Speed calculator This is a new page I have added to my website and it should make it easier to calculate speeds on a 4 speed box setup
You can alter the axle ratio , gearbox ratios in each gear , tyre size settings and Revs https://sites.google.com/site/fifersrelianthintsandtips/speed-calculator-chart .
Direct Download link https://dc2.safesync.com/DVdDvPQ/SPEED%20CHART.xls?a=C1EQVCWOdBsExtract from website above ;
Thanks to R3W forum member toadtoad for the giving me the link to the original spreadsheet by a Mark Allanson .
I have modified the look of the spreadsheet to hopefully make it easier to view .
While I cannot guarantee the accuracy of the spreadsheet , I believe it is probably accurate .
The above spreadsheet might not work for some folkTo use the chart above just click your mouse into a section on the
spreadsheet containing RED numbers and type in your new number .
Once you have typed in the new number just click on any grey square
and note that all the other numbers will change .
PLEASE LET ME KNOW IF IT DOES NOT WORK
If the original owner of the spreadsheet gets in touch with me I shall give full credit and /or remove it if they so wish.
