goose
« Reply #480 on: July 16, 2014, 10:08:16 AM » |
lovely trike , well done sir
« Reply #481 on: July 16, 2014, 09:32:36 PM » |
yeh all too true Looks good on the move mate.
when i could get it to move lol  lovely trike , well done sir  cheers Goose
fifer
« Reply #482 on: July 16, 2014, 09:41:52 PM » |
Looks like you were born to ride a trike . .
« Reply #483 on: July 16, 2014, 09:46:37 PM » |
Very nice mate well done.
« Reply #484 on: July 16, 2014, 09:57:04 PM » |
Looks like you were born to ride a trike . . maybe with a bit more practice  Very nice mate well done.
thank Hunter
« Reply #485 on: July 17, 2014, 08:50:06 PM » |
well it didn't take long for the gremlins to move in,small puddle of water under the rad and oil on the bottom crossmember under the front crank pully ! I'll try some seal softener but will order a new seal anyway and as for the rad maybe some k seal for the time beening
« Reply #486 on: July 17, 2014, 09:23:00 PM » |
Minor problems though really mate. You're doing fine.
« Reply #488 on: July 18, 2014, 10:34:30 PM » |
yep only teething troubles i hope ,it looks like the bottom tank of the rad is cracked so rad weld type product may not work we shall see. had a go at making cables tonight,bought a throttle cable kit for a peugeot 406 and some solderless nipples and off we go  A little progress  A little progress  A little progress  A little progress  A little progress all working fine if a little heath robinson,and had to put a return spring on the choke as the cable wouldn't push it off fully
« Reply #490 on: July 19, 2014, 07:09:21 PM » |
went for a little spin up and down the lane where i live,it was interesting. forgeting to steer being the main problem  A common problem for those used to a bike.  Leaning to turn, no longer works does it  Don't worry, first time out I thought- Oh f###, what the hell have I built !
« Reply #491 on: July 19, 2014, 07:20:59 PM » |
Excellent build;D
« Reply #492 on: July 19, 2014, 09:08:09 PM » |
went for a little spin up and down the lane where i live,it was interesting. forgeting to steer being the main problem  A common problem for those used to a bike.  Leaning to turn, no longer works does it  Don't worry, first time out I thought- Oh f###, what the hell have I built ! that is exactly what crossed my mind and never having riden a trike before it was a shock but it good to know I'm not alone. thanks Kapri it's turned out better than i could have hoped
« Reply #493 on: July 20, 2014, 06:03:43 PM » |
the fleet ]
« Last Edit: July 20, 2014, 06:06:06 PM by scannerzer »
« Reply #494 on: October 11, 2014, 06:27:27 PM » |
Now i can see why Olds built a pick up  had a little trip to the shops today and had to improvise  A little progress now some questions I've got 14" wheels with 60 profile tyres and out of a junction i need to slip the clutch quit a lot. the clutch is quit sharp with only about 20 mm of travel, how do the rest of you compare to this? the other question is the brakes which on a normal stop seem to work quite well but i'm a bit wary of how they'd perform in an emergancy stop,i don't even have a hint of lock up front or rear but do have reasonable retardation,again how are ye'all finding it . brakes are standard drum at the rear all new wheel cylinders etc linked to 1 front disk then the other front disc is to the standard front master. any and all thoughts or comments welcome cheers lads eddie
