort of, so sending off the MSVA application today.
Post by: steven brock on February 27, 2013, 09:35:01 AM
Great stuff my finishing seems to be taking years.. Lol
Post by: Manky Monkey on February 27, 2013, 09:10:35 PM
Woo hoo!
Good luck on the paper trail Dave. Having just completed the registration of my truck, I know how daunting it can seem, but must admit, looking back, it wasn't that complicated at all really. Honest.
Post by: Olds on March 05, 2013, 06:50:57 PM
Got the letter from VOSA confirming the date for the MSVA. 18th of this month and I am already bricking it. Not so much the test but mainly the hassle if it fails (don't fail, Don't Fail, DONT FAIL).
All I can do, is keep checking it over and try to find, possible reasons for failure..
Tiki Munki (Scottie) the Hot Rod Hauler of MovingHotRods.co.uk has been booked, so transport worries, have been taken care of.
Post by: scannerzer on March 05, 2013, 08:17:39 PM
good luck ON hope it all goes to plan
Post by: Manky Monkey on March 06, 2013, 11:57:42 AM
The very Mankiest luck to you Dave.
I think you're going to the same Southampton SVA test centre we took my truck to. I know exactly how you feel, but they really were very sensible, helpful guys. As they said, they're not there to stop custom vehicles getting on the road, but to make sure that those that do are safe & legal. Seeing the attention to detail & quality of your build, I'm sure you'll have no problems.
Post by: Olds on March 07, 2013, 07:48:24 PM
Thanks folks.
I bottled it today.
 The nice, neat, round, combination, rear lights I had fitted, weren't E marked and though the brightness and colour were good, decided to fit some E marked ones just in case. This also meant moving the reflectors again.
 Only one problem with the new lights, they are PUGLY
Post by: Mendalot on March 07, 2013, 07:58:02 PM
Change them back after the test ;D
Post by: Manky Monkey on March 07, 2013, 08:13:38 PM
Precisely.
Not sure they actually need to be E marked do they?
Post by: Olds on March 07, 2013, 10:00:13 PM
:o I am shocked that anyone would suggest such a thing. ;)
True but then it becomes a judgement call by the examiner, as to whether the lights are of equivalent colour and brightness etc.
All lights and mirrors are  E marked except for the front sidelights, which being from a 40s-50s military truck, are superbly made and I really can't see this being a problem.
Post by: WAYNE999 on March 08, 2013, 09:18:17 PM
The lights don't have to be E-marked but if they are there's no risk of a fail. I'm fitting the same ones to my trike £6 a pair from ebay but these will be changed after the test
Post by: Olds on March 18, 2013, 06:02:01 AM
MSVA day has arrived ! God I want this day over.
Had virtually no sleep last night. Not because I'm worried (which I am) but  because the Mother in law (86 & totally gone) has spent most of the night roaming around, turning lights on and off all over the house. She has Parkinson's and when she turns on a light it can be like being at a 70s disco.
Scottie is coming round to load the trike onto his truck this morning, then it's down to Southampton for the test.
Other than to do as Loony suggested, which was to cover the whole front end in foam rubber, I can't think of anything left to do now but pray to the Gods of sweat and tears.
Post by: WAYNE999 on March 18, 2013, 06:35:17 AM
Good luck mate
Post by: andyrennison on March 18, 2013, 07:34:39 AM
Good luck, i hope all goes well.
Post by: merv on March 18, 2013, 08:25:21 AM
All the best, hope it goes well
Post by: steven brock on March 18, 2013, 09:13:45 AM
If yours dont pass ill eat my hat.. Gudluck fella
Post by: mouse on March 18, 2013, 09:56:59 AM
Good Luck mate
Post by: Olds on March 18, 2013, 09:57:34 AM
Thanks folks. What will be etc. No time to change anything now  :-\
Post by: spanners on March 18, 2013, 10:37:28 AM
well it was st,patricks day yestrday , so may the luck of the irish be with you ,
it,ll be a doddle ,its so perfick,,,
fingers crossed ,, just for that extra bit of luck ,,
Post by: kinkytriker on March 18, 2013, 12:36:46 PM
that beauty will fly through, good luck ;D
Post by: Olds on March 18, 2013, 03:54:01 PM
IT PASSED ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Post by: kinkytriker on March 18, 2013, 04:00:43 PM
hahaha well done, only a blind man would fail it  ;D ;D ;D ;D
Post by: steven brock on March 18, 2013, 04:21:59 PM
Excellent..
Post by: Olds on March 18, 2013, 04:38:41 PM
The only thing that caused a bit of a problem, they didn't know what to put down on the paperwork, they couldn't work out if it was a goods vehicle or not. Only took half an hour to sort out, seems it could be  ???
A big thank you to Scottie (www. movinghotrods.co.uk) for all his help today.
A genuinely great guy who I am sure I will end up calling if I need another vehicle moving :)
Oh and thanks to all you monkeys
Post by: TwistedPatience on March 18, 2013, 04:56:34 PM
Congratulations look forward to seeing it at Basingstoke show
Post by: Olds on March 18, 2013, 05:01:36 PM
Insurance - MOT - Number plates - Basingstoke Show  ;D
Post by: merv on March 18, 2013, 05:05:34 PM
Well done Dave,must be a great sense of achievement :)
Post by: WAYNE999 on March 18, 2013, 05:24:13 PM
good show old boy ;D
Post by: thebigdogsix on March 18, 2013, 05:24:28 PM
Well done its a great feeling  :)
Post by: scannerzer on March 18, 2013, 08:00:25 PM
well done ON
Post by: Manky Monkey on March 18, 2013, 08:11:48 PM
I remembered to send you a Good Luck text this morning -but forgot I didn't have your number.  :P
Now get out there & enjoy the fruits of your labours.
Post by: tikimunki on March 18, 2013, 08:25:50 PM
One happy chappy !!!
(http://i300.photobucket.com/albums/nn10/movinghotrods/trike_zps00622cb4.jpg)
and snack wagon round corner does a great cup of T
Post by: Manky Monkey on March 18, 2013, 08:34:48 PM
Aah, the Southampton VOSA test station. Spent far too long there myself waiting for test results.
Really pleased for you Dave.  ;)
Post by: trikerpete on March 18, 2013, 08:47:21 PM
Congratulations to you Dave
Post by: Olds on March 18, 2013, 09:36:22 PM
Thanks peeps.
What all the nerves were about-
Post by: Olds on March 18, 2013, 09:41:32 PM
Makes Scotties truck look huge. Recon with careful positioning you might get four trikes on.
Post by: steven brock on March 18, 2013, 09:50:36 PM
Great pic  :)
Post by: Manky Monkey on March 18, 2013, 10:14:51 PM
Scottie the hotrod haulier's the nicest guy in the world ain't he. Mad as a box of frogs, but nice with it.
Post by: hunter on March 18, 2013, 10:49:53 PM
That looks really nice up there well done mate.
Post by: Mendalot on March 18, 2013, 10:53:33 PM
Well done that man, we all likes good news, buddy.  We now need to pray to the weather gods, to give us a half decent summer, so you can enjoy the fruits of your labour ;D ;D ;D
Post by: fifer on March 18, 2013, 10:55:14 PM
Deliverance ;
Delivered  :)
Congratulations  :) .
Post by: andyrennison on March 18, 2013, 11:40:30 PM
Well done and congratultions. Bet yoiu are still buzzing and dont sleep again tonight. Very pleased for you.
Post by: Olds on March 21, 2013, 01:06:34 PM
Once again thanks guys.
Got an insurance quote of £252 fully comp from Adrian Flux (Bikesure) with a value of £8000 and mileage limit of 1000 ;).
Are there better/cheaper insurers that you know of ?
Post by: hunter on March 21, 2013, 01:17:48 PM
Although a lot of trike owners don't do a lot of lot of mileage i think the 1000 miles restriction is a joke.
Post by: Olds on March 21, 2013, 01:43:43 PM
Don't worry about the milage limit. I suggested it to get the price down.
With three cars and two bikes mileage on the trike is going to be low  ;).
Think I will have to drop the value to see if I can the price down
Post by: hunter on March 21, 2013, 01:54:36 PM
I mentioned the mileage Because i have a policy with flux,And have the same restrictions.
Post by: Manky Monkey on March 21, 2013, 03:06:25 PM
If it's any help Dave, I insured my truck with Adrian Flux. 5,000 miles a year, fully comprehensive cover, £10,000 value.
£266. Do you actually need fully comp'? If it got damaged you'd probably repair it yourself anyway. That would drop the price.
I think what you've been quoted is about average.
Post by: trikerpete on March 22, 2013, 01:46:02 PM
Personally I only ever insure as T.P.F & T. As Andy says should it ever get damaged no garage/bike shop would want to repair it. I'm currently with "Whittlesey Insurance" for about £120 & 5000 miles P.A.
Post by: WAYNE999 on March 22, 2013, 04:43:41 PM
Me too but we can get around this by owning several speedos ;)
Post by: Olds on March 22, 2013, 07:04:49 PM
£147 tpf&t / 3000 miles. Thanks Pete
Post by: Olds on April 05, 2013, 04:49:28 AM
First real road outing (for the MOT) is on Monday. Not sure how the trike will handle, as so far all I've done is fairly low speed moving it about. This at first scared the wotsit out of me. 40 years of riding bikes and I found myself pushing the bars the wrong way, didn't realise quite how much counter steering had become an automatic reaction. Also clipped my first curb with a back wheel the other day. No damage but thinking of making an idiot sign to go on the handlebars to remind me that it's wider at the back than the front. ::)
 As I posted elsewhere the weight ticket has reared it's ugly head, after DVLA phoned and asked for a scan of the MSVA certificate. They decided that a weighbridge ticket would be required, as VOSA had put down the unladen weight. When I asked what the weight ticket should show, the answer was unladen. ???
It's not a big thing, I was just trying to rationalise the registration procedure to as few steps as possible
Post by: scannerzer on April 05, 2013, 12:40:56 PM
Bet your looking foward to you first long spin,hope all goes well
At mot I'm sure it will you've done a good job of your trike,good luck
Post by: trikerpete on April 05, 2013, 04:42:15 PM
Good luck for MoT  & remember....your triangular now, so mind the rear wheels ;) :)
Post by: Manky Monkey on April 05, 2013, 04:43:37 PM
Dave called at Loony's workshop this afternoon. I'd finished my Postal delivery & was killing some time before going back to do some overtime, so just happened to be there when he rode in.
I can confirm the "Deliverance" trike looks as good in the flesh as it does in photos. A beautiful job Dave.
Post by: Manky Monkey on April 05, 2013, 04:44:34 PM
Post by: Manky Monkey on April 05, 2013, 04:45:29 PM
Reversing.
Post by: Manky Monkey on April 05, 2013, 04:46:36 PM
And heading for home. Good to see you Dave.
Post by: Manky Monkey on April 05, 2013, 04:48:12 PM
Post by: morrag on April 05, 2013, 06:20:12 PM
What a very nice series of pics. of a particularly nice trike. Indeed something removed from the usual, and executed really well, nice one and an "'atta boy" to builder and photographer, really nice to see, and should prove an inspiration to those currently struggling on the enthusiasm front, perhaps :P :P :P :P :P :P :P.Morrag
Post by: tbone on April 05, 2013, 08:03:34 PM
Have to agree with all the comments, very nice sir.
Post by: Olds on April 05, 2013, 08:23:54 PM
Thanks. Must admit that I'm rather pleased with the way it turned out in the end. Still some bits I'd like to change but that's always the way.
Nice pics Andy  ;D
Now have the weight ticket so that bits out of the way. Now just MOT and visit to DVLA.
 Beginning to think the end might at last be in sight.
 Our local weighbridge is only about 400 yards from Loony's workshop and a round trip of only 10 miles from home. Surprisingly nothing broke, fell off or failed to work . :D
Post by: Manky Monkey on April 05, 2013, 09:53:04 PM
That's more than I managed on the maiden voyage of my truck Dave!
Always got the camera with me -you never know what might turn up.  ;D
Post by: Al on April 06, 2013, 12:31:16 AM
really nice clean looking trike dave well done
Post by: andyrennison on April 06, 2013, 08:14:13 AM
That is a lovely trike, well done indeed Dave. If mine is 1/2 as good I would be pleased. Fantatic jobs :)
Post by: steven brock on April 06, 2013, 08:17:19 AM
Manky pilgrimage this could catch in  ;D
Post by: Olds on April 07, 2013, 05:41:31 AM
Have decided that the seat I made is a little short, so am making a new one.
3mm aluminium base plate.
Post by: Olds on April 07, 2013, 05:47:23 AM
Foam made up in layers
Post by: scannerzer on April 07, 2013, 10:43:57 AM
Your a talanted man ON, I would like to build a seat for the savage as it
causes numb bum after about an hours ride, how do you know what grades
of foam to use in each layer and it it available mail order?
maybe a "how to" feature ?
Post by: merv on April 07, 2013, 12:45:28 PM
                                        "how to" feature ?
                                                      What a great idea
Post by: Olds on April 07, 2013, 08:15:58 PM
Being as the seat is sprung and the leather thick, the foam is very high density (10mm sleeping mat). Its more to give shape and grip than comfort. A bit like a horse saddle but it does have a bit of give to it.
As for a how to, this is just the way I do it. there are probably better ways available on the net, but will continue to post pics and perhaps short descriptions as I go.
The leather was soaked for a couple of hours then stretched over the foam and base, then, left for an hour and retightened. At this point the bottom layer of foam is not fitted. This will go in later to ensure a tight fit. I will now leave it overnight and start heat shaping it in the morning.
Title: Re: Deliverance
Post by: Olds on April 08, 2013, 04:38:33 AM
After leaving the leather to stretch overnight (well to 4am) using a suitable heat source (a hot plate, oops) the leather was dried and shrunk moulded, especially around the edge. Each time an area was heated, (until it starts to steam) the leather's pressed against foam.
In the past I've found that a heat gun tends to dry the surface too quickly and that radiant heat works best.
Post by: Olds on April 08, 2013, 05:27:15 AM
It's now at the point where the leather will keep the shape when removed from the base & foam.
BTW forgot to say the foam was covered in cling film to prevent it getting wet and drying the leather too quick.
Post by: scannerzer on April 08, 2013, 06:03:47 AM
Looking good
Post by: hunter on April 08, 2013, 11:07:21 AM
Nice one Old,Is that leather or vinyl.
Post by: Olds on April 08, 2013, 04:41:58 PM
Leather.
MOT passed this afternoon ;D
No advisories, just lots of questions like, who made it, who made the frame, how long did it take etc. Now just need to go to the local DVLA with the paperwork.
Nearly there  :D
Post by: scannerzer on April 08, 2013, 08:03:59 PM
told you didn't need to worry ,very well done  8) 8)
Post by: Manky Monkey on April 08, 2013, 08:06:24 PM
Congratulations Dave!  ;D
Post by: andyrennison on April 08, 2013, 08:26:35 PM
All over bar the shouting. Well done indeed :)
Post by: Olds on April 08, 2013, 08:48:32 PM
Thanks guys :)
Will try to get over to the DVLA tomorrow but family matters may (probably will) get in he way.
Hopefully be able to give MM, the registration number, for the Basingstoke show soon ;D
Post by: trikerpete on April 08, 2013, 09:12:50 PM
Congratulations young man ;) :)
Post by: hunter on April 08, 2013, 09:25:20 PM
Well done Dave.
Post by: fifer on April 09, 2013, 06:00:12 AM
Congratulations ; there was never any doubt that it would pass ;D ;D
Post by: Olds on April 09, 2013, 09:47:09 PM
Thanks. No chance to go to DVLA today :'( but did some more on the new seat.
The leather has been glued to the top surface of the foam. This is not normally done but this seat is sculpted.
The second seat base is made out of 1mm steel. The reason for two bases will become apparent.
Just noticed that It's been eight months since I started posting about the trike under the heading Nearly finished ?
 Finishing has taken longer than I thought :)
Post by: Olds on April 10, 2013, 12:17:59 PM
Spent all morning at the DVLA. All paperwork ok but they have decided that despite having the V842 stamped by a garage confirming the vin is stamped correctly, the MSVA certificate from VOSA which you can't get without the vin stamped and a MOT certificate from a different garage, which once again you can't get without the vin stamped, they want trike taken to the office so someone can see if it's got the vin number on it. ???
