May 18, 2024, 12:19:17 PM *
Author Topic: XJ 650 Trike project  (Read 1335 times)
voodoo
« on: August 07, 2011, 10:36:18 PM »
Need to clear some space so having a clear out..
XJ 650 Excellent running motor...
Basically its the bike minus swing arm with the rear section cut off ready to fabricate it up to except this rear end.....
Full Trike rear end came from front damaged Trike...It has a full bench seat with seatbelts a front seat...Volvo Disc brake axel with nice alloys & excellent tyres..mudguards, lights ect ect...basically stick it back together & either bolt it onto the swing arm ( part of origional Trike frame with swing arm section supplied) or weld it onto the front section... origional Trike Was built by a Trike shop & is very very well made....origional front end & engine were Kawazaki GTR 1000 which are easy & cheap enough to buy if you just want to do it that way....Bike has log book in my name.....
Want £1000 for the lot..it even has this Tank I started to get ready for a complete custom spray job, theme was a ratty looking Bio Hazard Trike lol......I can complete the rest of the panels in that theme for an additional cost..that would be both Trike mudguards, front mudguard & side panels......Paintwork would work out @ only £350 if done when buying this lot.....
So A grand for everything you need & only fabrication is to how you want to connect the two....
Here's a pic or 2 of tank...Voodoo.....
http://i119.photobucket.com/albums/o131/voodooist666/Paintwork/IMG_3925.jpg
http://i119.photobucket.com/albums/o131/voodooist666/Paintwork/IMG_3924.jpg
http://i119.photobucket.com/albums/o131/voodooist666/Paintwork/IMG_3923.jpg
http://i119.photobucket.com/albums/o131/voodooist666/Paintwork/IMG_3921.jpg
http://i119.photobucket.com/albums/o131/voodooist666/Paintwork/IMG_3920.jpg
Custom Paint Spraying...
