November 11, 2025, 07:19:49 PM *
Pages: 1 [2]
Author Topic: pillar drill prob  (Read 10257 times)
zakboy
« Reply #15 on: January 28, 2012, 03:24:43 PM »
Ok T bone thanks for that much appreciated
« Reply #16 on: January 28, 2012, 09:42:28 PM »
i do mains voltage for a living.
on your meter you could have a capacitance setting, check the manual for how to select it.
the capacitor SHOULD discharge thru the motor windings but i always Zap 'em before i touch 'em, oh and be sure to unplug the damn thing from the wall socket
the capacitor my have "popped" which will be obvious as its come to bits. you wont have to test it then
disconnect the cap (usually spade lugs) and using the meter on capacitance test against the value on the capacitor, if its pretty close then you've got other problems but you ll probably find its way out.
but as it's now not making any noise I'm not sure if you ha vent burned  a winding or a connection so while its in bits give all terminations a once over. be sure to get a motor starting capacitor as one from a fluorescent light or ballast wont be up to snuff
i got a bench grinder and pillar drill, both with blown caps and repaired them with aud20 capacitors, that's a pretty common fault with 240v equipment and company's here throw the gear away thinking the cost of a sparky to be more then the repair is worth
good luck
zakboy
« Reply #17 on: January 28, 2012, 10:03:13 PM »
hi Chewie this is the multimeter witch seting do i need to have it on is it the horse shoe shape pic
« Reply #18 on: January 28, 2012, 10:16:19 PM »
sorry mate you dont have the setting  Sad
zakboy
« Reply #19 on: January 28, 2012, 11:04:10 PM »
ok chewie never mind, cheers anyway
« Reply #20 on: January 29, 2012, 12:29:43 AM »
Zakboy, without wishing to impugn your ability, or enthusiasm, but for safety sake, maybe you should now consult a trained Electrical man to check this motor over, just in case you get it wrong. 240v AC ain't really for amateurs, however enthusiastic, really, Morrag
zakboy
« Reply #21 on: January 29, 2012, 01:58:16 AM »
yes you right Morrag mains electricity has to be respected, will get it checked out by a some one better qualified.cheers  Smiley
digger06
« Reply #22 on: January 29, 2012, 06:17:37 AM »
mine wasdoing the same but it was the front pulley slipping on the shaft,
can you see the belts when its running, and checked they arnt moving?
if they are its the pulley
zakboy
« Reply #23 on: January 29, 2012, 11:26:28 AM »
I think i can rule that out Digger, as i have disconnected the belts to see if the mottor would spin on its own with out the load but it wont,but thanks for your input Digger
Pages: 1 [2]