ARRRRGH >:( >:( >:( >:( >:(
Post by: spanners on April 10, 2013, 12:36:04 PM
they will have you walking a tight rope, and jumping through hoops whilst whistling ,dixie, next  ::) ::)
Post by: Dslam on April 10, 2013, 04:28:55 PM
In my experience this is normal. You should find the inspector is fine and is only ratifying what is on the paperwork to help prevent fraud. Just go with it and all will be well.
Post by: Manky Monkey on April 10, 2013, 07:46:11 PM
Welcome to my World Dave! As Mr Slam says, just roll with it -it could be a lot worse. One more tiny hurdle & you'll be roadworthy & completely legal!
Post by: Olds on April 10, 2013, 09:15:18 PM
Well I'm in trouble then.
Can't whistle!
I know. Just can't work out why they made me pay (and go through the hassle) to get a V842 certified to prove that it's been stamped.
I keep on rolling but am ending up a bit bruised. And a lot lighter in the pocket!
Scottie is once again coming to the rescue, transporting the trike for me. ( www.movinghotrods.co.uk) For which I am very grateful,  I know he's had to rearrange things to do this.
Post by: Manky Monkey on April 10, 2013, 09:20:30 PM
He is indeed a diamond geezer.
With luck, both Scottie & Old Newbie should be displaying vehicles on our pitch at the Basingstoke Festival of Transport next month.
Post by: Olds on April 13, 2013, 07:16:52 AM
Yep. If I manage to get it registered in time I'll be there ;D
Done no more on the new seat recently but will get back to it today. Had a bad night so made up the nameplate to go on the tailgate.
The recessed etched area has been filled with a mix of paint and lacquer to try to get a effect similar to the old style enamelled badges. when its fully dried out (it's in the oven at a low heat) I will bevel the edges before final lacquer.
Post by: Manky Monkey on April 13, 2013, 05:42:47 PM
Is there no end to your talents?!
Post by: trikerpete on April 13, 2013, 08:16:06 PM
hhmmm you clever old bugger  :) ;) :D
Post by: Olds on April 14, 2013, 07:20:26 AM
 ;D
Got a bit more done on the seat. Three holes drilled through to match existing mount and two M8 bolts welded through the rear holes to attach the springs to. I used calliper mount bolts as these have a large head, low profile and happen to be laying around. The front mount hole has a M8 nut welded on. Also a stiffener was welded down the centre line of the of the steel seat pan.
Apologies for the poor quality welds but all I have left are 3mm rods. None of this will be visible anyway ;)
Next will be the hard bit. Sewing. Not looking forward to this and it might take some time as the leather is 2mm thick and sewing through 4mm of hide is hard on these old hands.
Post by: Olds on April 15, 2013, 10:34:12 AM
Seat is now finished.
Instead of sewing all round I decided to stretch and glue the leather over the lip of the steel base, only sewing at the two rear pleats and the nose section. The aluminium base was then persuaded into place and the steel lip now covered in leather rolled over slightly holding everything in place tightly.
Post by: Olds on April 15, 2013, 10:43:28 AM
New compared with the old.
On the trike the new one is really comfy :D and moves the seating position back far enough, that I can grip the tank with my knees, without smashing the left knee on the carb.
Might fit a pair of small vintage John Bull knee grips :-\
Post by: Olds on April 16, 2013, 11:02:11 AM
Well the quest for the Holy Grail ( registration number) continues. ::)
Spent the morning with Scottie, taking the trike up to Theale DVLA office and back, to let a gentleman look at the numbers stamped on it.
The only question asked was, whether the pick up bed was removable  ???
The registration number, should be sent to me in the "next few days". Not quite sure what counts as a few days, DVLA seem a bit vague about that.
Post by: spanners on April 16, 2013, 11:06:00 AM
i,v been on the phone to DVLA >:( >:( >:( this morning,, they have ,,lost,, my v5. :o :o and say i have to re-apply for it, >:( >:( i,m ,NOT,, a happy monkey,,,
Post by: Olds on April 18, 2013, 07:01:44 PM
Still waiting on DVLA. Feel I should be like a kid waiting for Christmas but for some reason I'm not. Perhaps it's just taken too long. Might just be post-build blues. Will start thinking about the next project whatever that might be.
Any suggestions?
Post by: Olds on April 19, 2013, 09:28:34 AM
DVLA saga.
Looks like the DVLA interpretation of "next few days" is different to mine.
Didn't actually expect speedy results but thought I'd chase them a bit today. When the LO called back, seems nothing had been done since I took the trike up on Tuesday morning. The paperwork was waiting for the managers signature before being processed. A very nice lady said that she would put it on his desk.
Looks like the first months tax and insurance that I have already paid for will be a total waste and the cover note for the insurance may run out before they issue the reg. number. God only knows what will happen then. I expect I will have to go up there for a third time.
Post by: Manky Monkey on April 19, 2013, 02:20:53 PM
Hang in there Dave. The paper trail seems to be more hassle than the build for everyone, but you'll soon be totally legit. I definitely needed a break from mine when the registration process was all over, so I know how you feel. Once the plate & tax disc are on though, it'll be waiting for you in the garage whenever you want to ride it.  ;D
Post by: ROD on April 20, 2013, 11:38:48 AM
At least youre getting there ON.
Post by: Manky Monkey on April 20, 2013, 07:04:11 PM
Dave dropped in at Loony's workshop this afternoon cos he was in the area. Nice to see you matey & apologies for not chatting more, (Chris & I were working on my truck -well he was working. I was getting in the way).
Don't get disheartened Dave. You're very nearly there now.
Post by: Olds on April 20, 2013, 09:12:31 PM
Yes I know :)
Small problem with the engine. Cooling system pressurising, noticeable oil consumption, slight amount of oil in coolant, very sooty number three spark plug.
That folks means a new head gasket is required. :( On the bright side, there is no coolant in the oil. :)
Lifted the rocker cover to find the cylinder head nut between number 3 & 4 cylinder loose. Yes I know, I should have rebuilt the engine. Just hope the head is not warped. Not a lot I can do till I find a new gasket so plan on having a quiet Sunday.
Post by: spanners on April 20, 2013, 09:21:24 PM
Yes I know :)
head sets are quite easy to get ,, there was some on evil bay ,, if you get stuck shout , as i should still have a spare head set in stock                     ( somewhere  ::))
Post by: Olds on April 20, 2013, 09:27:53 PM
Cheers mate. I'll see what I can find on Monday. If I'm really lucky one of the local factors will have one.
Post by: Olds on April 23, 2013, 04:20:04 PM
Lovely weather, sun shining, not too hot, perfect for taking the trike out  :D  but I can't  :'( :'( :'( :'(
Still waiting on DVLA  >:(
Think I may go to Theale tomorrow, to find out what's happening.
Post by: Manky Monkey on April 23, 2013, 07:45:10 PM
At least it's not too far to go Dave.
I should be out driving my freshly registered hotrod, but got the carb off & in bits at the moment, so it's going nowhere, so I know how you feel.
Post by: Olds on April 24, 2013, 04:31:07 PM
Didn't have to go to Theale. Which is lucky because I wasn't in the best of moods.  DVLA phoned me first thing this morning. At first there was a bit of a panic because they couldn't find my application  >:(  A very nice lady phoned back after 15 min and said it would be processed today and put in the post 1st class this evening. She did however tell me what the number would be  :-X :) The  ;D face will have to wait till I actually get some documentation.
It's a shame about the pop Andy, but better to get it running properly, than risk damaging the motor, or getting frustrated with it not being right.
Post by: Manky Monkey on April 24, 2013, 08:04:30 PM
That's fantastic news Dave. So have you got a Q plate?
We were saying at the workshop this evening, that, (touch wood), the Pop hasn't actually let us down & left us stranded anywhere yet. We fully expect a bunch of teething troubles. At the moment we're just fine tuning things.
Come & see us again on the trike as soon as you get that number plate fitted!
Post by: Olds on April 24, 2013, 08:37:21 PM
Yep it's a Q. The guy at DVLA was surprised that I was totally ok about getting a Q plate but I think it shows that it's been registered correctly.
When I was getting insurance, the company almost insisted that it be a Q but I don't know why.
It's all down to waiting for the Posties to do their bit now.  ;)
Post by: Manky Monkey on April 24, 2013, 09:04:30 PM
We'll do our best Dave!
Although my truck's Q plated, the insurance company still wanted to know the date of manufacture of the original vehicle.  ???
I agree, the Q suffix shows you've correctly registered your vehicle -something to be proud of.  :)
Post by: Olds on April 25, 2013, 07:36:06 PM
 ;D Now part of the Q continuum  ;D
Could have kissed our postie when she delivered the documentation, but Mrs Old was behind me and that would not have gone down well.
Post by: Manky Monkey on April 25, 2013, 08:20:46 PM
And Heather the postwoman's hubby's a postal manager.
Congratulations Dave. Roadworthy at last! Now get out there & enjoy the fruits of your labours!  ;)
Post by: BikerGran on April 25, 2013, 09:34:07 PM
They probably think so too!
Post by: andyrennison on April 25, 2013, 09:53:43 PM
Well done - excellent result :)
Post by: kapri on April 26, 2013, 07:15:37 AM
Well done ! Love the 'Q Continium' , got 2 Q's myself  . Also ' Q for Quality' ;D
Post by: spanners on April 26, 2013, 07:30:50 AM
Q705 E,lderly A,ged N,ewbie   :D :D
Post by: Olds on April 27, 2013, 05:49:44 AM
;D Yep, that's me.
Post by: scannerzer on April 27, 2013, 06:12:51 AM
time for some road trips then  ;D ;D
Post by: merv on April 27, 2013, 08:02:12 AM
Nice looking trike
Now go an enjoy
Post by: blair on April 28, 2013, 08:31:27 AM
well done
Post by: Olds on April 28, 2013, 06:39:11 PM
Couldn't put off pulling the head off when I realised that I could set fire to the engine breather tube like a Bunsen Burner :o
No need to hit it, once all nuts were removed the head lifted straight up,
Not a pretty sight.
Post by: Olds on April 28, 2013, 06:47:28 PM
Luckily all the bores are damn near perfect and the pistons, once wiped with petrol damped cloth turned out to be new :o
Looks like someone, has rebuilt this engine very recently, but didn't torque down the head or clean the old gasket residue off the block ???.
Putting it back together will have to wait till tomorrow. The lights have gone fut in the garage and being as it's Mrs Olds birthday I suppose I'd better spend a bit of time with her.
Post by: BikerGran on April 28, 2013, 11:13:27 PM
That's amazing - just a wipe?
Post by: hunter on April 28, 2013, 11:27:48 PM
Tis like new.Lucky man.
Post by: Olds on April 29, 2013, 06:07:02 AM
Yep and the good news doesn't stop there. The head seems to have new set of valves and stem seals  :D
No need for a decoke and all valves seat perfectly.
Only question is why do all this and then not torque down the head properly ??? and what else have they done wrong?
Pic of head after wiping off the oil and gunk with a rag.
Post by: BikerGran on April 30, 2013, 07:45:16 PM
Forgot?
Post by: Olds on May 01, 2013, 08:00:32 PM
Maybe!
Trikes back on the road again. Just trundling around the village at the moment to make sure every things ok.
At one point the wife happened to be following in the car, when I asked how it looked, hoping she might say great or nice or even ok, the reply I got was " like some old fool on a tractor" :o
Post by: trikerpete on May 01, 2013, 08:22:07 PM
at least its a tractor some old fool built himself  :D :D
Post by: merv on May 01, 2013, 08:25:26 PM
Ha ha ha , that's something my wife would say also
Post by: andyrennison on May 01, 2013, 09:54:59 PM
I would take that as a complement
Post by: Olds on May 01, 2013, 10:07:08 PM
Well it could have been worse  :D
Post by: Olds on May 03, 2013, 01:44:11 PM
Got the V5C today ;D
It's wrong  >:(
The engine number is incorrect and I know it's not my fault.
Gave Swansea a call and now I have to write a nice letter explaining what a lot of the situation and asking them to correct it. This I will send recorded delivery after the problems I and others on this site have had in the past.
Some mention of having to get it inspected >:( again >:( >:(
Rant over.
Post by: kapri on May 03, 2013, 04:06:44 PM
They got my chassis number wrong on my post SVA lobook, just like Andys  ::)
Post by: spanners on May 03, 2013, 04:16:27 PM
well,well, i wonder, ::) ::) ::) what are they going to send back to me  :-\ :-\ :D
Post by: Manky Monkey on May 03, 2013, 06:22:23 PM
The chassis number was correct, but they got the body type wrong. I had to send them a photocopy of the SVA certificate to show it's a pick-up & not a saloon.
Post by: Olds on May 03, 2013, 08:29:38 PM
DVLA didn't return the MSVA certificate but I kept a scan copy. However that doesn't show the engine number. That was written down on the V627/1 inspection report which I don't have a copy of.
The V5C also doesn't have the model name on it but at least the make is down as OLDS.
Remember folks keep copies of everything and I mean EVERYTHING
Post by: BikerGran on May 03, 2013, 09:32:34 PM
Ever wonder whether some of this is deliberate?
No of course it can't be - can it?
Post by: trikerpete on May 04, 2013, 04:14:35 PM
 Any paperwork I send to DVLA is always to be signed for  :)
F**k knows what its going to be like when all the regional offices shut down..i cant wait  ::) ::)
Post by: Olds on May 10, 2013, 10:24:36 AM
After just 30 or so miles the sidewalls on the new front tyre started to crack :o
 The "new" front tyre that came with the wheel, is obviously a very old unused tyre :(
I ordered a new Avon triple duty from M&P on Tuesday for definite delivery today. :)
 Glad I phoned to confirm delivery. It hadn't left the warehouse yet so wouldn't get here till Monday at the earliest.  >:(
With the Basingstoke show being on Sunday that's not a lot of use to me. ::)
 None available locally but Micheldever tyres promise to have one in for tomorrow morning. :-\
Post by: Olds on May 11, 2013, 07:45:33 AM
 >:( Micheldever tyres just called and said the tyre didn't arrive. Will be Monday!
Trike up on stands, front wheel out and tyre off.      Oh sugar!
Well at least they called before I set out,  which is probably for the best, as I wouldn't have been a happy bunny.
Looks like either the existing tyre or one I removed from my old Harley will be going on for Sunday.
Post by: Manky Monkey on May 11, 2013, 08:21:08 AM
At least you have the know-how to fit tyres yourself Dave. Never fitted one in my life.
Post by: Olds on May 12, 2013, 08:09:53 PM
Bought a new tyre at the show today. Longstone 3.50 x 19. Have heard some good things about these. Higher load and speed ratings than the Avon and a period tread pattern.  :D
Fitted easily and now I have a road/tyre contact patch 70mm wide instead of just 20mm with the old bike tyre.
Post by: Manky Monkey on May 12, 2013, 08:38:21 PM
Fitted already? How'd the trike handle in the rain on the way home Dave?
Post by: Olds on May 12, 2013, 08:47:58 PM
Yep. Nothing else to do.
Trike handled fine until I pushed it into a corner a bit fast :o Lots of grip at the back, sod all at the front.
Post by: Manky Monkey on May 12, 2013, 08:56:38 PM
Yeah, you can't ride 'em like a bike can you. Got to lead the front end into the bends, rather than racing up to the corners & throwing it over onto full lock at the last minute. Otherwise you tend to go straight on.
Lots of favourable comments on your handiwork at the show today mate.
Post by: Olds on May 12, 2013, 09:00:00 PM
 ;D
I must try to get something different done for next year.
Post by: Manky Monkey on May 12, 2013, 09:03:36 PM
At the speed you work, you should have a whole fleet of trikes by then.
Post by: spanners on May 12, 2013, 09:17:43 PM
olds,,, what are you like at OLDS--MOBILE engines ,,?
