November 11, 2025, 05:37:23 PM
General Tech
Beam axle or stub axle options.
Topic: Beam axle or stub axle options. (Read 3656 times)
The North
May 24, 2012, 10:12:23 PM »
I need a narrow beam axle and it needs to be light as possible, used to make up light beam axles using Hillman imp stub axles and the worked well imp stuff is rare though now.
Any suggestions on a suitable option for stub axles, or a beam axle off a old 30s type motor. I have a pop 103 e sit up and beg front axle but it is a it heavy and wanted it for spares for my prefect, but if needs must i will hack it about.
Re: Beam axle or stub axle options.
May 24, 2012, 10:46:46 PM »
why not just make one
The North
May 24, 2012, 10:52:27 PM »
Quote from: spanners on May 24, 2012, 10:46:46 PM
I maybe did not explain myseld very well, Stub axles to fit a made up beam axle, needs to be light, what old cars had stub axles like the imp in sise weight etc.
May 25, 2012, 05:06:58 PM »
Probably worth having a word with my brother Brock or CunningPlan, they being our resident drag car builders. Mr Brock may even have a spare Pop beam, though not sure if it had the hubs on.
madron
May 25, 2012, 07:36:30 PM »
i have a morris dropped beam axle narrower and a bit lighter than pop will swap for your pop axle
also as so many people are triking reliants what about the front stub axles off them
May 25, 2012, 10:32:15 PM »
Quote from: madron on May 25, 2012, 07:36:30 PM
thats sort of what i was ,,hinting at ,, loads that can be used , just take,s some real thought,,, not ,brain, pickin,
The North
Reply #6 on:
May 25, 2012, 11:15:00 PM »
If you type in to google sporting car trials look at the average front axles you will get an idea what i am after. The old imp stubs were spot on size weight the lot, reliants are in truth a bit heavy as are pops but about passable just. I want super low weight at the front especially.
The North
Reply #7 on:
May 26, 2012, 04:44:16 PM »
I picked up a pair of A40 Devon front trunion/ hub assemblys today, i will make some side plates and see how it turns out.
Reply #8 on:
May 27, 2012, 06:56:12 PM »
is this for a trials car project ?? got quite and hankering for a Dellow or something home built along those lines...
The North
Reply #9 on:
May 27, 2012, 11:06:30 PM »
This is for a sporting car trialer, the dellows did and still do see use in pcts Production car trials and classic trials long distance trials like the Lands end Edinburgh trial etc.
I think Dellows fetch strong money that is when they come up for sale. Many more affordable options out there like the Marlins and other popular kit cars that are eligible.
Remember unless you get a car with an existing registration etc, you will need to submit the car for IVA Individual vehicle approval this costs over 400 quid and anther smaller fee for retest if it fails.
Not a smooth road to happy motoring as i see things, avoid it like the plague and my advice only buy a car with registration etc.
Reply #10 on:
May 28, 2012, 11:25:58 AM »
I have a kitten chassis which does have a V5 if the old owner can find it or at least what it's reg was... but I would probably buy in a chassis or something with a V5... still thats a long way off as I need to finish the Pop first...
