May 16, 2026, 06:34:05 AM *
Author Topic: disc conversion help please!  (Read 4584 times)
LEVVIN
GRIN AND BEER IT!
« on: July 29, 2011, 11:09:22 PM »
As the original reliant disc converter, Lord Monkey, can you please advise me on the exsessive pedal travel i have ended up with, please?
ive gone to the book, fitted mk4 golf calipers, nova discs, gti carriers, stainless braided hose, and a fireblade 5/8" master cylinder on my xs1100 hardtail trike.
i had a nightmare bleeding them, and now, with no air left in the system at all, i get rear brake, but with huge pedal travel and brake biting hard just as the cylinder reaches its internal stops.
help please!
i would have thought that the pedal should be rock hard well before the end of cylinder pushrod travel!
lev
GRIN AND BEER IT!      Easy now!
zakboy
« Reply #1 on: July 30, 2011, 03:19:04 AM »
hi Levin, sounds like the master cylinder is bottoming out before the brake pads have enough pressure behind them to bring them up against the disc,s sufficiently, you need a bigger master cylinder you may be better off using a landrover master cylinder or the kit car copy of them you get on ebay instead of a bike master cylinder they have a 3/4" bore and should cure the prob work,s a treat on mine,all the best zak
« Last Edit: July 30, 2011, 03:42:29 AM by zakboy » Logged
LEVVIN
GRIN AND BEER IT!
« Reply #2 on: July 30, 2011, 09:17:50 AM »
hi Zak,
the problem i have is the trike s bike derived with std pedal, vertical throw, and all the car cyls ive seen have to be mounted horizontally with res on top.
bike style as you know have res via a hose and operated from below.
any suggestions on how to fit a car style cylinder this way?
lev
zakboy
« Reply #3 on: July 30, 2011, 09:42:04 AM »
hi Levvin, i know exactly what you mean i also had to do it on the xj900 project as well because the bike cylinder was just not delivering enough fluid before the piston bottomed out (not big enough) for the disc covertion, not sure what the pedal set is on yours but i would imagine it was pretty much the same as the xj with the master cylinder mounted vertical with a remote reservoir, so we had to do away with the short rod on the pivot arm on the pedal and connect a much longer one and mount the landrover cylinder horizontally on a bracket further back on the frame but also had to fit a pivot arm on the bracket that the master cylinder was on,its a little hard to explain, but if you have a look though my thread xv 750 virago project i did go into in more detail with pic,s i all so went thought in more detail with the xj900 witch i think is on page 4 0r 5 of the trike page entitled gnash and zakboys xj900 trike project,another alternative is that recently i have seen some larger bore master cylinders on eBay with remote reservoirs that i think could be mounted vertical but cant remember witch section they were in i think it may have been in the kit car spares,
« Last Edit: July 30, 2011, 10:01:35 AM by zakboy » Logged
« Reply #4 on: July 30, 2011, 10:56:56 AM »
old style mini  master cyl.s mount vertical with the res, built in  Wink
« Reply #5 on: July 30, 2011, 06:39:02 PM »
hi Zak,
lev
Hi, here is picture of how i did mine on my last GS850 Suzuki. The linkage changed vertical throw to horizontal for the Landrover clutch master cylinder. hope this helps.
regards
]pete
« Reply #6 on: July 30, 2011, 06:39:54 PM »
another photo
well its nearly horizontal Roll Eyes Smiley
RODeo
« Reply #7 on: August 01, 2011, 05:07:54 AM »
Looks good TP. I was gonna suggest using a cam to change direction ,but wasnt sure of the existing bike set up. The only thing I would suggest from Levvins point of view is to make the cam 'legs' longer with various holes drilled in them. That way you can keep adjusting until the pedal height/pressure etc feels ok ,then chop off the excess metal.
        Rod
« Reply #8 on: August 01, 2011, 10:09:06 AM »
Or you could use a 5/8" Girling master cylinder with a remote reservior and knock up a mounting bracket to fit the existing cylinder mounting holes.
Or you could use your bike setup to power a slave cylinder mounted on the rear frame.
« Last Edit: August 01, 2011, 10:17:29 AM by tbone » Logged
LEVVIN
GRIN AND BEER IT!
« Reply #9 on: August 02, 2011, 11:19:51 PM »
hi guys.
sussed it!
ordered a landie clutch mc a few days ago.
no need for loads of bracketry, by simpley rotating the brake pedal spindle 90 degrees anti clockwise, so it is protruding from the bottom of the spindle at 5'o'clock, and removing/rewelding the stop buffer, the arm on the spindle naturally moves the mc pushrod horizontally with pedal depression.
i tried a 5/8" fireblade mc, and it was totally useless with 2 golf mk4 calipers.
would apply the brakes at the exact moment it reached its fullest travel.
hoping this 3/4" landie mc will do the job on my xs1100 hardtail.
lev
zakboy
« Reply #10 on: August 03, 2011, 04:12:20 AM »
The 3/4 mc will do the trick Lev, and if the cam on your pedal shaft can operate at the 5.00 o'clock position it will make life allot simpler,could not rotate mine to that position because it would fowl on the frame and had to keep it at the 12.00 clock position witch meant when depressing the pedal the brake rod had the opposite action to what i needed it pulled instead of pushed so i had to add another pivot leaver at the mc end to reverse the action of the brake rod when depressing the pedal.  zak
« Last Edit: August 03, 2011, 04:24:49 AM by zakboy » Logged
« Reply #11 on: August 03, 2011, 06:39:37 PM »
Aah, the joys of custom building!
LEVVIN
GRIN AND BEER IT!
« Reply #12 on: August 03, 2011, 09:39:22 PM »
still cant show off my handywork on here!!
just cant seem to post pics from my pc!
real easy on uk triker forum!
Anyways, ive fitted the 3/4" landie mc, just cut off the pedal spindle stop, as the frame acts as a stop now i've turned the pivot arm so its at 7'o'clock. (5'o'clock was too steep!)
fitted the mc plunger straight onto the pedal pivot arm, made a funky bracket for the mc mounted just off horizontal and it all works fine now! locks wheels up a treat!
lev
« Reply #13 on: August 04, 2011, 06:31:10 AM »
try re sizing your pics. There is a thread on here somewhere about it (now some clever a**se will pop up with the link !!! Grin Grin Grin Grin)
Firery Fred
« Reply #14 on: August 04, 2011, 08:30:19 AM »
Yeah,but not me  Cheesy