Post by: Olds on May 13, 2013, 06:15:13 AM
If you mean the LV8-260, made from 75 to 82 and fitted with a single, dual jet Rochester. Sod all. In fact that's the total sum of my knowledge of these engines. :-[
Post by: spanners on May 13, 2013, 07:08:58 AM
If you mean the LV8-260, made from 75 to 82 and fitted with a single, dual jet Rochester, sod all. In fact that's the total sum of my knowledge of these engines. :-[
yep thats the one ===================================soddin, boat anchor ,,
Post by: Olds on May 16, 2013, 06:38:55 PM
The trike has been running hot and not a lot of umph. At first I thought carburation, seeing as both exhaust and air filter are not as Reliant would fit but no matter what I did to the carb, it made no difference. Today I remembered that when I set the ignition timing I used the Haynes book of lies. At the time I thought static timing at TDC a bit odd, so to hell with Haynes and set the timing to 10 degrees BTDC.
Took a spin around the ring road then out to Loony's workshop and no overheating under load or stationary and it goes quite well. Actually it goes very well   :D
The new tyre has also transformed the steering. It's still heavy at speed ( too much trail ) but the low speed flop has almost disappeared, feels more stable going into corners, with the bonus that the front wheel doesn't lock up when I touch the front brakes in the wet.
The rear brakes are bedding in and will need adjusting soon.
 All in all good afternoon ;D
Post by: Manky Monkey on May 16, 2013, 08:51:27 PM
Sounds like you're at the same stage of your build as me & my truck Dave -all the hard work's done, just got to get the damn thing running right. You seem to be on the right track though.
Post by: WAYNE999 on May 17, 2013, 06:13:17 AM
Ooh you've not  lived.All the swearing,the throwing of tyre levers then the nipping of the inner tube between the levers and the rim then having to do it all over again
Post by: fifer on May 17, 2013, 06:28:29 AM
Aye , but then you get older and wiser and inflate the inner tube before fitting the second bead  ;D ;D.
Post by: Olds on May 17, 2013, 07:11:35 AM
 ;D
I have NEVER fitted a tubed motorcycle tyre using tyre levers. They are only for removing the tyre.
If you ensure that the bead is in the well as it is fitted, the last section can be persuaded on by foot (wear stout shoes)
Lubricate well using French chalk (talc) of if desperate a little washing up liquid.
Post by: Olds on May 17, 2013, 06:28:05 PM
Things were going too well. Took the trike out this morning and when I got back noticed a strong smell of fuel. Carb was dripping petrol down onto the alternator (and my left leg) >:( No it wasn't coming from the overflow/vent. It was the feed pipe from the bottom of the float bowl.
The rubber gland had started to disintegrate (ethanol ?)
Have temporarily made a new one from a small grommet, which will probably dissolve so I will have to find a new one.
Moss do them for 80p.
I expect I will have quite a few little problems till things settle down. Just glad this one didn't catch fire :)
Post by: Manky Monkey on May 17, 2013, 08:06:37 PM
I'm having problems with constantly sticking floats in my truck's carb. Chatted to Miles at Jackhammer rod parts shop the other day & he said several customers have reported the same. He suggested the new Ethanol mix in fuel was to blame too & that maybe a lead additive in the fuel would help lubricate things.
Post by: Olds on May 20, 2013, 11:16:09 AM
The new V5c arrived today  ;D despite the fact that Post Office tracking shows the old one still hasn't been delivered to DVLA (wonder if I can get my £1.70 back ;) )
All the numbers etc. on it are correct this time, but it still hasn't got Deliverance as the model (not that fussed) and have noticed that the revenue weight is 280 kg. This is the figure I came up with, confirmed by VOSA but 40 kg lower than the weighbridge figure (lot of chalk on the plate, it's a quarry!). If they are not going to use the weighbridge figure why did I have to get the trike there, get it weighed and pay for it ?
Never mind It's all done now. :)
Post by: hunter on May 20, 2013, 11:46:21 AM
So result at last,
If we get a summer you'll have plenty of fun riding it.
Post by: Manky Monkey on May 20, 2013, 03:48:40 PM
Don't try & understand DVLA logic Dave. It's like Royal Mail logic -bears no relation to the real world at all. Just enjoy your labours.
Post by: Olds on May 20, 2013, 06:49:32 PM
So far it's been out almost as much in the rain as when it's dry. Why am I always busy on nice days
  I prefer not to get wet, but at least an off is less likely ;D
I am  ;D
Post by: Olds on May 25, 2013, 05:24:45 PM
Had a lucky day :-\
New choke lever arrived, so after a nice trip out on the trike in the sun, to get a cable, I started to fit it. Unfortunately our cat decided to watch and when I stepped back and trod on his tail, things started to go wrong. Afore said cat hissed, spat and clawed, I tripped over and smacked my knee hard against the air filter. The filter mounting got bent and the manifold adaptor, broke at the weld between the steel tube and the iron elbow.
Was this lucky?  I was at home where I could fix things and not at the side of the road.
The cat by the way is fine. At least until I catch him.
Post by: BikerGran on May 25, 2013, 07:42:11 PM
 ;D
Post by: Manky Monkey on May 25, 2013, 08:44:31 PM
Shouldn't laugh, but that's funny!
Post by: spanners on May 25, 2013, 09:05:09 PM
 :D :D :D CUCKIN FAT  :D :D :D
Post by: Olds on May 27, 2013, 04:48:12 AM
Went for a ride yesterday and performance started to drop off. Ignition felt retarded.
When I pulled off the distributor cap I noticed small specs of blue inside. The heel of the points are wearing at an incredible rate, yes the points cam is smooth and the felt pad is oiled.
The points are the ones that came with the engine. They looked new ( just like the pistons, valves etc.) so I left them in.
I know there are some dodgy points sets out there, so today will look for some of better quality and maybe look into electronic for the future.
One day I will ride the thing and not find another problem  :D
Post by: Olds on May 27, 2013, 04:01:22 PM
Needed a small tool/storage box, the pickup is great for moving stuff but crap at keeping things safe.
I was going to make one then I found this.
Post by: Olds on May 27, 2013, 04:08:34 PM
It's from a Massey Ferguson tractor. Mrs Olds nearly peed herself laughing when she found out as she thinks the trike looks like one >:(
At £21 including delivery wasn't worth making one. A magnet behind the bed holds the lid up when open.
Post by: Manky Monkey on May 27, 2013, 05:28:07 PM
Very nice Dave. Made for the job!
Not melting the points by using the wrong coil are you?
Post by: terry t on May 27, 2013, 06:47:26 PM
its taken me 4 years Dave. think its ok now ;D just under 800 trouble free miles since Jan this year
Post by: Manky Monkey on May 27, 2013, 08:46:56 PM
100 trouble free miles in my truck -now I've got to replace a bent pushrod.
The joys of customising!
Post by: triker_Chewie on May 28, 2013, 01:47:22 AM
toolbox looks great! like it grew there
Post by: Olds on May 28, 2013, 04:05:04 AM
 :) Not perhaps the best location access wise but it's out of the way and the styling suits the trike. Would have made a good battery box with a bity of work.
Nope, 12v coil, no ballast resistor. The points show no signs of burning, just the heel feels like it made from recycled Tupperware.
Post by: fifer on May 28, 2013, 07:19:16 AM
I have had the heel on a set of modern points wear down in a couple of days .
When I checked the heel I found that it was so soft that I could dig my nail into the material  :o
Is your distributor the newer type with the sliding points operated by the plastic white fork which sits over the pin on the baseplate { often usually coloured Blue } or the earlier points { often usually coloured Red }?
EARLY POINTS
LUCAS ................. PART NUMBER ....... DSB108
CI........................ PART NUMBER ....... CS132
INTERMOTOR ....... PART NUMBER ....... 22580
MINISPARES ......... PART NUMBER ....... GCS2118
MOTAQUIP ........... PART NUMBER ....... VCS108
QUINTON HAZELL . PART NUMBER ....... XCS132
UNIPART ............. PART NUMBER ....... GCS3004
LATER SLIDING  POINTS
LUCAS ................. PART NUMBER ....... DSB191{C}
CI........................ PART NUMBER ....... CS179
INTERMOTOR ....... PART NUMBER ....... 23451E
MINISPARES ......... PART NUMBER ....... GCS2261
MOTORCRAFT ....... PART NUMBER ....... EDP109
QUINTON HAZELL . PART NUMBER ....... XCS179
UNIPART ............. PART NUMBER ....... GCS3005
Post by: Olds on May 28, 2013, 08:02:12 AM
Same here >:(
It's the newer type with the plastic fork.
Just spent Half an hour reading your site and getting part numbers.  :D
Must admit I'm generally not a fan of electronic ignition conversions after having a couple fail on me At least with points I can see what's happening.
Post by: Olds on May 31, 2013, 08:53:04 PM
Just been out enjoying an evening bumble around, when there was an horrendous racket coming from the front of the trike. I pulled over straight away, thinking something drastic / terminal had gone wrong. Seems a small stone flicked up from the front wheel, got into the fan cage and as  the fan smashed it around  was merrily trying to destroy the radiator fins. Luckily no real damage has been done
Looks like a fine mesh guard will be the next thing to fit.
Must admit, that despite a few teething problems, riding the trike is fun. Folk smile and wave and when I'm parked up, come over and ask daft questions. Mrs Old would say, they are laughing at the old fool, on his three wheeled tractor.
But I don't care. ;D
Post by: Manky Monkey on May 31, 2013, 09:02:23 PM
That's the whole point ain't it Dave. They are fun.
I used to get bike riders telling me that only cripples rode trikes -their words not mine -& that they were the worst of both worlds cos you got wet like a bike & stuck in traffic like a car. But my little Reliants were as nimble in traffic as most 2 wheelers & were a completely different riding experience to a bike. I loved just going up & down through the gears & steering into corners etc.
I used to have a girlfriend who wasn't into bikes at all, but would come out for the occasional Sunday pub lunch trip on the trike. She knew nothing about the Reliant, but soon learnt the answers to all the usual questions cos she'd get asked them every time we stopped for petrol or whatever.
Post by: trikerpete on June 01, 2013, 04:42:59 PM
Is your distributor the newer type with the sliding points operated by the plastic white fork which sits over the pin on the baseplate { often usually coloured Blue } or the earlier points { often usually coloured Blue }?
EARLY POINTS
Please look at following photos, would you say these points/dizzy are of the "early" or "late" type?
Post by: trikerpete on June 01, 2013, 04:45:38 PM
Any idea what year would they change from being "early" to "late"?
Fifer......any chance you can make a new thread (sticky) showing part numbers/years etc of consumable reliant parts? ;) :D
Sorry for jumping your thread Dave  :-*
Post by: Olds on June 01, 2013, 05:05:47 PM
Thems is early  :)
Post by: tbone on June 01, 2013, 05:44:13 PM
you mean like this one?....http://www.mankymonkeymotors.co.uk/forum/index.php?topic=6726.0
I REALLY AM NOT GONNA BOTHER ANYMORE
Post by: terry t on June 01, 2013, 07:48:05 PM
what engine cc and number is yours Pete
DISTRIBUTOR
750cc engine up to no 7941  lucas 23d4
750cc engine from  no 7942  lucas 43d4
850cc engine                     lucas 45d4
type 23d4 and43d4 centrifugal
type 45d4             centrifugal and vacuum
like tbone say its all on here just do a search
Post by: Manky Monkey on June 01, 2013, 08:09:04 PM
I appreciate your efforts Tim!  :-*
Post by: trikerpete on June 02, 2013, 07:56:10 AM
Tim. Im sorry about that but I was only looking at the "Trike Tech" section and had forgotten you had already done it. Thanks for your input, I promise to pay more attention in future ::) :)
Post by: Olds on June 26, 2013, 10:03:25 AM
Hey Deliverance is famous :D Well sort of. Bored this morning had a look in the gallery section and saw that the pic Andy took had over 90 hits ???
Looked on Google images for  Deliverance Trike and its the first pic ;D
Post by: Manky Monkey on June 26, 2013, 10:29:47 PM
And I see the banjo playing hillbilly from the film "Deliverance" is in there too!  :P
That's a real Purdy tri -cycle you got there bo-oy.
Post by: Olds on July 02, 2013, 05:17:06 AM
Yup, Lonnie .
Dueling Banjos, originally known as Feudin Banjos, is one I'd love to play well but my fingers don't. :(
Either I've put on weight recently or the seat springs have sagged a bit as the seat was bottoming out ( :D ) going over the pot holes.
So I have fitted longer springs. Smoother ride but the downside is the seat feels a little less secure on the corners.
Post by: spanners on July 02, 2013, 08:59:36 AM
we,ll have to tell mrs 0ld newbie, to ration the cake  :D :D :D :D :D
Post by: Olds on July 29, 2013, 09:58:49 PM
NO......... not the cake! :o
Deliverance is as MM said "boringly reliable" but the temp gauge needle always settled at halfway between N and H. As it wasn't boiling over thought I'd live with that, but found it annoying so fitted a new A-TT05 sender. Not done a road test yet, but 30 minutes running while stationary and the needle never moved off N. Looks like the old sender was designed for engines with a lower running temperature causing the gauge to over read.
Post by: fifer on July 30, 2013, 06:12:14 PM
That would be the Sender with the Red centre as per following extract from my site ?
https://sites.google.com/site/fifersrelianthintsandtips/water-temperature-sender
WATER TEMPERATURE TRANSMITTER
Thread ; 5/8 by 18 UNF
{ This transmitter has a RED Base around the spade terminal }
RELIANT ; Part Number ; Still To Find
LUCAS ; Part Number ; SNB105
DELCO ; Part Number ; 7966267
DELCO ; Part Number ; SU15
LAND ROVER ; Part Number ; PRC7918
PSA ; Part Number ; 1205552
SMITHS ; Part Number ; TT4802/00A
SMITHS ; Part Number ; A TT05
MANUFACTURER ….. MODEL ….................... YEAR From ….. YEAR To
ASTON MARTIN ............. DB5 , DB5 V8 ................  Sep 1967 ............. Nov 1976 ,
................................... Vantage .......................  Sep 1967 ............. Nov 1976
HILLMAN ..................... Avenger .......................  Feb 1970 ............. 1976
................................... Hunter .........................  Oct 1966 ............. 1977
................................... Imp .............................  1963 ..............................
................................... Minx .............................  Aug 1969 ............ Sep 1970
HUMBER ...................... Sceptre , Arrow  ............  1963 ..............................
................................... Hawk , Super Snipe ........ 1964 ................... 1967
JAGUAR ....................... Daimler Double Six 5.3 ... 1975 ................... 1980
................................... Daimler Limousine ......... 1972 ................... 1975
................................... Daimler Sovereign 2.8 .... 1970 ................... 1974
................................... Daimler Sovereign 4.2 .... 1971 ................... 1980
................................... Daimler E type 4.2 ......... 1971 ................... 1974
................................... Daimler E type 5.3 V12 .. 1971 .................... 1974
................................... XJ6 ... 2.8 ..................... 1970 .................... 1973
................................... XJ6 ... 4.2 ..................... 1971 .................... 1975
................................... XJ12 ... 5.3 ................... 1970 .................... 1973
SUNBEAM .................... Alpine ........................... 1965 ................... 1971
................................... Rapier .......................... 1965 .................... 1971
................................... Imp Sport ..................... Oct 1966 .............. 1971
................................... Stilleto ......................... Oct 1967 .............. 1971
................................... Tiger ............................ 1964 .................... Feb 1967
TALBOT ....................... Hunter ......................... 1978 ....................................
RELIANT ...................... Fox .............................. 1983 .................... 1990
................................... Kitten .......................... 1975 ..................... 1983
................................... Rebel 700 , 750 ............. 1969 ..................... 1973
................................... Rialto ........................... 1982 ..................................
................................... Robin 750 , 850 ............. 1973 ..................................
TRIUMPH ..................... Spitfire 1300 , 1500 ........ 1967 .....................1971
Post by: Olds on August 06, 2013, 11:42:51 AM
At last got around to giving the trike it's first clean. Always seems a waste of time, it's only going to get dirty again. Found a few little chips in the paint and a very small dent in the rear tank. Probably from delivering a complete Yam front end (couldn't be bothered to wrap it up  ::)). It's for use not show so I'm not fussed. Did notice however something melted to the exhaust. Looks like a small heat shield might be required. :P
Post by: fifer on August 06, 2013, 04:41:22 PM
Yep , a heat shield shoed do it and will also help when you give it some welly  ;D
Post by: Manky Monkey on August 06, 2013, 10:56:02 PM
By some proper gentlemen's leather brogues. Trainers are for kids to wear until they can manage real shoes.
