« Reply #45 on: February 06, 2010, 05:37:51 PM » |
Todays progress:
Tank stripped (eventually!!!!), filled, and primed (Almost, I ran out of primer!?!?!?!) Front Wheel stripped and primed! Angle grinder taken to the frame!
« Reply #46 on: February 06, 2010, 07:28:09 PM » |
Thanks Clive. Will collect it from you at the Basingstoke show if that's O.K Coo, Jaffa Cakes. I haven't had one in ages. Fancy one now. So what have you done to your frame then?
« Reply #47 on: February 06, 2010, 08:45:23 PM » |
Nothing too drastic, just ground off the rear foot peg mounts, and a couple of spurious leftover bits from the original frame!  Clive's Chopper Build Oh, and managed to start a helmet, just to keep my hand in at the old painting malarky!! As an aside, after seeing the pic of JJ you posted, I'm feeling more and more drawn to building/buying a reliant trike!!!!!!!  If we bump into each other at the Picket Piece show, you can have the tank then! Or pop in on your way, and get it then! Clive
« Last Edit: February 07, 2010, 04:41:44 PM by Clive »
« Reply #48 on: February 06, 2010, 11:29:46 PM » |
JJ's was built by a guy called Mick in Kent. He also built the Honda trike Muffin's missus, Michelle's just bought. He just keeps churning them out! Only met him once, but his preferred style seems to be streamlined & panelled in -an ideal canvas for your paint skills? You cannot resist the call of the mighty Reliant!
« Reply #49 on: February 07, 2010, 04:40:55 PM » |
Today, I have: Primed the tank  Clive's Chopper Build Painted the front wheel  Clive's Chopper Build Started to build the engine/gearbox!!!  Had to stop at this point, as had no jointing compound  Quite pleased with myself for getting this far with it!!  Clive's Chopper Build  Clive's Chopper Build Oh, and finished painting the helmet! Just to prove that painting doesn't need to involve airbrushes, and all sorts of fancy stuff, this was completely done with masking tape, and halfords rattle cans!! Not worried about the shiny finish, as when it's completely dry it's getting flatted, and then a Matt finish clear applied!  Clive's Chopper Build  Clive's Chopper Build Clive
« Last Edit: February 08, 2010, 07:10:28 AM by Clive »
« Reply #50 on: February 08, 2010, 10:32:47 AM » |
cracking helmet job mate
« Reply #51 on: February 14, 2010, 04:57:55 PM » |
Got some more done while waiting for the CJ to arrive!!  Front Wheel finished  Clive's Chopper Build Tank with first layer of paint on  Clive's Chopper Build Same as the frame  Clive's Chopper Build Engine done  Clive's Chopper Build  Clive's Chopper Build  Clive's Chopper Build and a general shot of the garage for the heck of it (after the CJ arrived!!)  Clive's Chopper Build Clive
« Last Edit: February 14, 2010, 10:50:43 PM by Clive »
gazzagood
« Reply #52 on: February 14, 2010, 05:32:49 PM » |
I always know what I'm doing. Can you help me PLEASE
« Reply #53 on: February 14, 2010, 10:43:38 PM » |
I've never seen a garage that clean before! Nice chop frame Clive.
« Reply #54 on: February 15, 2010, 03:53:49 PM » |
It's just the size of it Andy - all the stuff doesn't look so untidy cos it's not piled up!
« Reply #55 on: April 12, 2010, 07:18:22 PM » |
So, back to working on this!!  Finished the frame with another coat of yellow. Then decided to change the colour scheme slightly. The wheels now gold, and the forks look like this (well, ones done!), (pearlescent white, gold, bronze, and yellow!!) prior to clearcoat.  Clive's Chopper Build and the tank has it's artwork started  Clive's Chopper Build  Clive's Chopper Build Clive
« Last Edit: April 12, 2010, 07:20:17 PM by Clive »
« Reply #56 on: April 13, 2010, 08:41:22 PM » |
I do like a nice trad' flamejob. Your painted fork legs are unusual -makes you wonder why no-one else really does it. Worked out well on the cafe racer.
bitzman5
« Reply #57 on: April 13, 2010, 11:40:55 PM » |
Hi Clive what paint did you use on the engine
« Reply #58 on: April 14, 2010, 07:21:25 AM » |
It's Halfords VHT Aluminium paint buddy!
MM, yeah, I don't know why more people don't paint them either!?!
thebigdogsix
« Reply #59 on: April 15, 2010, 07:30:41 PM » |
Would this stuff work/be suitable on brake calipers?
