November 13, 2025, 09:11:44 AM *
Author Topic: one for fifer me thinks..........Starter motor swop  (Read 2681 times)
RODeo
« on: February 25, 2012, 05:22:13 PM »
Can I convert from new type pre engaged s/motor to old type Inertia by just changing the engine back plate?(seen your info to swop the other way on R3W) Do I use the flywheel /clutch for the early type s/motor as well,or is there some incompatibility ?
         Rod
« Last Edit: February 25, 2012, 06:30:28 PM by RODeo » Logged
« Reply #1 on: February 25, 2012, 08:30:57 PM »
Yep  Smiley
Here,s one I did earlier  Grin
Click on photo to enlarge
http://i423.photobucket.com/albums/pp316/fifer3w/STARTER%20MOTORS/OLDSTYLEINERTIASTARTERFITTEDINENGIN.jpg
You will need to swap the flywheel due to the different teeth but you might be able to use your old clutch if they are the carbon thrust type
I had an 1989 engine with the carbon thrust clutch , a bu***ed pre-engaged starter and the gearbox was also b***ed .
As I did not have another pre engaged gearbox or another pre engaged starter motor but had about 6 inertia type gearboxes lying about and a new inertia starter motor it was a no brainer decision .
On the starter motor / gearbox swap I did on that one above all I did was change the flywheel and clutch but I did not change the back plate and ALL I had to do was slot the holes .
I changed the box with the engine still in the car and then found that the holes in the pre engaged starter are smaller spaced than the 5 inch ? holes on the inertia starter so I used a Dremel to slot the plate insitu .
I then went into my hut and gave myself a darn good thrashing  Embarrassed
You will need to fit a separate starter solenoid as per
http://i423.photobucket.com/albums/pp316/fifer3w/STARTER%20MOTORS/OLDSTYLESOLENOIDFORINERTIASTARTERFI.jpg
Swop the flywheel then , before fitting the replacement gearbox , try the new inertia starter on and see what you have to do to make it fit .
« Last Edit: February 25, 2012, 08:36:10 PM by fifer » Logged
RODeo
« Reply #2 on: February 26, 2012, 08:31:30 AM »
Thanks fifer