Post by: Olds on August 14, 2013, 08:40:43 PM
After having another stone try to beat my rad to death when trapped in the fan I finally got around to making guards.
Also made an infill section below the rad to stop all the road spray and crud ending up on the bottom pulley. This I made from stainless due to the stone chips it's bound to receive.
 Painted red only because I have no black at the moment  :-\
Post by: Manky Monkey on August 15, 2013, 08:34:40 PM
Looks good in red Dave. Tidy, as always.
Post by: digger06 on August 24, 2013, 09:43:11 AM
Yup, Lonnie .
i fitted some rubber mounting thingys in mine, like car engine mounts but smaller, might have even been reliant ones?
very secure now, and just padded enough
Post by: steve brock on August 27, 2013, 01:24:57 PM
I have the original fan wizzing around i assume it ok but now I'm starting to think it might be dangerous mmmm
Post by: Olds on August 27, 2013, 03:29:04 PM
Only if you stick your fingers in there. ::)
I dumped the original fan but did fit a guard on the alternator fan and pulley for my own peace of mind.
Post by: Olds on November 07, 2013, 08:57:38 PM
Took the trike out for a ride today as I had to drop off some paperwork at Loonys workshop (and have a coffee and some good company).
10 miles of single track lane where all the muck ends up in the middle of the road and the trike looks like I've been off roading.
Perhaps it's time to take it off the road and fit the girders (and maybe a larger front mudguard ).
In some ways I'm hesitant to do so, as it means Deliverance will possibly be off the road for a month or more :-\
Post by: Manky Monkey on November 07, 2013, 09:15:12 PM
Good company till I arrived Dave?  :(
The trike looks fantastic & starts & runs as reliably as a modern production vehicle. It really is a credit to you mate. It'd be a shame to see it covered in salt & road crud though. Might be the right time for a little Winter remodelling. I plan to keep my Pop on the road for the Boxing Day vintage meet in Romsey & the New Years day meet in Hartley Whitney. Then I'll be taking it off the road till about April cos I want to swap dashboards, send the speedo away to be recalibrated, fit new switches etc.
Post by: Olds on November 26, 2013, 04:42:30 PM
Tried the girders and didn't like the look :(.So back on with the original forks just in time to go out for a chilly ride in the sun  ;D. The sunset as I was pulling back into the village was incredible. Why do I never have a camera at the right time.
May modify the new handlebars to fit the old forks :-\
Post by: panthershaun on November 26, 2013, 05:00:17 PM
sad to say mate I agree  :'( for some reason they don't quite cut it which is a shame....
Post by: Olds on January 24, 2014, 06:58:35 PM
Decided to continue with the front mudguard made initially for the girders, as I'm fed up with all the crud hitting the rad. Most of my journeys seem to involve muddy country lanes and with a trike you cant miss that strip if muck down the centre of the road. The girders are not completely off the menu but the mudguard will fit both types of forks.
 Made up the mounting brackets today and finished all the welding. All that's left to do is some filling, mainly at the seams, then paint. Once this is done I will try fitting the girders again to see how it all looks.
Post by: Manky Monkey on January 24, 2014, 07:23:21 PM
Nicely done Dave -looks like a factory made part, (though I'm not sure that's a compliment!).
I liked the girders, but they definitely needed to be black to look right when fitted.
Post by: Olds on January 24, 2014, 07:29:56 PM
Well the trike is hardly a 'custom' in the usual sense of the word on this site. Custom built yes, but not radical in any way.
Post by: Manky Monkey on January 24, 2014, 07:32:39 PM
I beg to differ Sir!
Post by: Olds on January 28, 2014, 05:16:13 PM
Thanks Andy :)
Front crud catcher fitted to the tele's. The shape and extra colour really narrows the gap between the wheel and the down tubes/radiator surround.
Hopefully this will help with the looks of the girders.  :-\
Post by: morrag on January 28, 2014, 05:55:07 PM
Looks a treat Dave, with the orig. tele forks! use your very excellent girders on another build, this one is, believe me, done! ;) ;) ;), you wouldn't paint a moustache on the Mona Lisa! would you? well, maybe that's a bit of leap of faith, but you get my drift, I'm sure, regards, Morrag
Post by: trikerpete on January 29, 2014, 08:06:32 PM
Looks real good, great job  :)
Post by: merv on January 30, 2014, 09:23:03 AM
What a good job, you really are talented
Post by: Mendalot on January 30, 2014, 09:24:44 AM
That works really well and compliments the general overall look of the machine. Very nice 8)
Paul.
Post by: fifer on January 30, 2014, 09:27:07 PM
Braw Looker :)
Post by: Olds on February 02, 2014, 09:49:41 PM
Thanks guys.
Two small disasters today. Indicators switch decided to self destruct and I had to make a new contact plate for it. Then riding home from the workshop. a rear mudguard stay broke. Luckily I was going slowly and no damage was done.
Post by: Manky Monkey on February 02, 2014, 09:56:16 PM
That would be Mr Loon's workshop. Nice to see you there this afternoon Dave. Mudguard looks great in the flesh. Hope you got home safely.
Post by: Olds on February 02, 2014, 10:02:28 PM
Yep. Was just pulling into the village when a stay on the rear RH side parted company. Just took the mudguard off a slung it in the back :)
Both problems MY fault. The mudguard stay for not getting around to fitting a steady bracket. The switch because I bought a cheap Chinese one. ::)
Post by: Olds on February 04, 2014, 05:43:07 AM
Could not sleep, so remounted both rear mudguards, with steady brackets between the support arms and the axle mount. Not an elegant solution but it's all hidden. From the way the mudguards, previously bounced up and down, this was a job that I knew would need doing, but hadn't. ::)
Post by: Manky Monkey on February 04, 2014, 09:24:51 PM
Couldn't sleep because you were worried about your mudguards?! You're taking this hobby way too seriously Dave!  :)
Post by: Olds on February 13, 2014, 01:28:54 PM
:D It's not the trike that keeps me awake. I just can't stay still for any length of time.
Did another coal run today. The extra weight makes no real difference to the handling.
Post by: Olds on February 14, 2014, 11:37:32 AM
Having decided to keep the tele forks for present, I thought it time to do something, about the tendency for the forks to twist slightly, while cornering. With the new mudguard there is now plenty of room to hide a substantial brace.
Think this should do, as it's made from 4mm steel plate. :) Took a lot of heat and hammering to get the arch right, to fit snug inside the mudguard.
It's a bit heavy though!
Post by: Manky Monkey on February 14, 2014, 06:42:37 PM
That's a lovely smooth bend Dave. Sounds such a simple thing to do -until you try it.  ;D
Post by: morrag on February 14, 2014, 08:46:40 PM
I was able to brace my last trikes forks with a flat strip of 10mm alluminium plate,Dave, and it proved to be a considerable improvement!The Honda forks I used had convenient cast in lower fork leg lugs, enabling me to do so, so no bending required,although I have made a similar steel brace as yours on previous forks, Morrag
Post by: kapri on February 14, 2014, 09:05:13 PM
I've just bought a cheap hydraulic pipe bender , with a bit of fiddling ideal to curve strap as well.
Post by: Olds on February 22, 2014, 12:06:41 PM
Thought about that, and you are right, but to get the shape I needed, would have meant making up a former, + the steel was too wide to fit in the bender. ;D
The brace is now fitted and stops the twisting. Due it being shaped to fit the mudguard mounts it's also well hidden.
I have dumped the white handlebar grips due to rapid disintegration and discolouring >:( and replaced them with early, pre-unit triumph ones.
These are much longer so I took the opportunity to widen the handlebars from 35.5" to 39". Lengthening the throttle tube was a pain.
While not a fan of stickers on vehicles, after being stopped in a car park to be asked where I got the trike  ::), I took a leaf out of Pete's book and added a "built not bought"  :D
Post by: Manky Monkey on February 22, 2014, 09:31:40 PM
Hand painted stickers -properly hand made!  ;D
Post by: Olds on April 02, 2014, 04:30:59 PM
MOT time already :o
Passed no problems  ;D. So with the tax and insurance already done, I'm set for another year of blatting around the countryside.
Post by: morrag on April 02, 2014, 06:11:36 PM
And it still looks very nice indeed!!! Morrag....ps Keeping the teles was a sound move :D :D
Post by: stinkey on April 03, 2014, 12:45:43 PM
Glad to see I'm not the only one who does the coal run ? Trike looks cool sir
Post by: Olds on April 09, 2014, 07:17:56 PM
Thanks guys.
Been a bit busy with other things recently. Not been able to leave the house today, so the Deliverance badge has been replaced by the Olds badge I cast earlier.
Post by: Olds on April 09, 2014, 07:22:37 PM
Also started a long overdue modification.
? ;D
Post by: andyrennison on April 09, 2014, 07:29:49 PM
Still looks fantastic, im with Morag, front end looks right
Post by: Olds on April 10, 2014, 07:03:47 PM
 ;D
Worked out what the last pic is ?
My son and daughter have been bugging me about the trike being a single seater. So have decided to make a QD pillion conversion.
I have already made two saddles, a small, cool looking one and a larger comfy one. With the small one fitted there is room behind, to fit a pillion pad mounted to the front of the pickup bed and the frame beneath the saddle. Luckily I still have enough of the same leather (as long as I don't mess up  ::) )
First stage completed, the pillion foot peg mounting. This bolts to the gearbox mounting plate and can be fitted/removed with just three nuts without disturbing the gearbox.
Post by: Olds on April 11, 2014, 02:46:45 PM
Wrought iron and steel plate, pillion pad mounting. The claw goes around the frame cross tube, under the saddle.
Post by: Olds on April 11, 2014, 02:48:48 PM
Shown in position.
Post by: twisted on April 11, 2014, 02:52:25 PM
very neat ON looking good as ever  ;)
Post by: Olds on April 13, 2014, 07:07:01 AM
Seat base with thread inserts fitted and the molded leather facing ready for stitching.
The base is 3/8" ply and will be given a couple of coats of waterproof varnish. This has cost nothing but time as all materials were left overs. :)
I like cheap projects  ;D
Post by: terry t on April 13, 2014, 07:31:49 AM
Looking good Olds, does it state 2 seats on the V5, or have you got to get it checked over again.
Post by: Olds on April 13, 2014, 07:57:26 AM
At the moment it down as, seating capacity 1, but I should be able to get this amended by sending back the V5C with it noted in the changes section.
Will have to also inform the insurance company of course.
Post by: Olds on April 13, 2014, 09:17:05 PM
Nearly finished. Got the foam cut and the sewing done. All thats left to do now is trim the edges a bit, make a channel section to locate over the front of the pickup bed and then, the hard bit, trying to match the colour of the saddle. Cant remember what stain and polish I used. ::)
Post by: Olds on April 13, 2014, 09:18:04 PM
Post by: merv on April 13, 2014, 09:33:11 PM
That is a very neat and good looking job Mr Olds, you are a very talented man
Post by: andyrennison on April 13, 2014, 10:10:20 PM
Looks good. Thought at first there were no foot pegs but now I see em. Very neat
Post by: Olds on April 14, 2014, 05:20:08 AM
Thanks. This is not meant to be permanent, just fitted as required. So didn't bother with a rolled edge to the  leather ( makes sewing harder ) and the stitching is not as neat as it could be. The radius of the corners is about as small as I could go with stretching and shrinking.
Post by: kapri on April 14, 2014, 08:00:36 AM
Neat idea for seat placement :)
Post by: Manky Monkey on April 14, 2014, 09:03:06 AM
I know it's a silly question Dave, but how strong is the edge of the pick-up bed? Will it take the weight of an adult sat on it? Does look good though. I saw the passenger footrest bar fitted a couple of days ago & you wouldn't notice it till it's pointed out to you. Very tidy.
Post by: Olds on April 14, 2014, 09:45:34 AM
It's certainly strong enough. I know I can stand on it. The fuel tank frames are bolted to this panel and are full height, this adds a lot of strength to this area. This was done so I could mount the battery box on the front of the bed, bolts go through the box, front panel and tank frames.
More worried about how to secure it in position, so may mount the seat to the top of the tank mounts instead, as there are bolts I can use there already.
Post by: Olds on April 14, 2014, 02:42:59 PM
All finished. Decided on fixing to the tank mounts. Two wing nuts and it can be removed.
Post by: minimutly on April 14, 2014, 05:57:29 PM
Don't you have to have grab handles for a second seat? Been looking at how to make mine, 20mm steel conduit feels about right.
Huw
Post by: Olds on April 14, 2014, 07:27:39 PM
Yep, grab handles or strap required.
The white grab handles have always been there, as it was a way of avoiding possible projections problems at MSVA. Mine are 1" diameter to match the roll on the pickup bed sides.
The law on grab handles / strap is a farce. Putting a strap across a dual seat is next to useless. The pillion just keeps rocking back and forth, smashing into the rider, yet this is legally ok. I've always insisted a pillion hold on to me, tight. But then so far they have all been female  ;) :D
Post by: Mendalot on April 14, 2014, 08:03:36 PM
Now that conjures up a very funny vision, wish I could draw cartoons............ Olds, nipping off from the traffic lights with his female pillion fallen off the back into the pick up, with just a pair of legs poking up ;D ;D ;D
Post by: Manky Monkey on April 14, 2014, 09:16:33 PM
 :D
Post by: Olds on April 14, 2014, 10:01:45 PM
 ;D Pickup bed's too short for that ;D
Perhaps something like this
Post by: Manky Monkey on April 14, 2014, 10:10:27 PM
Is there nothing you can't do Dave?! Way too talented for one Monkey.
Post by: merv on April 14, 2014, 10:17:53 PM
I totally agree, I wished I had half his talent
Post by: Mendalot on April 15, 2014, 11:22:21 AM
Absolutely priceless Dave  :D :D :D
Post by: Olds on April 15, 2014, 11:50:38 AM
 :D
Talent, don't think so, but thanks.
 It's not great as I only had a felt tip pen to hand, but you get the idea.
Post by: minimutly on April 15, 2014, 05:59:24 PM
If you could imagine the mess I'd have made of that drawing then multiply it by ten you still wouldn't be near it. Talent you have sir, and if you don't mind me saying, it shows in your trike, it has something unique.
Huw
Post by: Olds on April 17, 2014, 12:01:41 PM
Yeah, I know I said I'd finished the pillion conversion, but I had a small bit of leather left over, so I'm making a small removable backrest.
Don't want anyone falling into the pickup bed, do we. :D
Post by: Olds on May 03, 2014, 04:04:00 PM
Spurred on by Twisted, I finally got around to replacing the HT leads I made for the MSVA.
Dumped the carbon core and replaced with multi strand copper core using the end fittings from the old leads. Not sure what the RF interference is like, but then I don't have a radio on the trike. :D  Should check it out sometime but I don't think it will be too bad as the leads are so short.
Post by: the coppersmith on May 03, 2014, 07:48:49 PM
Can I ask where you got those right angle fittings from for the dissie cap? Just what I need. 2 of mine foul the chassis and one has tended to work itself out, causing me a worrying moment.
Post by: Olds on May 03, 2014, 08:55:16 PM
They were ones I already had I think from a Rover V8. I tend to reuse stuff a lot. Might have a couple more but if not similar ones are available from-
http://www.autoelectricsupplies.co.uk/product_list/17
Not expensive.
Post by: Olds on May 11, 2014, 07:37:09 PM
Never been very happy about the sealing properties, or look of the original gear lever housing. While at the show today I picked up a cv gaiter for £1.
With slight modification it fits a treat. This was just to try for fit and I will tidy up the cut edge later.
Post by: Olds on May 12, 2014, 11:11:58 AM
The V5C has come back from DVLA and the trike is now officially a two seater. :)
Should make it easier to sell if I need to.
Post by: Manky Monkey on May 12, 2014, 08:14:15 PM
Just out of curiosity Dave, will you have to present the trike for MOTs with 2 seats fitted now?
Post by: Olds on May 12, 2014, 08:35:24 PM
Somehow I doubt it. Never had it questioned with bikes where I've removed a pillion pad or fitted a racing seat.
Main thing is make sure that if I carry a passenger, all is legal and that the insurance ok
Post by: andyrennison on May 12, 2014, 08:43:39 PM
Seemed a painless process.
