Title: It's still going to be a trike Post by: jevi on July 29, 2012, 10:43:21 AM Third time lucky? Don't know if its my computer skills (or lack of them) but I've tried twice already to make this post. I was wondering if this would work?
Title: Re: It's still going to be a trike Post by: zakboy on July 29, 2012, 11:45:18 AM Is this your ural jevi
Title: Re: It's still going to be a trike Post by: steven brock on July 29, 2012, 02:08:49 PM Leading link front? or is this the rear?
Title: Re: It's still going to be a trike Post by: kevsky on July 29, 2012, 02:27:41 PM don't think the cable ties will hold out for very long
Title: Re: It's still going to be a trike Post by: digger06 on July 29, 2012, 03:55:38 PM ural frames are thick but i think i would beef it up in that area before using as a trike, not much triangulation in that area
Title: Re: It's still going to be a trike Post by: terry t on July 29, 2012, 04:30:50 PM i don't think this will work for a swing arm.hard tail yes. if you want to use the existing swing arm pivot point on the Ural frame for your A frame to fit. and the shock points for the suspension that will work. but if you use points B/C for for extra pivot points then they will pull the frame. and not move with the main A frame
have a look at this http://www.uralmotorbikes.info/trikes.htm Title: Re: It's still going to be a trike Post by: Plasticpig on July 30, 2012, 03:48:50 PM Jevi.
Point 'B' is only a mount for the rear footrests/exhausts, and is probably only lightly welded or braised. Just my 2p's worth, but how about hanging the front of your frame off a piece of plate fixed to the two engine mounting holes and brace it off the swing arm mounting point? I had mounts off the swingarm and one bolted under the seat. Title: Re: It's still going to be a trike Post by: jevi on July 30, 2012, 06:02:08 PM I hope this gets through that mysterious force which seems to be blocking my attempts to respond to all these comments.
The answers are - yes, its the rear, wot even if I tighten them right up and I hadn't thought about that. To TerryT thanks for the link to MPC that's where I got the bike from. I had looked at their werewolf trikes before I decided to try making this a three wheeler (I couldn't afford to pay for the conversion so thought I'd do it my self) Hello Mr Plastic, you've just given me the kick I need to get back on track. I had thought of using the swing arm pivot point as one fixing point, point B as a second and intended to extend back a touch behind where the rear mudguard/pillion mount goes and use that as a third brace point. Title: Re: It's still going to be a trike Post by: Plasticpig on July 30, 2012, 08:12:40 PM If I was to make the rear end again, I would build it as in the modified pic, bolted to the engine mounts where the white arrows are.
Title: Re: It's still going to be a trike Post by: jevi on July 31, 2012, 12:15:26 PM Thanks Plasticpig for the response, your idea is a good one. I took some pics this morning before I came to work so I'll have a bit of a play around with paint on the computer and see what I can come up with.
