January 26, 2026, 03:25:18 PM
Only the crumbliest, flakiest...
Topic: Only the crumbliest, flakiest... (Read 1642 times)
April 17, 2008, 10:26:59 PM »
Big brother Brock's been trying out the metalflake paint he brought home from his State-side hols. Rainbow flake added to the lacquer over a gloss black base.
Very pretty Steve.
Oh, that's the back axle for his new drag car by the way.
brock
Re: Only the crumbliest, flakiest...
April 17, 2008, 10:55:52 PM »
how the hell does he work in a tip like that ?
April 17, 2008, 10:56:46 PM »
Maybe you should spray some of that 'flake on the walls bro.
April 18, 2008, 12:04:24 AM »
thats looks well tidy
what make diff is it may i ask?
brock
April 18, 2008, 01:14:50 AM »
It is (was ?) a 9" Ford, just about the most popular drag racing axle. Originally from light trucks etc, this one has been narrowed to about 32" and had different ends fitted so that we can run the bearings on the outside of the tubes and use a "floating" hub set, it means that if a shaft breaks the hub stays attached. The big brace across the back is also added. 9" refers to ring gear size, there are others that will do the job but the 9" has far more aftermarket parts and gear sets available.
April 18, 2008, 06:53:35 AM »
thanks for the info
texon
Reply #6 on:
April 18, 2008, 05:17:10 PM »
Rainbow flake always looks great over black and the colours it shows are outta this world but im not struck on it on light coloured surfaces