Post by: Olds on May 19, 2014, 07:57:16 PM
Yep, just fill out the changes section on the V5C and send it back to DVLA and hope it doesn't get lost  :)
Finally got around to starting on the new hand gear change lever. This is what I originally planned till I realised it wouldn't pass MSVA.
Made out of 304 stainless (what we used to call 18-8). Forgotten quite how hard to work this stuff is so, heat and hammers to get the required shape. Lots of polishing ahead.
Post by: gazzagood on May 19, 2014, 09:01:50 PM
That's very nice Dave we'll done
Looks like you worked hard making that one. Like it
Gaz
Post by: Manky Monkey on May 19, 2014, 09:24:04 PM
Looks stunning Dave.
Post by: scannerzer on May 19, 2014, 09:37:46 PM
maybe i'm being thick here but why would that not pass msva
Post by: Olds on May 19, 2014, 09:46:04 PM
Thanks. The pic flatters it a bit but more polishing and I hope to get close to a mirror finish. Still need to do some welding and drill the cross pin hole, so no point in doing more till after that.
Do you still have stainless wire in your mig Andy ? Pretty please.
Wouldn't pass as it would be considered to be a stem. Minimum diameter of any stem, has to be 10mm (or 5mm radius if a blade)
Post by: Manky Monkey on May 19, 2014, 09:48:43 PM
I've got part of a small reel left Dave. Currently running mild steel. It only takes 2 minutes to swap reels -but you can weld it!
Post by: Olds on May 19, 2014, 09:53:14 PM
Thanks will pop around to the workshop sometime.  :-*
Post by: Olds on May 20, 2014, 07:37:07 PM
Managed to spend a couple of hours making the new sliding pivot, spring guides and spring. Also spent an hour looking for a M10 die before remembering that I threw it away and hadn't yet got around to replacing it :P Had to turn the threaded end down and thread M8  ::)
Post by: Manky Monkey on May 20, 2014, 08:14:38 PM
Sorry Dave, did you say you made a spring?!
Post by: Olds on May 20, 2014, 08:39:36 PM
Why? Doesn't everyone?  :D
Didn't have one the right size. The hardest part is getting an even temper. It's not under great strain so as long as it maintains it's length and doesn't fracture that's good enough for me.
Post by: Manky Monkey on May 21, 2014, 08:27:01 PM
I hate you. You know that don't you.  :P
Far too clever for this site!
Post by: BikerGran on May 21, 2014, 09:58:05 PM
Shhhhhhhhh!   You m ight want a spring one of these days!    ;)
Post by: Manky Monkey on May 22, 2014, 06:22:10 PM
It's not fair. I wish I was clever too.  :(
Post by: Olds on May 22, 2014, 07:17:53 PM
You don't fool me ! Anyone who can build rods, bikes and trikes is no dummy. :)
Post by: Manky Monkey on May 22, 2014, 07:24:14 PM
O.K, I don't really hate you.  :-*
Post by: Plainy Janie on May 22, 2014, 07:30:42 PM
Don't you mean 'keeping' an even temper :P
Post by: Olds on May 22, 2014, 07:36:22 PM
 ::) :D
Post by: Olds on May 23, 2014, 06:41:10 PM
Gear lever finished  :) Thank you Andy for the use of your MIG and thank you to Marcus for doing the welding. Was going to do it myself but when you are in someone else's  workshop and he offers, it would be churlish to refuse. ;D
Post by: Manky Monkey on May 23, 2014, 06:55:08 PM
Ooh, Purdy.
Post by: goose on May 23, 2014, 07:42:53 PM
very nice olds
Post by: scannerzer on May 23, 2014, 09:28:42 PM
nice ,i like the cue ball gear knob
Post by: trev on May 24, 2014, 09:03:46 AM
I like your knob too. ::)
Post by: merv on May 24, 2014, 05:48:55 PM
Ooooh Shiny, always great work comes out of the Old's stable
Post by: Olds on May 24, 2014, 06:55:09 PM
 :D Thanks.
Even shinier now ! Got fed up with polishing by hand so I've converted one side of the bench grinder to a polisher. Why oh why did I not do this years ago ? Hours of work reduced to minutes. Plus it's fun.
Will now be on the lookout for another cheap bench grinder or a polisher, so I can have coarse and fine mops permanently setup.
Post by: andyrennison on May 26, 2014, 09:51:04 PM
Very nice as always
Post by: Olds on June 04, 2014, 02:22:23 PM
A while ago I cut down a CV boot to fit over the gear lever. It wasn't very neat, so I've modified the retaining cover by tack welding on a flange made from a short piece of 2" exhaust pipe, hammered out to form a lip. This sits inside the bellows  and holds it snugly in place.
Post by: Olds on June 09, 2014, 02:16:22 PM
Not able to do much at the moment so I'm fiddling around replacing parts that aren't quite right.
Today it was the dipstick tube and steady bracket. Not a lot wrong but the tube was slightly too long and neither part looked too nice.
Replaced with stainless steel versions, that polished up nicely.
All I really want to do is ride it  :(
Post by: merv on June 09, 2014, 05:14:00 PM
That's very nice
Post by: Olds on June 27, 2014, 06:28:22 AM
D'oh!
The engine has always had a slight but annoying tapping noise when warm. At first I put this down to a worn rocker then realised it was lower down and was piston slap on one cylinder, which seemed a little odd. ???
 With Merv and Twisted pulling engines apart, I was looking back at some enlarged pics I took when I pulled the head off mine and found the cause. Number 2 piston had been fitted the wrong way around ! :o
 Don't know how I didn't see this at the time (probably not wearing my glasses) but it means having to remove both head and sump to correct.
Post by: terry t on June 27, 2014, 06:49:39 AM
D'oh!
Olds   cant you just drop the sump. take the end cap off rotate the piston 180 then refit
Post by: Olds on June 27, 2014, 08:40:07 AM
Not that easy Terry. On 850 engines the con rod big ends  are angled and should be fitted a certain way around. Unless of course the con rod has been fitted incorrectly as well. Not sure that is possible due to clearance issues. Will start with the sump to check this, though I think I may have noticed ( perhaps not  ::) ).
Post by: Manky Monkey on June 27, 2014, 09:24:35 AM
That's not natural for a Reliant engine to be so clean! I don't think they left the factory that smart.
Post by: twisted on June 27, 2014, 11:25:30 AM
you are right andy! there is no way i am ever going to get mine to shine up like those  :o ;)
Post by: Olds on June 30, 2014, 10:49:03 AM
Someone had obviously spent a lot of money on this engine but it wasn't assembled correctly. Hence all the leaks and problems I had at first.
Wonder if the owner got fed up with the engine and that is why the Rialto got scrapped  ???
New load bed mat to protect the wood and, paint when hauling stuff, courtesy of a certain Mr Field. Thanks Andy  :).  Heavy duty stable matting. Very thick and HEAVY. Chamfered the back edge to make it neat and fit tight under the tailgate when it's closed.
Title: Re: Deliverance
Post by: twisted on June 30, 2014, 04:33:48 PM
very nice and neat sir. ;)
Post by: Manky Monkey on June 30, 2014, 07:18:24 PM
Now we're floor buddies! -whatever that means.
Post by: scannerzer on June 30, 2014, 09:25:29 PM
that look fantastic Olds,just sets it off
Post by: Olds on June 30, 2014, 10:43:04 PM
It does look rather smart. :) Think I prefer the paint and wood finish but it's really not practical for day to day use. Everything slides about. Might fit some lashing rings sometime to hold stuff down as the roads around here are atrocious. I can see why hard tail servicars had the rear box mounted on leaf springs.
Post by: goose on July 02, 2014, 03:14:05 PM
very nice olds
Post by: Olds on July 21, 2014, 07:16:49 PM
The old fashioned seat springs had to go ! The first lot were too short, the replacements seemed ok but longer on journeys, the bouncing was doing my back in. After much pondering, drawing and rummaging I came up with this. Adjustable for weight and damped to prevent the dreaded bounce, hopefully this will be the last seat mod. Had to move the seat up a bit to allow for the much greater travel. Don't think it looks too bad either and best of all it cost nothing but time. ;D
Post by: scannerzer on July 21, 2014, 09:20:07 PM
awsome, whats it off a 125 ?
Post by: BikerGran on July 21, 2014, 09:29:39 PM
actually it looks rather good!
Post by: Olds on July 21, 2014, 10:04:31 PM
Thanks. Yep CG125 or one of the many clones. Picked up a near new pair when doing the girders, so had one spare. Still some tidying to do. Need to cut off the old spring spigots from the frame and paint the brackets.
Post by: Manky Monkey on July 21, 2014, 10:51:35 PM
How's it braced to the gearbox & under the seat Dave? Do you get any sideways movement? Similar set-up to Kapri's Ural saddle? I was never a fan of coil sprung seats, although I have one on my bobber project. Your alternative looks great.
Post by: Olds on July 22, 2014, 02:07:30 AM
Yep there is a bit of sideways movement, mainly down to slop in the front seat pivot, but it's not too bad. A new pivot pin and stiffer shock mount bushes should sort that out if and when I get around to it. It's all mounted to brackets attached to existing bolts on the seat and gearbox. I will put up some pics later.
Post by: Olds on July 22, 2014, 06:34:20 AM
Mounting brackets. As you can see, these still need some finishing especially the seat one. :-[
Post by: twisted on September 16, 2014, 10:55:29 PM
hi dave. just wondering how you have been getting on with your new seat setup? have been thinking of doing something similar on mine but using a small mountain bike shock with a 550lb spring instead. i was planning on using two (after all i am not a small unit) but now think that would be nearly solid but wasnt sure if a mono mount would stand up to the side to side movement. just wanted some user experience before getting any welding done  ;)
Post by: Olds on September 17, 2014, 07:16:25 AM
Hi Craig.
Getting on great with it. ;D   I will never be able to do long distances on it but that's not the trikes fault. It's the same with cars and bikes  :(
Some others on this site have used mountain bike shocks. But be careful, a lot of these shock units have no damping arrangement.
The main reasons I went with the 125 shock were, A- it allowed for long travel, this means you can mount it towards the rear of the seat reducing sideways leverage on the shock. B- good damping. C- adjustable preload. D- I already had it. :D Actually it meant that I could jury rig it up and check it would work.
Some folk might not like the feel of the seat, as the rubber mounts allow a bit of sideways movement, but it suits my arthritic back just fine as I don't get pitched to the side if one wheel hits a small pothole or lump in the road.
Post by: twisted on September 18, 2014, 09:54:40 AM
cheers mate thats good to know.
i have the shock already like yourself so will use it i think, it can be preloaded but not sure if its dampened. also, unlike you, i dont have as much room to mount up a long shock but the one i have is only 12cm long so i can get it under my seat.  :)
Post by: Olds on April 07, 2015, 07:12:41 PM
Had a breakage on the trike. While pulling out onto a very busy road, I was a bit heavy handed with the gear change and managed to snap the gearbox lever at the welded elbow. All my fault as I had not prepped the weld properly and then ground most of it off to make it look nice. ::)
 Had to drive home in second gear (only about 4 miles). At least it didn't overheat.
This wont happen again. Full depth vee prepped and re welded using 3mm welding rod
Post by: Manky Monkey on April 07, 2015, 07:54:53 PM
Was that after I saw you this afternoon Dave? Not easy trying to cross the Newbury/Basingstoke road in the evening rush hour with a wonky knob.
Stay safe matey.
Post by: Olds on April 08, 2015, 03:41:18 PM
Yep. Having a floppy knob is not good at the best of times, but pulling out on that road to find your stuck in neutral was a bit iffy. Luckily Lunatic was following and stopped so at least I had some sort of barrier from the traffic.
Post by: andyrennison on April 09, 2015, 09:49:52 PM
So long as you are ok, nothing else really matters
Post by: Olds on April 10, 2015, 07:59:10 PM
True Andy. Trike was fixed and back on the road the next day. :)
Had it's MOT today. ;D
Post by: Manky Monkey on April 10, 2015, 08:13:01 PM
And?  ...I'm assuming it passed with flying colours?
Post by: Olds on April 10, 2015, 08:18:52 PM
Naturally.  :)
Think I'd hang up my tools if the trike or a bike ever failed.
Post by: Manky Monkey on April 10, 2015, 08:32:21 PM
 ;D
Post by: Olds on August 27, 2015, 10:36:44 AM
At a recent show folk noticed the pillion seat in the pickup bed and asked how it fitted. Possibly because it's such a strange looking thing when not fitted. I'd used it to take my daughter, but had taken it off as I feel it detracts from the trike. It simply hooks onto the frame below the riders seat and is held in place by two wing nuts on the rear tank support frame. I've probably shown this before but can't be bothered to search the thread.
Post by: Olds on August 27, 2015, 10:40:50 AM
Post by: Manky Monkey on August 27, 2015, 02:17:56 PM
Suited the petite Magda , but not sure it'd take those of us of larger build! Clever idea Dave. That was the first time I'd seen it in use.
Post by: stinkey on August 27, 2015, 02:20:52 PM
That's what I told the guy ? :-\ I'm so clever.. ::)
Post by: Olds on January 14, 2016, 08:48:37 AM
Started to think about getting the trike ready for the spring, as to be honest it's not been used much recently.
New fork gaiters are first on the list. Bought from China as not only were they the cheapest option but the existiing 'British made' ones have disintegrated after only three years !
Post by: the coppersmith on January 14, 2016, 10:43:43 AM
I've just had a real good moan on another forum about the quality of rubber items, wiper blades etc. 12 months and things are falling to bits. Rad hoses, fuel pump diaphragm, (blamed on Unleaded by supplier).
Post by: Olds on January 14, 2016, 02:11:22 PM
Ethanol in fuel has been around for a while now, so should only affect old rubber components, not new stuff.
Post by: BikerGran on January 14, 2016, 10:32:06 PM
And hopefully shouldn't affect windscreen wipers at all!  I seem to buy them far more ofte3n than I used to, they used to last for years!  And we used to be able to replace just the rubber blade - don't see those any more either.
Post by: Olds on February 01, 2016, 07:34:40 PM
Getting the trike ready for the fabulous spring and summer we are going to have. Yep I'm delusional, but happier this way. Fresh oil, brakes checked, general check over and new fork gaiters fitted. Managed to put a BIG scratch in the front mudguard while taking it off to get the forks out, so that will have to be repainted sometime. The chrome on the horn was flaking badly,  and that was stripped and the cover painted. Never been happy with the horn though so may look out for something a little different (& louder).
Post by: Sid_Vicious on February 01, 2016, 08:57:30 PM
You could get an repro of the Indianhead they used on the old Chief or with your new hobby you could just spin one and open up openings with the lettering Olds in some stylish font.
Post by: Manky Monkey on February 01, 2016, 09:26:36 PM
Looking forward to seeing it out & about again soon Dave.  :)
Post by: Olds on February 01, 2016, 10:17:27 PM
Looking forward to getting out on it again. Neck and arm seem to be getting better so hopefully soon.
You mean like this ? Just a tester to check the former shape and work out the diameter of disk needed. Can't find a font that really works.
Post by: Manky Monkey on February 01, 2016, 10:31:42 PM
 ;D
Post by: merv on February 01, 2016, 11:17:28 PM
What do you mean, just a tester and cant find a font that works, most people would be happy with that, oh well
Post by: Sid_Vicious on February 01, 2016, 11:47:58 PM
I think it could be nice to mimic the font you used on the tank with maybe some extra small holes around for more air/sound to pass trough.
Post by: Olds on February 02, 2016, 06:23:18 AM
Have you been hacking my computer Sid?
Post by: Sid_Vicious on February 03, 2016, 12:48:45 AM
I'm not that good with computers, but you must have had the same ideas as I had about the horn.
Post by: Olds on February 03, 2016, 08:59:05 PM
 :D
Trying to concentrate on the car, so this will have to be relegated to being a future, 'I'm fed up, so I'll do something different' type job.
Post by: Olds on May 10, 2016, 07:51:31 AM
Rocker noise has got a little excessive so off with the tank and rocker cover. Thought while I'm in here, check the head nut torques. After cracking each nut they were re torqued and it took at least 1/2 to 3/4 turn. Looks like despite being re torqued after initial running of the engine, the head gasket has compressed some more.
