May 16, 2024, 01:08:40 AM *
Author Topic: speedo drive  (Read 2025 times)
gpz
« on: March 25, 2009, 11:27:45 PM »
does any one know if not using the speedo cable on reliant gearbox will it leak oil if not blanked off and if it does what can u use to blank it off
tony b
« Reply #1 on: March 25, 2009, 11:29:20 PM »
it will leak oil ,try a 22mm plumbing blank or cut the end from the speedo drive,the bit that screws onto the box and solder a 1p coin into it.
« Reply #2 on: March 26, 2009, 07:48:58 AM »
Well done Tony,  Grin.
« Reply #3 on: March 26, 2009, 11:54:24 AM »
It's only a little dribble, working it's way round the threads of the drive unit, but obviously a little drip can go a long way, (just look at Tony Blair), so if you're not using it, then definitely blank it off. I found cutting the screw-on fitting from the end of an old Reliant cable & blanking the hole in it with a rubber blanking grommet, sealed with a dab of Araldite glue, did the job on my last one.
Alternatively, give Twisted Patience or FLC a shout & persuade them to machine you a purpose made blanking cap.  Smiley
« Last Edit: March 26, 2009, 01:31:46 PM by Manky Monkey » Logged
gpz
« Reply #4 on: March 26, 2009, 01:10:53 PM »
thanks guys i sought thought it would leak but i just needed to make sure
tony b
« Reply #5 on: March 26, 2009, 10:16:15 PM »
thnks tbone,lol,shabba
blair
it looks bigger in water ! !
« Reply #6 on: March 27, 2009, 10:09:36 AM »
just out of curiosity has anyone actually ever met TONYB ? could we have an X labour leader in our midst ?
« Reply #7 on: March 27, 2009, 10:18:22 AM »
can't be, our one is far too clever Grin after all his is BUILDING a trike, all the other one did was to ruin things Wink
« Reply #8 on: March 27, 2009, 11:31:20 AM »
I've long suspected TonyB is just a figmant of our collective imaginations. He doesn't really exist
-does he?  Tongue
