« Reply #105 on: April 10, 2009, 09:39:29 AM » |
Yep a clear plug is used to see what colour the ignition process is.
I doubt that it's the plugs at all sound like you need to check your carbs ASAP.
« Reply #106 on: April 10, 2009, 04:19:40 PM » |
Got the seat mounted to the seat pan, and just laid it roughly on the rails, just for the pics!!!
« Reply #107 on: April 10, 2009, 04:20:23 PM » |
« Reply #108 on: April 15, 2009, 01:32:47 PM » |
Can anyone tell me if the item circled is the neutral switch?
I only ask 'cos when I removed it to check it's servicability, all the oil pi**ed out of the hole!?!?!?!
The manual is lacking in direction as to where the neutral switch is?
blair
it looks bigger in water ! !
« Reply #109 on: April 16, 2009, 08:06:14 AM » |
yep neutral switch
« Reply #110 on: April 24, 2009, 01:13:24 PM » |
« Reply #111 on: April 24, 2009, 01:13:50 PM » |
« Reply #112 on: April 24, 2009, 01:14:16 PM » |
« Reply #113 on: April 24, 2009, 01:14:48 PM » |
« Reply #114 on: April 24, 2009, 01:15:35 PM » |
« Reply #115 on: April 24, 2009, 01:19:18 PM » |
Sweeeeeeeeeeeeeeeeeeeet ride there Clive does it go alright?
« Reply #116 on: April 24, 2009, 01:39:53 PM » |
Bit lumpy, in for colourtune, and carb balance after MoT!
« Reply #117 on: April 24, 2009, 03:20:19 PM » |
Great! Good luck with the MOT Clive -just in time for the Summer.
65nova
« Reply #118 on: April 24, 2009, 06:05:50 PM » |
bloody lurvley mate....really like it
« Reply #119 on: April 24, 2009, 09:48:18 PM » |
Very Cool Good luck with the MoT and the write-up you're gonna have to do now
