April 22, 2026, 10:29:57 AM *
Pages: 1 ... 31 32 [33] 34 35 36
Author Topic: A little progress  (Read 160712 times)
goose
« Reply #480 on: July 16, 2014, 10:08:16 AM »
lovely trike , well done sir  Wink
« Reply #481 on: July 16, 2014, 09:32:36 PM »
Video needs subtitled.
Ok select first gear, clutch out, oh is this first, select first, check again if it's first, I'll try to move, hold on need to check I'm in first, have I done that yet? check bike is in first again, yep definitely first and move off, bugger no throttle is a pain  Tongue Grin Grin Grin
yeh all too true
Looks good on the move mate.
when i could get it to move lol  Grin Grin
cheers Goose
« Reply #482 on: July 16, 2014, 09:41:52 PM »
Looks like you were born to ride a trike  Smiley
« Reply #483 on: July 16, 2014, 09:46:37 PM »
Very nice mate well done.
« Reply #484 on: July 16, 2014, 09:57:04 PM »
maybe with a bit more practice  Wink
thank Hunter
« Reply #485 on: July 17, 2014, 08:50:06 PM »
well it didn't take long for the gremlins to move in,small puddle of water under the rad and oil on the bottom crossmember under the front crank pully ! I'll try some seal softener but will order a new seal anyway and as for the rad maybe some k seal for the time beening
« Reply #486 on: July 17, 2014, 09:23:00 PM »
Minor problems though really mate. You're doing fine.  Smiley
« Reply #487 on: July 17, 2014, 09:41:59 PM »
Nice job, what would custom building be without a few little problems  Roll Eyes Wink Smiley
« Reply #488 on: July 18, 2014, 10:34:30 PM »
yep only teething troubles i hope ,it looks like the bottom tank of the rad is cracked so rad weld type product may not work we shall see.
had a go at making cables tonight,bought a throttle cable kit for a peugeot 406 and some solderless nipples and off we go
http://i1056.photobucket.com/albums/t373/Eddie096/6D178193-F6A7-43A9-A97D-44F933232E28_zpsfmu4ywgx.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/F082150B-1496-4936-AA34-8690CAAC9B0E_zpsphzmdahp.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/3CC3A474-2242-46E4-97A0-EC02A00367A8_zps12bqckkc.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/70578BE9-F743-4FE9-BD2E-A15838D04F2D_zpskqtgzoqi.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/F90D1991-B747-48C4-AE50-0C520755C63D_zps9aqjhw5t.jpg
A little progress
all working fine if a little heath robinson,and had to put a return spring on the choke as the cable wouldn't push it off fully
« Reply #489 on: July 19, 2014, 05:52:35 PM »
went for a little spin up and down the lane where i live,it was interesting. forgeting to steer being the main problem  Roll Eyes Shocked
« Reply #490 on: July 19, 2014, 07:09:21 PM »
A common problem for those used to a bike.  Smiley Leaning to turn, no longer works does it Cheesy
 Don't worry, first time out I thought- Oh f###, what the hell have I built !
« Reply #491 on: July 19, 2014, 07:20:59 PM »
Excellent build;D
« Reply #492 on: July 19, 2014, 09:08:09 PM »
that is exactly what crossed my mind and never having riden a trike before it was a shock but it good to know I'm not alone.
thanks Kapri it's turned out better than i could have hoped
« Reply #493 on: July 20, 2014, 06:03:43 PM »
the fleet
« Last Edit: July 20, 2014, 06:06:06 PM by scannerzer » Logged
« Reply #494 on: October 11, 2014, 06:27:27 PM »
Now i can see why Olds built a pick up  Grin had a little trip to the shops today and had to improvise
http://i1056.photobucket.com/albums/t373/Eddie096/5B8660D2-3F29-44F7-8851-756A3E996F9B_zpsspamcegx.jpg
A little progress
now some questions
I've got 14" wheels with 60 profile tyres and out of a junction i need to slip the clutch quit a lot. the clutch is quit sharp with only about 20 mm of travel, how do the rest of you compare to this?
the other question is the brakes which on a normal stop seem to work quite well but i'm a bit wary of how they'd perform in an emergancy stop,i don't even have a hint of lock up front or rear but do have reasonable retardation,again how are ye'all finding it . brakes are standard drum at the rear all new wheel cylinders etc linked to 1 front disk then the other front disc is to the standard front master.
any and all thoughts or comments welcome
cheers lads
eddie
