January 26, 2026, 03:53:25 PM *
Pages: [1] 2 3
Author Topic: Been Welding  (Read 5802 times)
reliantman
« on: April 05, 2008, 04:46:19 PM »
It has been a while, but I have finally decided what I am doing with my bits.
VB gave me a lump & gearbox, and I cut up the spare Ural frame I had here. Its going to have leading links with a Suzi GS 850 back wheel fitted.
« Reply #1 on: April 05, 2008, 08:46:46 PM »
That's an interesting build. Have you got enough room in the frame to lift the rocker cover off to set the tappets? -I know from my own trike that it's easy to make it too tight!
reliantman
« Reply #2 on: April 05, 2008, 09:05:04 PM »
You know I did'nt think of that. There is enough room to drop the whole engine down, but it seems a lot to have to do to set the tappets. Bummer!
reliantman
« Reply #3 on: April 06, 2008, 09:28:09 AM »
I had another play this morning. I can gain a few inches by moving the engine foward a bit.
Also tried it with the Ural front wheel.
« Reply #4 on: April 06, 2008, 10:11:41 AM »
its coming along Smiley but i suspect u are gonna ave to persuade the frame to bend a tad more for that rocker cover
reliantman
« Reply #5 on: April 06, 2008, 10:23:22 AM »
If I can get in there with the disc cutter I will take some metal out from under the join where the arrow is.
« Reply #6 on: April 06, 2008, 10:33:48 AM »
Don't forget you need room for a fan & radiator too!
reliantman
« Reply #7 on: April 06, 2008, 10:59:14 AM »
I'm going to try it in front of the frame.
reliantman
« Reply #8 on: April 09, 2008, 10:09:37 AM »
This morning I was having a look at the axle mounts, and also found room to prop a scabby old rad in to see if it fitted.
Loads of room in there and the water pipes almost line up.
texon
« Reply #9 on: April 09, 2008, 04:56:03 PM »
Its great when plans come together  Grin
reliantman
« Reply #10 on: April 16, 2008, 01:48:22 PM »
Been out again in the sun today, and did this. All the bits are tied together with string, but it gives me an idea where everything will go. There will be big ball bearing sets at all points to keep it on the right track.
« Reply #11 on: April 16, 2008, 01:52:00 PM »
taking shape young man Grin
reliantman
« Reply #12 on: April 16, 2008, 01:58:24 PM »
I hav'nt been up to much as the mrs has been bad, but she decided to have a potter in the garden today so I went out as well.
You ok?
« Reply #13 on: April 16, 2008, 06:30:39 PM »
I'd just like to point out that MMMotors doesn't condone the use of string as an alternative to welding.
Try Gaffer tape. Wink
« Reply #14 on: April 16, 2008, 06:56:52 PM »
hey theres nowt wrong with string just as long as you double knot it pmsl  Grin
Mousy Boy :-) AKA Mick Smiley
Pages: [1] 2 3
