November 11, 2025, 06:18:18 AM *
Author Topic: Fuel Filters  (Read 1962 times)
« on: May 23, 2012, 10:56:17 AM »
Just an observation that might help someone,but Im sure you more experienced bike people will know this anyway,so apologies for ramble! Grin ....FIT A FUEL FILTER
 When I fitted my electric petrol pump it advised fitting an inline filter between the tank and pump.I fitted a transparent plastic bodied one. Today I was draining the tank to refill it and make a depth gauge as I filled it with measured amounts.I also wanted to check whether there was any obstruction as I felt the engine intemittently needed more fuel at some revs .
   The Harley type tank valve also has a filter poking up into the tank. I removed the tank valve to check the inside filter,it was clean. The mesh is very fine and there isnt a split in it to let any big particles through.
 BUT... the inline filter mentioned earlier looked a little dirty inside,I thought it was because it is in shadow under the tank. I removed it and it was really choked up with gritty particles,which Im assuming to be from the grinder when I was building the tank and also when I slit it to insert a baffle after I had run it on the engine.At the time, I washed the tank out several times,and thought it was clear.So it just goes to show how handy a fuel filter can be
   I'll just go and ramble outside now!
           Rod
« Reply #1 on: May 23, 2012, 05:17:39 PM »
I'm fairly sure my trike could do with an inline filter but there just isn't room to fit one!
« Reply #2 on: May 23, 2012, 09:14:37 PM »
Definitely worth fitting. A couple of quid for a filter can save an awful lot of hassle & expense later.
one arm bandit
« Reply #3 on: May 23, 2012, 09:44:14 PM »
ive got one before the fuel pump on mine same as rod i recently drained the tank to seal after a seam leek, had a new fuel tap on brought when i got the tank the filter on this is spotless, however my inline filter looks like toilet water after a non flushed floater has been swiming threr all night, i got a pkt of two for £3 so i changed it today when i refitted the tank, agree with mm why risk having to strip the carb(s) for the sake of a few nuggets Wink