One good thing is that the only 'emulsion' found was a very slight amount actually in the breather mesh.  :)
Also noticed that the outer insulation on some of the wiring has worn, due to rubbing between the tank and frame so that will need to be sorted before it goes back together again.
Post by: twisted on May 10, 2016, 09:49:19 AM
good job Dave  ;)
when you replace that wiring sleaving it with snake skin might help prevent rubbing. Or at least make it easier to spot if it continues as the snake skin would fray and be easy to spot.
Post by: Olds on May 11, 2016, 07:20:05 PM
It's just the plastic outer sheath that's worn. Got some insulating tape from some weird guy at a show, so I will probably just bind it in that. :D
While the tank is off and access easy, I figured I might as well change the oil. Some may remember that I originally filled it using the dipstick tube (took a while ::)). I had modified the dipstick and tube and upon filling, the oil level only came to the lower mark. Tried to work out where the dipsick measurements had gone wrong, never did, and thats the level it's stayed at. After todays oil change the level is exactly on the upper (full) mark. Seems that I can't reliably measure 5 1/2 pints.
Post by: merv on May 11, 2016, 07:56:35 PM
Not you Dave,surely not, there's hope for the rest of us  ;D
Post by: Olds on May 11, 2016, 08:23:18 PM
 :P
Got the wife to pick up the oil from Halfords while she was out shopping. Classic 20w-50. A staff member was concerned that she may have picked up the wrong stuff, saying that it was only for special older vehicles and asked what it was for. When she replied it was for an Olds, he asked, "an old what" ? Upon telling him that the make is an Olds and no, not Oldsmobile, the poor fellow wanted to look it up on their system. Doubt if he will find it ;D
Post by: Baychimp on May 11, 2016, 09:00:07 PM
I have trouble with everything after 5 1/2 pints  :D :D :D
Post by: fifer on May 11, 2016, 09:28:33 PM
If you torque the cylinder head then wait till you have done the recommended 500 miles , chances are that you will develop head gasket problems !
The gasket will have compressed /bedded in after the first heat up / cool down cycle .
The only  method I have found too work better than others is ;
{ 1 } Initial Torque
{ 2 } Run up to temperature
{ 3 } Let it cool for 8 hours or overnight
{ 4 } Re-torque
{ 5 } Let it cool for 8 hours or overnight
{ 6 } Last Re-torque
Note that Reliant issued a note stating that head studs should be tightened to 25 ft/lb except studs 11 and 12 which should only be tightened to 20 ft/lb
https://sites.google.com/site/fifersrelianthintstips/cylinder-head?pli=1
Post by: Olds on May 11, 2016, 09:38:23 PM
Err think I missed out stages 5 and 6. and only re-torqued it after the first heat cycle. Did however remember about studs 11 & 12 as I had noted it down in my manual.
The oil was a little blacker than I would have liked but no obvious sign of gasket problems.
Post by: Olds on May 12, 2016, 07:34:12 PM
Couldn't find my Wellseal for the cork rockerbox gasket, so I went back about a century and used shellac. After running the engine for a while there are no signs of leaks so the trike is now ready for the MOT. :)
 Sod it. No it's not. :(
While squeezing through between the trike and the XVS I managed to snap off the LH front 'flexible' indicator. >:(
 Pair of chrome bullet indicators ordered. ::)
I will probably paint the bodies black, while leaving the rims chrome, to match the headlight. Will also look to buy or make some clear lenses for them but there is no rush for that.
Post by: Mendalot on May 12, 2016, 07:56:21 PM
A true motor engineer is the man who uses Wellseal ........... the man who uses shellac is deemed to be an  OLD SKOOL motor engineering God  :D :D :D
Post by: merv on May 12, 2016, 08:15:09 PM
For us younger ones  ;D could you tell us what is wellseal ?
Post by: Baychimp on May 12, 2016, 08:15:54 PM
You didn't melt down a couple of old 78 records Dave.
Post by: Olds on May 12, 2016, 09:05:16 PM
 ;D ;D ;D
Wellseal is a liquid jointing compound that never fully dries out. Think it was originally developed by Rolls Royce.
It's great stuff but smell foul, ruins clothes and is really awful stuff to get off your skin. Not cheap but a tube seems to last forever. Unlike most jointing compounds where you use a little, then in six months time you find that what's left in the tube is ruined.
You can't melt 78's but you can dissolve them in denatured alcohol. Which happens to be the solvent for shellac.
Post by: Manky Monkey on May 12, 2016, 10:50:27 PM
I've got a tube of Wellseal. Looks like molasses or thick treacle. Doesn't taste as nice though.
Post by: Baychimp on May 12, 2016, 11:12:41 PM
You! tried it. :P
Post by: Manky Monkey on May 12, 2016, 11:35:36 PM
 :D
Post by: the coppersmith on May 13, 2016, 07:35:08 AM
I was brought (dragged?) up in a shipyard. Osotite and Stag were the jointing compounds of choice. Osotite was like wellseal and stag was for the ones which continued to leak. I've probably got it in my veins I used so much of the stuff along with cadmium from brazing and asbestos from living in that atmosphere. Bit of an old boiler then  :D :D
Post by: morrag on May 13, 2016, 04:58:20 PM
I remember those days, should belong to a club, or society, or....something, as there can't be too many of us left!!!..... ;D ;D
Post by: merv on May 13, 2016, 06:31:58 PM
OK, now you oldies have finished reminiscing, why use wellseal and is it only used for cork
Post by: the coppersmith on May 13, 2016, 07:14:52 PM
You can use it on any gasket, but you will not be able to use the gasket again. I always get some in a small container, small paint brush and apply it around both faces, put the gasket in and bolt it up, works for me ;)
Post by: Olds on May 14, 2016, 04:05:50 PM
New indicators arrived ar 10 am today. Great I can have this done by lunch time. :)
Wrong, so very very wrong !
Removed old inicators. No problem. Drilled out the mounting brackets to suit the larger stems, No sweat. Cut the leads to length and soldered on new connectors and earth rings. Slightly fiddly but fine. Mounted them to the trike and wired them in. Easy peasy. Test. Bo####ks.
  Fuse instantly blew.
Pulled one apart and found that they were wired- black = supply  the red = earth. Have no idea why I may have thought it should be the other way around. Possibly because it should be. ::)
. Actually an earth is not needed and is dumped and (black) supply lead just needs a spade terminal instead of a ring terminal adding. New fuse found and it's test time. Bo####ks again.
 Flash rate is too high.
Look at the bulbs and they are 10w and need to be 21w. No probs I think. Wrong again. All the 21w bulbs I have are the standard ba15s with large glass and they are too big to fit the lens back on. At least I know the indicators work.
 The nearest bike shop was shut. Next one is open but they have run out of these bulbs. Tried motor factors and even Halfrauds, but nowhere locally that's open seems to have them. Funny how they all say we usually stock them, except Halfrauds who didn't have a clue.
A box of 10 have been ordered on the internet.
  Checkout the wiring in the lamp. I know they were cheap, but this is awfull.
Post by: spanners on May 14, 2016, 04:32:05 PM
indicators 99p for two free delivery ,,,,,,from  back of beyond ,,,,   you gets what you pay for   ::) ::) ::)
Post by: Olds on May 14, 2016, 04:39:28 PM
Not exactly 99p but I know what you mean Mike. I will keep my eyes open for some decent vintage sidelights like I have on the pickup sides, to use as indicators. You can't beat pre-war stuff for quality.
Post by: spanners on May 14, 2016, 04:48:10 PM
i know of a vehicle thats had 3 alternators  in 4 months  all made in china  all died with bearing collapsed
i fitted an old one of a scrapper and its been ok since ,,
Post by: Manky Monkey on May 14, 2016, 04:58:15 PM
Bet my project's got more problems than your project :)
Post by: spanners on May 14, 2016, 06:15:46 PM
my current project is on the road ....all legal  and being used  :P :P
Post by: Olds on May 14, 2016, 06:20:19 PM
;D True but acording to my dear lady, this project isn't supposed to be a project any longer. Will it never end ? I certainly hope not. ;D
Post by: Olds on May 17, 2016, 04:57:59 PM
Waiting for a box of bulbs and a new LH handle bar swiitch unit to turn up as the indicator part of the existing switch could be a bit temperamental.
As it was such a lovely day, I at last got around to repainting the front mudguard that got badly scratched. Not usually too worried about the state of the paintwork, but this scratch was down to bare metal. Painted, laquered and rubbing strips refitted, I will leave it a couple of days to fully harden before putting it back on.
Post by: Manky Monkey on May 17, 2016, 05:08:22 PM
Tha's purdy.
Post by: Olds on May 19, 2016, 07:14:30 AM
The saga of the indicators continues.
Box of 10, p207m 12v 21w ba15s 19mm bulbs arrives, supposedly from a well known maker and once fitted the flash rate is still too fast for MOT at about 130 flashes per minute. Carefully check the bulbs and yes they have 12v 21w printed on them but they're obviously not. Nor do they have an E mark or manufacturers name. Looks like they are probably counterfeit. >:(
 The supplier when asked genuinely seem concerned about this (possibly because he has another 78 cartons of them) and said that he would send out some more once he has checked the rest of his stock.
 I have also taken the precaution of ordering some from a different supplier and will see what happens.
Post by: kapri on May 19, 2016, 08:22:18 AM
Counterfeiting is a BIG problem within the motor trade . Often a container of ,say, Mk6 Escort front brake pads will be sent over and then sold off to wholesalers who sell on to small factors sell on ebay. Many manufactuers are now using holographic seals on their wares. My local factors only buys from big manufacturers direct and with certain ISo standards in pplace. His parts are dearer than e bay but you GET what you are paying for and with a manufacturers back up, important on something like a timing belt!
Post by: minimutly on May 19, 2016, 06:27:33 PM
Fear not it will be OK when we join the EU ;D
Post by: BikerGran on May 19, 2016, 06:38:21 PM
(http://theclothesline.ie/wordpress/wp-content/uploads/2013/01/wooden-spoon.jpg?w=150)
Post by: Olds on May 19, 2016, 08:12:18 PM
 ;D
OK, so have been refunded for the bulbs as the guys entire stock isn't what it's supposed to be. >:(
But on a brighter side the LH switch unit arrived and I was pleasantly surprised.
 It's so much better made than the old one(it even has a brass bushing for the indicator switch lever). It's a copy of  a 1970s Yamaha one. The original idea was to just take out the indicator section and swap them over, but I decided to use the whole thing.  This meant some internal rewiring as the on off switch is now the parking light switch and modification to the housing to allow the cables to exit from the bottom, plus a bit of soldering to join it all up to the existing loom. Also took the opportunity to extend the wiring a bit just in case I want to change the handle bars at some point. ;)
Post by: digger06 on May 20, 2016, 07:06:36 AM
use a digital(solid state) indicator unit
load independent, my indicators AND my harzards run through the same unit, they still flash at the same rate, you can use any bulbs you want, doesn't matter,,,
Post by: Olds on May 20, 2016, 11:09:56 AM
Yep, could do. The indicators and hazzards already work through the same unit, but it has a minimum wattage of 2 x 21 (+ 1 x 1.2)  Changing two bulbs should be cheaper and easier than fitting a new flasher unit and I'm trying hard to keep costs down. Just a pain that there seems to be a shortage of them locally. I should have new 'guaranteed' 21w E marked bulbs in a couple of days, hopefully tomorrow.
Adding just an extra 2w bulb into the system is enough to get them to flash at the correct rate, so the bulbs I have are close but no cigar.
Post by: Olds on May 23, 2016, 08:34:42 AM
D'oh ! The new bulbs arrived on saturday from a different supplier and they are also dodgy. On checking them the resistance of individual bulbs varies by as much as 33 ohms ! So much for being guaranteed. The supplier has responded quickly blaming 'human error' and is sending out replacements. Looks like there must have been a container load of these.
Post by: BikerGran on May 23, 2016, 10:32:24 AM
I wonder if this is why I keep haveing problems with one of the rear lights on my car?
Post by: Olds on June 09, 2016, 01:53:15 PM
 ;D MOT done. Had to ride out to Harewoods of Andover. Very nice guy and VERY thorough. This was the most carefully done MOT I have ever witnessed. Took a full hour and even checked every frame weld !
Came away with two advisories  :( And a complement on the standard of the trike. ;D
001 Rear wheel bearing slight play offside rear
002 Nearside rear handbrake effort low
But he did admit that he was being pedantic about these, as he could only just feel the bearing issue and the handbrake was fine but the nearside wasn't as good as the offside and passed as an emergency brake system, despite it only needing to be a parking brake (because two separate hydraulic brake systems are fitted).
Post by: stinkey on June 09, 2016, 03:38:36 PM
 Checked every weld ? Never heard of that ? Nit picking to the extreme ? But he most likely couldn't believe what he was seeing ? I bet he has seen some BAD stuff ?
When I took martins trike for it's MOT, Geoff the tester made a cuppa,and we chatted for ages,Martin asked him if he was going to look at the trike ? Geoff looked at me,smiled and said OK,but if Stinkey built it I don't need to ? Made my head swell for sure ? ;) well done good sir..
Post by: Olds on June 09, 2016, 03:56:52 PM
D'oh!
Bad new always seems to follow good. Took a trundle out to the workshop and by the time I got there the temp gauge was in the hot zone. Actually it had gone past hot, yet the bottom hose was cool to touch suggesting no water circulating. We left it to cool then refilled with water. A very gentle journey home and by the time I pulled onto the drive, the trike was doing a pretty good impression of a vintage traction engine. Steam and water being ejected at a considerable rate from the rad overflow.
Either the stat has got stuck closed, the pump has ceased to pump, or most likely the head gasket has gone.
Ho hum.
Post by: merv on June 09, 2016, 04:11:54 PM
Hope it's a simple fix
Post by: minimutly on June 09, 2016, 05:27:01 PM
Sorry to hear about possible HG failure Olds.
On the mot test, interesting to hear he found play in the rear wheel bearing, given that its a solid axle with a tapered hub, it would have to be up and down movement, pretty hard to detect - unless the hub is loose on the shaft? Worth checking?
Post by: stinkey on June 09, 2016, 07:16:58 PM
Could just be an air lock ?
Post by: Olds on June 09, 2016, 08:19:40 PM
It's head gasket. :(
No water in the oil but there is oil in the water. By that I mean, an oily residue on the inside of the radiator and rad cap.
 Oh well, at least I still have the bikes until I get this sorted. My own fault for being in a hurry and thrashing it back from Andover. At my age I really should know better.
Not checked the 'wheel bearing' yet, but yes, first off I will check the hub to halfshaft fit.  I fitted new bearings when I made the axle tubes, but these days one can't tell the quality by the name.
Post by: Olds on June 10, 2016, 10:18:17 AM
Pulled the plugs. Number four is running very slightly weak but that is common on these engines, three is rich with a bit of an oil problem, two is fine, but number one is far too clean at the end of the thread. Looking into the bore, it's wet in there and it's not go go juice.
New top end gasket set ordered and should be here on Monday.
Post by: the coppersmith on June 10, 2016, 10:27:15 AM
Is it a problem with the Reliant engine, like my old Hillman Imp engine ?? Are there good quality head sets etc. Plug burn seems a little uneven, as you have said, hope you haven't opened the can of worms !
Post by: Olds on June 10, 2016, 03:16:38 PM
I'm think it will be ok but then I'm an optimist. Number three plug looks worse in the pic than it really is so not worried about that. Just hoping that the head won't need to be skimmed as I believe there isn't much spare metal on 850 heads.
I too had an Imp ( singer chamois ) with a 'head problem' after the wife drove it, fully laden, for five miles in second gear, when the gear change broke. ::)
It had probably lost all water in the first two miles. By the time it clattered on to the drive the engine was so hot, you could hear the oil boiling in the sump.
Post by: digger06 on June 10, 2016, 04:51:06 PM
they are about 3 or 4 quid on fleabay, findin bulbs isn't a problem after that,
Post by: Olds on June 10, 2016, 06:32:48 PM
Yep, that's what I did in the end. Talked to only manufacturer of this size bulb in the uk (Autolamps) and they admitted that these would not pass e mark testing but stated that they didn't need to. Had a bit of an argument regarding the use of non e marked bulbs in e marked light units, plus the fact that my amps x volts readings suggested they were only 16 to 17w not the 21w they were claiming.
