January 17, 2026, 05:02:51 PM *
Author Topic: cx500 (again)  (Read 2918 times)
« on: October 19, 2015, 12:28:57 AM »
Looking in my manual for info tonight and it says it has a primary reduction gear of 2.24 . Knowing naff all about bikes doe sthis mean that output from gearbox max revs will only ever be 10,000 (redline ) divided by 2.24?  I was actually chceking overall tyre size and final drive ratio and it's a really tall gearing which doesn't tie up with what I've been told about cruising speed of these motors
IE Final drive of 3.09 with tyre diameter of approx 24" gives a theoretical top speed of about 240 flat out in 5th!!  Halving that output would make it more realistic and easier to work out car diff ratio needed.
« Reply #1 on: October 19, 2015, 07:15:17 AM »
Yep. The clutch/input shaft runs at a lower speed than the crankshaft. On some bikes the clutch basket is chain driven, on the CX it is geared.
