January 17, 2026, 12:04:46 PM *
Pages: [1] 2 3 4
Author Topic: Crunch time  (Read 21607 times)
hornet6
« on: November 27, 2014, 09:35:14 PM »
Hi. Have,nt been around for some time....only dropping in occasionally to see how other peoples builds are going. Well, now its crunch time. Its time to try and get my project running this weekend. A mate of mine is going to wire up the motor and see if it fires up ok. Theres no indicators or lights rigged up just yet. This is just to test that the motor is ok.  It has changed a little bit since this last photo.
no projects ever finished
hornet6
« Reply #1 on: November 27, 2014, 09:43:05 PM »
The KN air filters have gone. I have made a flat style air filter of my own design which I hope will work. Also, the tank has gone, and I hope to make my own twin tanks. Also, the mountain bike shocker for the seat has been junked. There was to much lateral play in it, which was making the seat rock from side to side. In its place is a home made leaf spring , which looks great and is more firmer than the bike shocker. I will try and get some photos of the new mods on here soon for merv  Grin Grin Grin Grin Grin Grin
hornet6
« Reply #2 on: November 27, 2014, 10:10:34 PM »
This is the base of the right side air filters
hornet6
« Reply #3 on: November 27, 2014, 10:15:04 PM »
Mesh added
hornet6
« Reply #4 on: November 27, 2014, 10:21:59 PM »
The air filter sponge is fitted, then the top goes on.
hornet6
« Reply #5 on: November 27, 2014, 10:23:57 PM »
Fitted nice and snug under the top frame rail. Grin Grin
hornet6
« Reply #6 on: November 27, 2014, 10:25:02 PM »
Will post some more pics tomorrow.
« Reply #7 on: November 28, 2014, 06:14:41 PM »
I loved the cut outs in the tank with the air filters poking through, but I guess the airbox will be more practical. Nicely made. I'll be interested to see the leaf spring cos I'd considered using a cut down tractor seat one on Tazet's trike. Indicators suggest you might be MSVAing this?
hornet6
« Reply #8 on: November 28, 2014, 07:41:02 PM »
Heres a pic of the leaf spring. Its made from 3 strips of 40*3mm thick stainless steel. At the moment its quite firm......I think if I cut the 2 inner strips a bit shorter it should make it a bit softer.  The 2 brackets hanging down near the center of the saddle will be cut off,as they we,re made for the shocker.
hornet6
« Reply #9 on: November 28, 2014, 07:43:40 PM »
This is the right inside part of one of the tanks. Only tacked together,but I think the shape is ok.
hornet6
« Reply #10 on: November 28, 2014, 07:45:41 PM »
An overall shot. I think the battery box might go as well....or be made as small as possible.
« Reply #11 on: November 28, 2014, 08:48:30 PM »
Those carbs are at an extreme angle, near on down draft, is there no float chamber on those?
hornet6
« Reply #12 on: November 29, 2014, 05:00:00 PM »
Yes there is float bowls on em. The engine and carb set up is completely standard....they are at that angle. This is what caused the problems with the air filters clashing with the frame. On the standard bike,the air filter box sits half way into the back end of the tank between the frame rails.
Any way, more importantly.....ITS ALIVE....ALIVE. Very noisy with the open exhaust,but it fired up and ran. Well chuffed with the guy who sorted the black art of lectrickery.
« Reply #13 on: November 29, 2014, 06:29:48 PM »
Hurrah! Well done chaps.
hornet6
« Reply #14 on: November 29, 2014, 07:14:24 PM »
How do I go about MSVA then. Do I need to do more work on it first before they inspect it  ie fit footrests,brakes, lights and indicators Huh  All confused but excited at the same time  Roll Eyes Roll Eyes Roll Eyes
Pages: [1] 2 3 4