One good bit of news regarding the MOT. There is absolutely nothing wrong with the 'wheel' axle bearing. Think the tester must have felt the jack he used rock slightly
Post by: stinkey on June 10, 2016, 07:43:09 PM
I got rushed into hospital (seriously scalded) because of a singer chamois ?
Post by: Olds on June 11, 2016, 06:22:12 AM
Heater pipes ?
Post by: stinkey on June 11, 2016, 08:12:01 AM
Well I'm guessing head gasket was the main mechanical issue ? But being young/foolish/naive and exited about getting to the street rod Nats at knebworth caused a lack of concentration and after the first pullover on the A1 I didn't put the rad cap back on properly ? So a few mins down the road we pulled over again ( we as in my 8 month pregnant wife )and I placed a rag on the rad cap to loosen it ( won't do that again ?) which promptly blew up in my face/chest..OUCH ! Luckily my friend in the car behind managed to get me to the Lister hospital near Stevenage in time,I was badly burnt in deep shock and slipping into cardiac arrest..spent 10 days in hospital ward..lost a tooth due to the trauma as well ? :D the funny part ( but you couldn't get away with nowadays ?) was my missus (about to drop any moment ?) and her also heavily pregnant friend,would both jump into her friends tiny invalid car ( the little blue single seater fibreglass ones ?) and drive up the A1/M to visit me  :D
Post by: Olds on June 11, 2016, 06:54:04 PM
Ouch !  Not nice. Bet your missus was, a, Really worried about you and b, Really, really pissed off with your timing.
Gasket set arrived  :o. Looks to be much better quality than the last set. Has more metal around the cobustion chambers and the better valve seals so they will also get fitted. Might help with the oil problem on number three cylinder.
Post by: Olds on June 11, 2016, 07:04:05 PM
Head off. Amazing what a bit of water in a running engine can do to clean up a cylinder.
No obvious damage and the head appears to still be flat when checked end to end and corner to corner.
Lots of cleaning up to do before sticking it back together.
Post by: fifer on June 11, 2016, 07:12:39 PM
Torque ;
With that type of cylinder head gasket it needs to be run without coolant for a minute on first torque assembly to set the glue /sealant .
1st Retorque ;
Then , after 8 hours or so , you fill the engine with coolant and retorque .
Run up to temperature and switch off and leave for a further 8 hours or so .
2nd and final Retorque ;
Full info at my site ;
Post by: minimutly on June 11, 2016, 07:17:37 PM
I see the original gasket was one of those cardboard ones, i wont use them, had to skim loads of mini heads for people who have. The new one looks decent though.
I think the point about rechecking the torque after a run is a good one, just as long as its all nice and cool.
Post by: Olds on June 11, 2016, 07:38:50 PM
Torque ;
Will do. Cheers.
Yep. Must admit the original didn't look to be of great quality. A real pain to clean it all off the head and I havn't started on the block yet. It broke up while taking off the head. >:(
Post by: stinkey on June 11, 2016, 08:15:22 PM
I don't think she was peed off with me ? And can you please let us all know who/where you got the gasket kit from please ?
Post by: Olds on June 12, 2016, 07:37:32 AM
Haldane International Ltd 07714748545 trading on ebay as classicbrakeandelectric8
£15.00 including P&P
A couple of small issues.
As usual a couple of holes in the head gasket could do with slight attention but it would fit as is and no swan neck to manifold gasket was included. But I make my own anyway.
Post by: fifer on June 12, 2016, 10:55:28 AM
Difference in the head gaskets ;
(http://i423.photobucket.com/albums/pp316/fifer3w/CYLINDER%20HEAD/HEADGASKETDIFFERENCES_zpse05c0568.jpg) (http://s423.photobucket.com/user/fifer3w/media/CYLINDER%20HEAD/HEADGASKETDIFFERENCES_zpse05c0568.jpg.html)
Manifold gasket modification to suit the manifold and head ;
(http://i423.photobucket.com/albums/pp316/fifer3w/CYLINDER%20HEAD/MANIFOLDGASKETMODIFIED.jpg) (http://s423.photobucket.com/user/fifer3w/media/CYLINDER%20HEAD/MANIFOLDGASKETMODIFIED.jpg.html)
Cylinder head inlet ports modification    ;
(http://i423.photobucket.com/albums/pp316/fifer3w/CYLINDER%20HEAD/HEADSHOWINGORIGINALMETALBETWEENTHEINLETPORTSONTHELEFTANDTHEMODIFIEDONESONTHERIGHT.jpg) (http://s423.photobucket.com/user/fifer3w/media/CYLINDER%20HEAD/HEADSHOWINGORIGINALMETALBETWEENTHEINLETPORTSONTHELEFTANDTHEMODIFIEDONESONTHERIGHT.jpg.html)
Post by: Olds on June 12, 2016, 08:31:15 PM
Got all the remains of the old gasket off the block. 3 hours of carefull scraping and rubbing with green scouring pads with all holes plugged up.
Going to drop the sump as I'm sure there will be a some water in there. While that's off I will sort a known problem with this particular engine.
Number two piston is the wrong way around. Didn't notice it last time I had the head off but saw later it when I enlarged a hi res pic I had taken..
Seems the garage fairy's haven't sorted it, so .....
Should be lots of fun (not) seeing as the engine is still in the trike and there is not a lot of clearance underneath. :-\
Post by: stinkey on June 13, 2016, 07:39:34 AM
thank you kind sir ;)
Post by: Olds on June 13, 2016, 08:23:23 AM
Noproblemo stinkey.
Hmmm. Sump off and yes there was a small amount of coolant in there. Shame because I had only done 20miles since changing the oil.
Getting to the big end bolts is going to be a real pain as the oil pump is in the way. Almost tempted to leave the piston the wrong way round. :(
Post by: Olds on June 13, 2016, 10:24:08 AM
The offending piston !  :D Wasn't too bad getting it out. Used an old bathroom mirror on the floor to see what I was doing. Not helped by the fact that I managed to spear a knuckle on the botton of the dipsick and kept dripping blood onto the glass.
Now to try to find my ring compressor, that I havn't used (or seen) for about five years. :-\
Post by: spanners on June 13, 2016, 12:44:54 PM
olds  just be shure the conrod is the right way round also as it could be the piston to rod that is wrong
dont really know why i,m saying this to you  as you will all ready know what i mean  ,you clever owd bugger,,, ;) ;) ;)
Post by: Olds on June 13, 2016, 01:39:51 PM
 :D
Yep checked the shell stops relative to crank rotation. The piston and rod had literally just been fitted the wrong way around in the block. At least I got to look at the crank journal and shells and I'm convinced that this is a low mileage engine that's had new pistons, rings and bearings fitted.
Post by: Olds on June 14, 2016, 11:26:05 AM
Fitting the new valve seals requires removing the valves, which requires a valve spring compressor. No problem thinks I.
Errr, do'h ! My spring compressor is too big !
A few minutes with the angle grinder, drill and a bit of 25 x 5 mm steel bar and the problem's solved.
While the valves were out I did a decoke. Contact areas of valves and seats look great so didn't lap them, but I did make absolutely sure that each valve went back in it's original position.
Post by: minimutly on June 14, 2016, 06:00:51 PM
I made one just like that for changing springs on a series engines without taking the head off, stuff a bit of nylon roap on top of the piston and away to go.
Post by: Manky Monkey on June 14, 2016, 07:42:32 PM
I had a cast version of that once. Used it a couple of times on my old Morris Minors. It had a manufacturer's name on it, but I'm blowed if I can remember what it was.
Post by: Olds on June 15, 2016, 07:45:17 AM
Probably Britool.
Remembered using one on a friends Moggy back in the 70's so I knew it would work before I started to make it.
Reason for overheating in the first place- a duff thermostat. Why the hell don't they ever fail in the open position.
Post by: BikerGran on June 15, 2016, 09:19:27 PM
When I used to work shifts and drive to work at night in the freezing cold, and home again in the morning when it was even colder, my thermostats ALWAYS failed in the open position - but I guess that's just sod's law!
Post by: Olds on June 17, 2016, 11:07:32 AM
 ;D
Yesterday, after filling with new oil (despite the old stuff having only done 40 miles) and turning the engine over on the starter till the oil pressure light went out, I did a dry run (no coolant) as per fifers instructions for this type of head gasket. Not knowing how hot to let it get, I kept my hand on the back of the head and ran it till it was hot enough to be uncomfortable but not quite painful. Not very scientific I know.
At least the piston slap from number two cylinder has gone. :)
Today I re torqued the head and was surprised how much further the nuts moved and no I hadn't set the torque wrench differently. The gasket compressed so much that once I refitted the rocker shaft, there was no valve clearances. :o These have now been re set and once I have filled with coolant I shall do a full heat cycle then pull it apart and re torque the head again and undoubtedly have to re set the valve clearances, again
Oh what fun I am having. :P
Post by: Olds on June 17, 2016, 03:46:49 PM
And the fun continues. :(
Despite being carefull I seem to have cracked the thermostst housing. Nothing to see but when the engine starts getting warm coolant starts to leak out slowly from above one of the bolts.
Post by: fifer on June 17, 2016, 04:39:39 PM
Did you fit the housing after you had fitted the rocker cover ?
Post by: Olds on June 17, 2016, 06:21:36 PM
Before, so it definitely didn't have any rocker box gasket stuck under it.
Only thing I can see is that the new thermostat seems to have a slightly thicker bead around the outside. ??? I was probably just a bit heavy handed with the spanner though I did tighten the three bolts up evenly and in small stages. Perhaps the metal has aged, it appears to be a zinc aluminium alloy.
On the inside you can just see the crack. New housing ordered but I shall try aluminium brazing this one as I also want to change the angle of the neck slightly and It will be good practice even if it goes wrong.
Post by: fifer on June 17, 2016, 08:40:40 PM
Aye , some of the new thermostat housings are not all they`re cracked up to be .  :)
You also get different thicknesses of gaskets .
Post by: Olds on June 19, 2016, 04:21:33 PM
;D ;D
After doing a second full heat cycle and retoque, (with some sealer inside the housing) I took the trike out for a test ride to the workshop which is about five miles away. Nice to see everyone beavering away at various jobs.
Trike behaved perfectly, apart from some slight part throttle hesitancy. No overheating, leaking of vital fluids or clattering and the fan didn't come on until I got home and the trike was ticking over in the garage. Pulled the plugs and they are all a nice uniform beige colour, (even number three :)) so all seems great.
New thermostat housing should be here on Wednesday so we should be good to go for the rest of the summer. ;D
Post by: merv on June 19, 2016, 04:32:25 PM
That's good news, so no head needed
Post by: Manky Monkey on June 19, 2016, 08:28:39 PM
Nice to see you earlier Dave. Trike looked good as always.
Post by: Olds on August 05, 2016, 09:30:54 PM
Somehow the cue ball gear knob disappeared while the trike was parked at the shops. >:(
Been replaced with one turned from an 8 ball.  Surprised how deep the white sections went. Not having a white gear knob somehow made the white handbrake lever look odd so this was bound with black cord.
Not big changes I know but...
Post by: Manky Monkey on August 05, 2016, 10:06:37 PM
There really are some nasty gits out there aren't there. Sorry to hear that Dave, but the changes look just as good as the originals.
Post by: Olds on November 03, 2016, 01:45:13 PM
Tried to take the trike out today and I have a flat battery. For the past six months it has been going flat slowly but this time it only took a week and it's not accepting full charge (11.2 v) so looks like I will have to get a new one. :(
Did however get around to altering the new thermostat housing so that the hose will line up better.
Post by: Manky Monkey on November 03, 2016, 06:43:30 PM
Was that with your new ali' brazing rods Dave?
Post by: Olds on November 03, 2016, 08:45:20 PM
Yep. There is a tight fitting aluminium tube 'brazed' inside to reinforce the joint. Took a few attempts to get it totally water tight (well air tight).
Post by: Olds on February 07, 2017, 05:06:55 PM
Had to move the trike today so I could get the 650 out for it's long overdue MOT. Despite the battery being on charge for a few hours I ended up having to jump start it. I knew the battery was iffy back in November and have now ordered a new one. Still, it's lasted since I put it on the trike in 2012 ( date code is August 2011), so not too bad for a small battery that doesn't get regular use.
Oh and the XVS past the MOT. ;D
Now for some co-codamol and a lay down.
Post by: Manky Monkey on February 07, 2017, 09:30:39 PM
Sounds like you need a jumpstart yourself Dave.
Post by: Olds on February 08, 2017, 08:14:24 AM
Think I need something. Been up since 4am. Perhaps taking the bike for it's MOT wasn't such a good idea. :( Looks like I may have to sell the bikes. :'(
Never mind at least the trike will be ready for the road again soon and I will never sell that.
Post by: stinkey on February 08, 2017, 08:27:58 AM
I know that feeling ,take it easy sir.. ;)
Post by: spanners on February 08, 2017, 11:43:15 AM
i think we are all in the same club ,, OLD N, KNACKERED TINKERERS,,
Post by: Manky Monkey on February 08, 2017, 07:07:34 PM
Didn't realise it'd got that bad Dave. I'm surprised a man of your talents hasn't come up with his own homeopathic remedy though :)
Post by: merv on February 09, 2017, 07:15:09 PM
Give him time  :D
Joking aside i do hope you start feeling better Dave
Post by: Olds on February 12, 2017, 10:35:37 AM
Oh I do have my own remedy. I make (and consume) Sloe Whisky. Don't worry Fifer, I only use blended for this. The single malt is taken neat.
Battery has arrived and will be conditioned before fitting.
Post by: fifer on February 12, 2017, 08:56:00 PM
Olds , that`s ok .
You can continue to consume your Sloe whisky .
Up here in Haggis land we consume Quick whisky . { Or should that be whisky Quick ? }
Post by: Olds on May 22, 2017, 08:19:46 PM
Nice evening and i'm feeling OK so took the trike out for a short trundle around the village. :) Strong smell of fuel as I put it back into the garage and it turns out that the fuel hose from the pump is leaking. Well actually, it's very slowly dissolving ! It wasn't cheap stuff and was marked as suitable for unleaded yet it's only lasted five years.
At least on the trike it's easy to replace and hopefully the next lot will last a bit longer.
Post by: Manky Monkey on May 22, 2017, 08:44:26 PM
So is that the new Ethanol fuel doing that Dave?
Post by: Olds on May 22, 2017, 09:56:37 PM
That's all I can think it can be. The inside of the hose is slimy and resembles tar and the outside is starting to crack. Hopefully this was an old batch of hose from before they upped the ethanol in petrol. I had to replace the hose and tap washer on the Suzuki few years ago because they had started to dissolve, but that bike was built in the 80's so it wasn't surprising.
Post by: kapri on May 28, 2017, 01:21:33 PM
Normally you can see an inner Teflon liner is modern petrol line .Strangely been tidying my trike frame up today while the engine and box are out.
Post by: Olds on June 02, 2017, 05:28:15 AM
No liner just sticky rubber.  Hoses have been replaced. Won't bother with a pic as I'm sure you all know what a bit of fuel hose looks like.  :D
LH rear brake was locking up before the RH one. Was worried that the RH cylinder was either stiff or leaking but it was fine. Turned out to be the shoes grabbing and I just needed to add a  chamfer to the leading edges of the shoes and readjust.
All ready for the MOT next week at Cliddesden.
Post by: Manky Monkey on June 02, 2017, 07:05:23 PM
Are they still doing trike MOTs there Dave? Weren't they being taken over?
Post by: Olds on June 03, 2017, 06:54:53 AM
Yep  :) New guy decided to start doing them.  Before they only did trike MOT's on a Wednesday as the tester was sort of retired, but now I think it's any day.  Last year I blew the head gasket rushing back from Andover so perhaps it's lucky that I can get it done locally. ;D
Post by: Olds on June 06, 2017, 02:54:41 PM
 ;D MOT done for another year.  While I hate MOT's it's nice to have someone else check the vehicle over and pronounce it safe.
Post by: merv on June 06, 2017, 05:35:44 PM
Thats good news Dave, not that there was any doubt
Post by: Olds on July 26, 2017, 07:15:06 AM
 Had to make yet another gear knob after some f######g b#####d decided to walk off it, again ! >:(
This has now been epoxied in place so should be harder to steal.
Also got around to fitting some rubber strips between the boards and the pick up frame, to get rid of an annoying clatter when riding over the pot holed roads around here.
Post by: paulywombats on July 26, 2017, 08:18:39 AM
On a plus note, you are not being singled out, the whole country has gone with the pot hole look on it's roads. Special !
Post by: Manky Monkey on July 26, 2017, 02:27:09 PM
Seriously Dave?!What possible use would your gear knob be to anyone else? Thieving little scroats who just steal for the sake of it -probably chucked in a hedge once they got bored of playing with it. Was that locally?
Post by: Olds on July 27, 2017, 07:02:40 AM
Yep it was local again. The cue ball one got nicked about this time last year and I deliberately made a replacement that was boring, black and would look out of place on most vehicles. It probably got taken by kids, simply because they could or as a dare and as you say, got thrown away. Damned annoying.
Post by: Manky Monkey on July 27, 2017, 09:24:02 AM
School holidays now -heard a report on the radio the other day, saying that petty theft & vandalism skyrocket during the long Summer holiday.
Post by: paulywombats on July 27, 2017, 01:00:49 PM
Good to know that my tax contributions to the education system keep the crime rate down during term time.
Not having children myself, it's reassuring that my money isn't going to waste educating other peoples kids.
Post by: stinkey on July 27, 2017, 01:15:24 PM
It's not being wasted,just redistributed.. ::)
Post by: Olds on August 26, 2017, 07:09:36 AM
I've had a bit of a problem with the battery getting low and thought it was just because I wasn't using it enough. Turns out that I have a drain on the system. Put a meter across the battery (it was low) and the voltage was varying between 10.2 v and 11.1 v quite rapidly. ???
Items connected when ignition is off, Alternator, sidelight circuit and indicators/hazards.
Disconnected the alternator thinking it might be the  diode pack breaking down. No difference. Pulled the fuse for the lighting circuit. Nope that's not it.
Tried removing the fuse for the indicators. Yep voltage now stable at 11.5 v.
 Looks like it's the electronic indicator relay I fitted to overcome flash rate problems is at fault and that's why the drain is varies. Until I get around to fitting a new one, I'll pull the fuse when not using the trike.
God I hate electricity, you can't see where it's disappearing to.
Post by: paulywombats on August 26, 2017, 09:14:44 AM
That's because electricity phenomenon -
Do doo be-do-do
Phenomenon
Do do-do do
Phenomenon
Do doo be-do-do be-do-do be-do-do be-do-do-doodle do do do-doo do!
Think Muppets for the tune.
Post by: Olds on August 26, 2017, 03:26:53 PM
:D :D
Sorted for now, though it would no longer be MSVA compliant. Removed the lead from the relay to the hazard switch and now just use the switch to connect the left and right indicator circuits together.
This means that to turn on the hazards requires flipping the switch and turning on left or right indicators. Hardly a difficult task, I can do both at the same time, but technically it's not the single operation required.
Will still try to sort it out properly later.
Post by: stinkey on August 28, 2017, 04:23:11 PM
Hiya mate.i did what you said RE the rad?
Post by: Olds on August 29, 2017, 03:32:45 PM
That looks a bit better.  :)
Post by: Olds on April 14, 2018, 05:35:30 PM
Pulled the trike out from hibernation and took it out for a bit of a ride. Nothing to report apart from, it still works. :)
Post by: Manky Monkey on April 14, 2018, 05:51:50 PM
Must be the most reliable Reliant around :)
Post by: spanners on April 14, 2018, 05:52:01 PM
I will more than glady regime it anytime you want
Post by: Olds on May 24, 2018, 12:00:06 PM
MOT passed again with no problems. Wasn't due till 8th of June but with all the great weather we have been having, I though I'd get it done while the going was good. As usual the heavens opened and I got soaked.
Love going to the garage at Cliddesden as it's like riding into the past. Model AA Ford pickup, Ford Pilot pickup, Ford Pilot saloon, split screen Morris Minor, Austin 1300 Countryman (one of only four left), Fergy tractor and this Thorneycroft Swiftsure oil tanker.
Post by: Manky Monkey on May 24, 2018, 04:57:59 PM
Congratulations on the MOT :)
Last time I was at the Cliddesden garage, a few years ago, the old man had his grandson inside the tanker body, cleaning it out.
Post by: Olds on May 25, 2018, 03:51:53 AM
Think that would have been in 2013 as they were working on the tank when the trike went for it's first MOT.
The "old man" is Tom Mansbridge who is heavily into old and unusual vehicles, always comes over for a chat when he sees the trike there.
The lovely Pilot pickup.
Post by: stinkey on May 25, 2018, 08:21:15 AM
OMG that's so lovely..I'd like that
Post by: JayJay on May 26, 2018, 01:12:42 AM
Looks an interesting place to visit. Pilot is very nice. Can't be many of those pickups around or if there is, they must be hidden away.
Your trike is very nice too. Still looking good. I think the weather is going to be a bit like that all week, sunshine and storms. So you take your chances. Does the back fill up? You should put one of those rain gauges in it to see how much rain you've ridden in.  :D
Must be nice to have a trike that is so reliable, though that must be down to your craftsmanship. 8)
Post by: Olds on May 26, 2018, 06:21:00 AM
Thanks JJ.
 Only time it's filled with water was, when I lined it with polythene and used a hose, to static load test it. :)
The Pilot pickups were only made for export, mainly Australia. There was also another pickup version called the Coupe Utility which is drop dead gorgeous.
There is a tenuous link between the V8 Pilot and Basingstoke, in that Ford started production using surplus Canadian  flat head V8's that were destined for the Bren Gun Carriers built by Thorneycroft.
Post by: Chevy Rick on May 26, 2018, 10:00:40 AM
 >:( JJ you have got a trike that is reliable, that is until you let the water run low in the rad ???
Post by: Olds on May 26, 2018, 10:24:18 AM
I'm staying out of this one. ;)
Bit of a sad day for the trike. With my daughter now married and moved up north, the pillion pegs will no longer be needed, so have been removed.  :(
On a brighter  note, the silencer has been reworked slightly internally and now produces a more pleasant (to me anyway) sound. Not loud, just deeper in tone :D
Post by: Manky Monkey on May 26, 2018, 03:02:11 PM
I remember her as a very enthusiastic pillion at the Popham bike show Dave. End of an era.
I deliver the Mail in Kempshott, Basingstoke. One of my customers, Mr Blissett, remembers the bren gun carriers being test driven up & down Kempshott Lane. Sometimes the driver would stop & give him a lift home from school in them.
He also remembers seeing plumes of black smoke rising from Kempshott House, (later demolished to make way for junction 7 of the M3), as the Army tested flame throwers there.
Post by: morrag on May 26, 2018, 04:52:46 PM
Dave, that trike of yours is a classic example of less being more! ;D, absolutely ace, really, and the others I would couple with it in that bracket would be any or Mr. M's past trikes,....just sayin'....
Post by: JayJay on May 26, 2018, 07:05:40 PM
Umm let me see. My trike kept breaking down, something to do with electrics. Then the brakes failed on the way back from Basingstoke after the bumpy ride broke the copper pipe allowing the brake fluid to run out (I changed it to braided hose after that). You remember me overtaking you at that junction because I couldn't stop on a blind bend!   :o
Even though I carried bottles of water with me and had an overflow receptacle attached, the radiator always overheated. I have a very nice fan sitting in a box to be added to the trike (not something I can do) and a nicely reengineered head in my garage that I could put back on but I'm just physically unable to.
So no, I don't think I ever had a reliable trike in the way Olds has. So there.   :P  :-*
I would love to have my trike back on the road because even with the above problems, I enjoyed riding it even if the first time I drove it up my drive, I took out my dustbin because I forgot I was on 3 wheels and not 2!  ;D
Post by: Olds on May 26, 2018, 08:24:15 PM
Thank you Morrag. Kind words indeed.  :-[
I never wanted it to be an obvious custom and it doesn't grab attention from Joe public like those covered in flash paint / chrome or even those dubious, angle iron and checker plate things, but I'm happy with that.  :)
As to reliable. It's not been faultless. In the first year I had... engine problems (someone had thrown it together), a set of points that wore out after only 100 miles, a broken gear linkage (rode home in second) and a broken mudguard stay, disintegrating switch gear, plus a few little teething problems.
 All of which I can only blame myself for as I'm the only person that has ever worked on it. :)
Post by: terry t on May 26, 2018, 08:43:08 PM
Just a few little teething problems as Dave would say JJ xx
Post by: stinkey on May 26, 2018, 09:26:23 PM
Well Dave I think you underestimate your Trike..it certainly does stand out and in fact I know a few people who wish to build similar ? JJ I envy you and others because as yet I've never ridden a trike enough to find out it's problems? But working on mine with that Aim.. 8)
Post by: Olds on May 31, 2018, 03:27:02 PM
Thanks stinkey.
Seeing the heat shield Andy is making, reminded me that i have burnt two pairs of shoes (well actually one pair, cos they're both left foot) on the trike.
Unfortunately where I need a shield is right on the bend. So, lots of hammering of sheet stainless steel ensued. Damn I hate working stainless. Not totally ripple free but good enough. Hidden tabs on the back take jubilee clips. Need to buy a pair of nice stainless ones, but for the pic it's held on by some really nasty Halfrauds ones that I wouldn't dare use on a hose.
Sorry stinkey. No holes or slots.  :)
Post by: Manky Monkey on May 31, 2018, 06:27:04 PM
What size is the pipe Dave? I've just taken 2, 1 5/8" stainless ones off.
Post by: Olds on May 31, 2018, 06:52:56 PM
1 3/8" but thanks.
Post by: Olds on July 14, 2018, 09:26:04 AM
Trike is starting to show it's age with chips in the paint, etc. It's used and abused, cleaned once a year and to be honest that's fine with me, but the seat definitely needed some TLC. While I quite liked the tan colour it always seemed somewhat at odds with the colour scheme. So after re staining/polish, the leather is more of a worn black/brown colour and I love it.
Only one problem, now I have to do something about the rear tank straps. Will check if I have any of the harness leather left over from bonnet straps I made. If not, the ones fitted will get the same treatment as the seat.
Post by: paulywombats on July 14, 2018, 11:20:15 AM
Hi Dave
Seat looks fantastic. For me personally I like it in black against the colour scheme.
Post by: Manky Monkey on July 14, 2018, 12:46:03 PM
Never been a brown saddle guy myself. What stain did you use Dave?
Post by: paulywombats on July 14, 2018, 01:09:38 PM
Think it was a black one Andy. ;D
I'll get me coat.
Post by: Olds on July 14, 2018, 03:20:01 PM
;D
My own mix. Roughly 70% black 15% dark brown, shoe polish, 10% raw linseed oil 5% dubbin. Boiled up then several coats, applied warm and soaked into the leather using a propane torch.
You can buy leather stains but they tend to give a very uniform solid colour, which isn't what I was after.
Post by: stinkey on July 15, 2018, 07:16:00 AM
Oh s**t..you shouldn't have mentioned the propane torch..Andy may get ideas, and ya know what's likely to happen ? :o
Post by: Olds on August 08, 2018, 08:57:14 PM
 ;D
Got around to dying the tank straps to match the new seat colour and made a couple of polished stainless thumb nuts, for the electrics box cover, to replace wing nuts.
Post by: stinkey on August 08, 2018, 10:24:42 PM
Looks better..me like
Post by: Olds on August 09, 2018, 11:37:28 AM
Thanks.
A small alteration to the thumb nuts. Using cut to length, button head stainless screws, the tops of the threads have been blanked off. This stops me from, over tightening, stops water getting down to the threads and makes them visually similar to the nearby, tank frame mounting screws and washers. A small detail I know but worthwhile.
Post by: Manky Monkey on August 09, 2018, 01:31:20 PM
Details are always worth it.
Post by: Olds on October 02, 2018, 02:57:05 PM
D'oh ! Battery has died. Been getting iffy for some time and tried trickle charging, but it just drops back to 11v within a couple of hours.
No luck getting the conventional lead acid battery I want/will fit, in this country due to the new laws so have ordered one from France.
Post by: minimutly on October 03, 2018, 06:43:59 PM
The whole ethos, or beginnings if you want, of this country has gone down the pan.
Blame the media happy politicians, who voted for them?
Do I get away with that now Andy's away??
Post by: Olds on October 04, 2018, 09:35:17 AM
 ;D Think so, but don't push it.
New battery arrived this morning. Not bad, as I ordered it late Monday evening. Good price too.
Being as until they are filled, the shelf life is measured in decades not years (though it may need charging upon filling), I am tempted to order another.
This would of course be illegal. You can have as much battery acid in unsealed batteries as you want, but any quantity in a sealed container is illegal to posses without a special licence. The law is an ASS
Post by: merv on October 05, 2018, 07:52:10 AM
You are right about the law being an ass. That just don't make any sense at all.
Post by: BikerGran on October 05, 2018, 10:04:39 AM
How long has that been the case?  Or was it because you wanted it delivered in which case the acid is, as you say, in a sealed container, rather than getting it from a local workshop who would fill it and charge it?  Wondering what the price difference would be as I shall have to get a battery for my trike before I can sell it.
Post by: paulywombats on October 05, 2018, 10:35:48 AM
Don't sell Mother!! 8)
Post by: Olds on October 05, 2018, 11:23:19 AM
BG yes you can get one from a dealer filled and ready to fit but in this case it would have meant a two hour round trip. Tayna batteries will fill and send by courier but it costs more and they didn't have this one or an alternative in stock and had no idea if they would ever have them again or the price if they did.
 Looks like conventional batteries for bikes may become a thing of the past.
Maintenance free, sealed batteries, like gel, absorbent glass mat etc are no problem to get hold of but seem to have a short life span if not used/charged frequently.
Post by: BikerGran on October 05, 2018, 08:10:46 PM
Can't sell my mother as she passed on many years ago!  No point keeping the trike if I can't ride it.
Post by: Olds on May 21, 2020, 03:36:04 PM
Trike is not on the road due to no MOT, but on the May bank holiday that was VE Day, to relieve the boredom, I went to a "Stopathome Rally".  ;D
 When putting the trike away I found both rear brakes stuck on hard. Only way to move it was slackening the adjusters a notch.  >:(
Got around to checking it out today and found both slave cylinders had seized. :(
 Removing the pistons was a real pain, but luckily everything cleaned up OK, so rebuilt with new seals, a generous coating of red grease and a brake fluid flush, all is fine again.  :)
 Ready for MOT when this Corona business starts to ease up.  :-\
Post by: Manky Monkey on May 21, 2020, 04:45:15 PM
A rather fine line-up.
Post by: Olds on May 23, 2020, 11:19:31 AM
Thanks. It gave passers by something to look at and me a chance to clean out the garage a bit.
Seems the well in our front garden is on some sort of 'treasure hunt' map so even during 'lock down' we get cyclists and walkers, stop and take a pic of it.
Title: Re: Deliverance
Post by: Manky Monkey on May 23, 2020, 02:11:19 PM
You've become the village landmark :)
Post by: Olds on August 27, 2020, 03:50:53 PM
The village idiot more like.  ;D
Been a long time since I did anything to the trike, but house is nearly finished and it's raining so not going to work outside.
 Never been happy with the rear reflectors, being just screwed to a bracket, so made up a pair of new housings to bring them almost inline with the face of the tail lights.
 Seems I've run out of black paint again.
Post by: Manky Monkey on August 28, 2020, 07:19:26 PM
How on earth did you make those Dave?
Post by: merv on August 29, 2020, 08:13:49 AM
They are rather smart
Post by: triker_Chewie on August 29, 2020, 11:44:39 AM
skill and patience
Post by: Olds on August 29, 2020, 01:11:55 PM
 ;D
Metal spinning on the lathe. Same as when I made the bellmouths  and hubcaps for the speedster.
Five attempts to get two good enough and it's really not good for the Myford.
Post by: TwistedPatience on September 05, 2020, 10:37:58 AM
Myford not really rigid enough for spinning, good old boxford CUD or BUD with some weight behind it would be much better but you have done a great job with what you have.
Hats off to you Olds.
Post by: Olds on September 17, 2020, 07:19:13 AM
  :) Yep. Worried about the load on the old white metal headstock bearings, so anneal often.
